Hi Group
Will someone please explain why negative flaps supposedly provides better aileron control. I know conventional wisdom says that it does but WHY? It is not intuitively obvious at least to me. Yes I have tried negative flaps at low speeds both on the roll and braking but its effect as far as I could judge was marginal and my thoughts were that it reminded me of a placebo. So please direct me to the authorative articles on the subject or if there is a simple explanation please educate me. Thanks. Dave PS Also posted on the Stemme Owners Group where there is a thread running on the use of negative flaps for better control. |
Dave,
Sorry I don't know the aerodynamics (was trained in fluid dynamics of bioreactors, not aerodynamics) only that it made a world of difference on both my Nimbus 2 and Ventus B. The wings will drop on both without it, where with it I can usually come to a full stop before the wing will drop. It is definitely not a placebo. Try it in an 8-10 knot breeze. Point the plane into the wind and try both positions. Tim |
It's mainly useful on gliders that sit at a high angle of attack on the
ground. At low speeds, the wing is stalled, reducing aileron effectiveness as they are in the detached airflow; selecting negative flaps decreases the effective angle of attack of the wing and can provide some aileron effectiveness at low speeds by unstalling the wing earlier. Same thing while slowing down - negative flaps will delay the wing stalling and losing aileron effectiveness. It also helps to get the tail up as soon as possible, although by the time you can raise the tail the ailerons will probably be working...what some gliders really need is an extended (and retractable) tailwheel - start the roll with the tail level, lower the tail as speed increases. Just joking (kinda). Kirk 66 |
Going to negative on the ground run as you slow reduces
the angle of attack and stops the wing from stalling on gliders that are prone to wing dropping. Also reduces lift (AoA) and helps glider stick to the ground, ie, no desire to keep flying as the wing can't generate enough lift. John PS Some glider have ailerons that go negative (or do not go as positive) as flaps are increased towards landing, eg, Mosquito, ASH 25. |
All of the following applies only to gliders, that have a Flap-Aileron
connection, i.e. changing the flap position changes the aileron position as well. I can confirm that the ground-runs with negative flaps make a difference with my Libelle H301. The AoA is the angle between the chord line and the relative wind. Try this: look at the wing from the tip towards the fuselage with the stick centered and the flaps full positive. Draw a mental line from the leading edge to the trailing edge of the aileron. The airflow (relative wind) will be parallel to the ground during the ground roll. Now put the flaps up full negative and repeat the above. The line is now at a shallower angle since the leading edge is still where it was before but the trailing edge is up. The thing that really helps to gain roll control on take-off with the Libelle is to get the tail up and 'flying' asap. That way, the wing is at a small AoA and the ailerons are effective right away. Uli Neumann |
wrote in message oups.com... Hi Group Will someone please explain why negative flaps supposedly provides better aileron control. I know conventional wisdom says that it does but WHY? The flap/aileron interconnect has a lot to do with it. With the help of another person; Put the flaps in full negative then measure the max deflection of the aileron (full up to full down). Then put the flaps in full positive and again measure the max aileron deflection. With many sailplanes you will find that with negative flaps the interconnect allows a greater range of aileron deflection. Duane |
T o d d P a t t i s t wrote: Once you are on the ground, with your front
and back wheels rolling (or skid/wheel, etc.) the angle of attack remains unchanged. Stalling is a function of the AOA, not your airspeed. Stall is only indirectly related to airspeed when your aircraft weight is supported by lift. On the ground your weight's supported by your wheel(s), so you can go very slowly and not be stalled. (Unquote). I'm open to correction, but I think Todd is only right in the circumstances that the glider stays level laterally. As soon as a wing starts to drop, and the other to rise, the dropping wing has a higher AoA and the rising wing a lower one. On a nil wind day, with the glider having reached say 10 knots during the take-off run (faster than the wingtip runner can run), a tip dropping at even 1 knot has an extra AoA of 6 degrees - may well be enough to stall it with neutral aileron. Putting that aileron down (to try to lift the tip) just increases the AoA even more into its stall - hence, ineffective. Negative flaps, if ailerons move in sympathy with them, can be enough to unstall that downgoing tip. By the way, what Todd says about non-linear CL curve makes entire sense to me, and Duane's point about geometry, and others' comments. I just think all effects are in play, at least on some gliders. Now, why does opening the airbrake (usually called spoilers in the USA for some unknown reason) help on some gliders? And did it ever help on gliders that really did have spoilers (UK-speak for things that spoil lift but don't add much drag, unlike airbrakes [in UK-speak], which do both in spades)? Chris N. ===================== __________________________________________________ _________ Yahoo! Messenger - NEW crystal clear PC to PC calling worldwide with voicemail http://uk.messenger.yahoo.com |
What Todd says about angle of attack on the ground makes sense and is absoulutely correct - the problem is that we are working with wings well below their stall speeds, with weight supported by the landing gear, so "angle of attack" takes on a different meaning: at low speeds and "high angle of attack", the airflow around the wing is probably highly turbulent, and control surfaces will be inefficient. Reduce that "angle of attack" and the control surface is working in undisturbed (or less disturbed) air, and should be more effective. Raise the tail, and turbulence should be at a minimum. I would love to see some wind tunnel testing of, say, a Pik-20 wing at low (below stalling) speeds. I would bet a high tow that at the normal ground attitude, on the ground (i.e. a ground plane below the wing, weight supported by the gear), at low speeds (zero to 20 knots?), the airflow over the wing is probably really turbulent, and that setting negative flaps/ailerons moves those control surfaces closer to "undistrubed" flow, giving them a little more effectiveness. Remeber, this is a short, transitory phase of the development of airflow and lift over the wing - I wonder if much study of this "pre-flight" regime has been done. Then again, I may be full of sh*t! I do know it works on a Pik-20b, and that my LS6 doesn't really care where my flaps are during takeoff (but I use negative anyway, and go full negative on rollout - gets the flaperons out of the rocks!). Kirk 66 |
On Sat, 30 Jul 2005 00:05:03 UTC, "
wrote: : at low speeds : and "high angle of attack", the airflow around the wing is probably : highly turbulent I doubt that. Turbulence is associated with high Reynolds number, and that depends directly on speed. Low speed - low Re - less turbulence. Ian -- |
| more radial fans like fw190? | jt | Military Aviation | 51 | August 28th 04 05:22 AM |
| ASW-20 flaps setting VS speed | AttentionLEcureuil | Soaring | 4 | March 10th 04 12:25 AM |
| Speed Astir | Guy Acheson | Soaring | 0 | December 11th 03 03:24 AM |
| Overweight takeoff / flight | Koopas Ly | Piloting | 50 | December 4th 03 12:53 AM |
| Flaps and V-Tails of Death | Wallace Berry | Soaring | 59 | November 26th 03 10:54 PM |
