Peter wrote: FAR 91.175 (a) suggests that it is not permitted to carry out a descent in IMC except on an official published IAP. It does more than suggest, it states it quite explicitly (for most of us, neither of the exceptions are likely to apply): "Unless otherwise authorized by the Administrator, when an instrument letdown to a civil airport is necessary, each person operating an aircraft, except a military aircraft of the United States, shall use a standard instrument approach procedure prescribed for the airport in part 97 of this chapter." How would it differ if the entire procedure was done in Class G? Not in the least. All IFR rules apply in class G except for the requirement to obtain a clearance. |
![]() "Peter" wrote in message ... FAR 91.175 (a) suggests that it is not permitted to carry out a descent in IMC except on an official published IAP. Any views on this? FAR 91.175 (a) suggests nothing, it states, "Unless otherwise authorized by the Administrator, when an instrument letdown to a civil airport is necessary, each person operating an aircraft, except a military aircraft of the United States, shall use a standard instrument approach procedure prescribed for the airport in part 97 of this chapter." How would it differ if the entire procedure was done in Class G? It wouldn't differ in any way, the regulation is not limited by class of airspace. |
"Roy Smith" wrote in message
... It does more than suggest, it states it quite explicitly (for most of us, neither of the exceptions are likely to apply): "Unless otherwise authorized by the Administrator, when an instrument letdown to a civil airport is necessary, each person operating an aircraft, except a military aircraft of the United States, shall use a standard instrument approach procedure prescribed for the airport in part 97 of this chapter." So the next question, which I'll ask on Peter's behalf is... Since Part 97 only prescribes approaches for airports within the US (and presumably associated territories), how does an N-registered aircraft ever fly an IAP in IMC outside the US? Julian |
![]() "Julian Scarfe" wrote in message ... So the next question, which I'll ask on Peter's behalf is... Since Part 97 only prescribes approaches for airports within the US (and presumably associated territories), how does an N-registered aircraft ever fly an IAP in IMC outside the US? Probably by being otherwise authorized by the Administrator. |
... So the next question, which I'll ask on Peter's behalf is... Since Part 97 only prescribes approaches for airports within the US (and presumably associated territories), how does an N-registered aircraft ever fly an IAP in IMC outside the US? "Steven P. McNicoll" wrote in message .net... Probably by being otherwise authorized by the Administrator. So is there some sort of generic authorization, or is it authorized on a case by case basis? The latter seems unlikely. Do you really apply for such an authorization every time you fly IFR to Canada? Julian |
![]() "Julian Scarfe" wrote in message ... So is there some sort of generic authorization, or is it authorized on a case by case basis? Probably neither. The latter seems unlikely. Do you really apply for such an authorization every time you fly IFR to Canada? I've never flown IFR to Canada. Given that Part 91 only prescribes rules governing the operation of aircraft within the United States, including the waters within 3 nautical miles of the U.S. coast, I'd feel pretty silly asking for such authorization if I had a notion to. |
"Julian Scarfe" wrote:
So the next question, which I'll ask on Peter's behalf is... Since Part 97 only prescribes approaches for airports within the US (and presumably associated territories), how does an N-registered aircraft ever fly an IAP in IMC outside the US? That's easy, this rule doesn't apply outside the US. Part 91.1 says: "this part prescribes rules governing the operation of aircraft [...] within the United States, including the waters within 3 nautical miles of the U.S. coast." |
So the next question, which I'll ask on Peter's behalf is... Since Part 97 only prescribes approaches for airports within the US (and presumably associated territories), how does an N-registered aircraft ever fly an IAP in IMC outside the US? "Roy Smith" wrote in message ... That's easy, this rule doesn't apply outside the US. Part 91.1 says: "this part prescribes rules governing the operation of aircraft [...] within the United States, including the waters within 3 nautical miles of the U.S. coast." Ah. I'm getting confused with Parts 43 and 61, which clearly have to (and do) apply extraterritorially. That will also satisfy Peter's original question, which I think was looking at the applicability outside the US. Julian |
![]() "Julian Scarfe" wrote in message ... Ah. I'm getting confused with Parts 43 and 61, which clearly have to (and do) apply extraterritorially. That will also satisfy Peter's original question, which I think was looking at the applicability outside the US. What in Peter's original question suggested to you that he was looking at the applicability outside the US? |
So the next question, which I'll ask on Peter's behalf is... Since Part 97 only prescribes approaches for airports within the US (and presumably associated territories), how does an N-registered aircraft ever fly an IAP in IMC outside the US? "Roy Smith" wrote in message ... That's easy, this rule doesn't apply outside the US. Part 91.1 says: "this part prescribes rules governing the operation of aircraft [...] within the United States, including the waters within 3 nautical miles of the U.S. coast." Now Peter has got me wondering about this. The first bit that you snipped says: " (a) Except as provided in paragraphs (b) and (c) of this section and Secs. 91.701 and 91.703, this part prescribes rules governing the operation of aircraft" "Sec. 91.703 Operations of civil aircraft of U.S. registry outside of the United States. (a) Each person operating a civil aircraft of U.S. registry outside of the United States shall-- .... (2) When within a foreign country, comply with the regulations relating to the flight and maneuver of aircraft there in force; (3) Except for Secs. 91.307(b), 91.309, 91.323, and 91.711, comply with this part so far as it is not inconsistent with applicable regulations of the foreign country where the aircraft is operated or annex 2 of the Convention on International Civil Aviation; ..." So what's the test for something being "inconsistent with applicable regulations"? Many regulations work as prohibitions: if Part 91 prohibits something and the regulations of the foreign country remain silent on the issue (for example, the choice of instrument letdown), would the N-reg aircraft still have to comply with Part 91? Julian |
Only official instrument approaches authorised under FAR? | Matt Barrow | Instrument Flight Rules | 32 | August 5th 05 11:25 PM |
Instrument Checkride passed (Long) | Paul Folbrecht | Instrument Flight Rules | 10 | February 11th 05 02:41 AM |
Instrument Rating Checkride PASSED (Very Long) | Alan Pendley | Instrument Flight Rules | 24 | December 16th 04 02:16 PM |
PC flight simulators | Bjørnar Bolsøy | Military Aviation | 178 | December 14th 03 12:14 PM |
Logging instrument approaches | Slav Inger | Instrument Flight Rules | 33 | July 27th 03 11:00 PM |
