I bought a Cassutt (Primarily tube, fiberglass and fabric). It has a
light-weight BNC battery, starter and alternator, and a old Grand Rapids engine monitoring system but no radios. I wish to install a panel mounted MicroAir Radio and Transponder. I think I can figure out the wiring of the radios but the only aluminum on the airplane is a 12"X11" aluminum belly pan. Can I use this as a ground plane for both the VHF and transponder antennas? If so, where should I position them with respect to each other and the edge? With regard to the antennas, a transponder antenna came with the MicroAire Transponder, and I plan to purchase a VHF antenna from aircraft spruce. Aircraft spruce however, has many different designs, brands and of course prices. Which one would give me the best performance for my application? I have about 21" from the belly pan to the ground in the three point position. Any help you could give will be greatly appreciated |
A 12 x 11 belly pan is far too small for a COM ground plane. Find a tube
cluster weld, with four or more tubes joined together and clamp (or weld) a small plate near the center of the cluster, just big enough to hold the base of the COM antenna. The tubes will act as the ground plane. As to the transponder antenna, it is a relatively noncritical design. The cheap little "rod with a bb on the end" has worked for tens of thousands of installations and I see no reason it won't work for you. Mount it to the center of the belly pan and you should be OK. Jim "Steve" wrote in message om... I bought a Cassutt (Primarily tube, fiberglass and fabric). It has a light-weight BNC battery, starter and alternator, and a old Grand Rapids engine monitoring system but no radios. I wish to install a panel mounted MicroAir Radio and Transponder. I think I can figure out the wiring of the radios but the only aluminum on the airplane is a 12"X11" aluminum belly pan. Can I use this as a ground plane for both the VHF and transponder antennas? If so, where should I position them with respect to each other and the edge? With regard to the antennas, a transponder antenna came with the MicroAire Transponder, and I plan to purchase a VHF antenna from aircraft spruce. Aircraft spruce however, has many different designs, brands and of course prices. Which one would give me the best performance for my application? I have about 21" from the belly pan to the ground in the three point position. Any help you could give will be greatly appreciated |
| Retractable Comm Antenna | Ron Wanttaja | Home Built | 11 | September 6th 04 07:59 PM |
| ELT antenna -- Pitts | Al MacDonald | Home Built | 0 | July 15th 04 04:27 PM |
| Spare Transponder Antenna? | Jim Weir | Home Built | 6 | May 25th 04 04:34 PM |
| Fixing the Transponder with Duct Tape and Aluminum Foil | Ron Wanttaja | Home Built | 45 | March 14th 04 01:18 AM |
| Wanted: Transponder antenna | Grandpa B. | Home Built | 22 | November 28th 03 09:03 AM |
