One of the methods I want to try to reduce the noise of my Tailwind is
to modify my exhaust pipe as described on page 101 in Bingelis' book "Firewall Forward." I have a couple of questions. 1) First, has anyone done this and how successful was it? 2) On pages 101 and 106 Bingelis says to bend the rod "back for louver effect." But in the example on page 107 it looks like the rod was bent forward to make the louver. Tony describes it as an "excellent job." Bending back would seem to allow the exhaust gas to escape out the holes and bending forward would seem to allow the relative wind to flow into the holes. In either case the flow of the exhaust gas out the pipe would be disrupted, which, I think is the intent. Any suggestions on which way to go and if one way would work better than another? Thanks, Tom |
If this is the type of louvering you're trying to do:
http://www.spiretech.com/~guynoir/Pup/exhaust1.jpg I did it by making a paper layout using cad, wrapping it around the pipe, then drilling holes into the pipe. I only perforated the outboard half of the pipe. Then I deburred the holes, stuck a rod or a drill bit in each hole and pulled it aft as far as it would go. It turned out really well. The exhaust was substantially louder, though, but I wasn't following Bingelis's instructions when I made it. In fact, I don't know what Bingelis's instructions are. If you really want a quiet exhaust, here's a link to an article by Tony Bingelis on the "Swiss Style Muffler": http://www.piteraq.dk/flight/muffler.html gtm wrote: One of the methods I want to try to reduce the noise of my Tailwind is to modify my exhaust pipe as described on page 101 in Bingelis' book "Firewall Forward." I have a couple of questions. 1) First, has anyone done this and how successful was it? 2) On pages 101 and 106 Bingelis says to bend the rod "back for louver effect." But in the example on page 107 it looks like the rod was bent forward to make the louver. Tony describes it as an "excellent job." Bending back would seem to allow the exhaust gas to escape out the holes and bending forward would seem to allow the relative wind to flow into the holes. In either case the flow of the exhaust gas out the pipe would be disrupted, which, I think is the intent. Any suggestions on which way to go and if one way would work better than another? Thanks, Tom -- J Kimmel www.metalinnovations.com "Cuius testiculos habes, habeas cardia et cerebellum." - When you have their full attention in your grip, their hearts and minds will follow. |
John,
Thanks for the two links. The article concerning the Swiss Muffler was the most complete one I've seen. Thanks! Tom John Kimmel wrote: If this is the type of louvering you're trying to do: http://www.spiretech.com/~guynoir/Pup/exhaust1.jpg I did it by making a paper layout using cad, wrapping it around the pipe, then drilling holes into the pipe. I only perforated the outboard half of the pipe. Then I deburred the holes, stuck a rod or a drill bit in each hole and pulled it aft as far as it would go. It turned out really well. The exhaust was substantially louder, though, but I wasn't following Bingelis's instructions when I made it. In fact, I don't know what Bingelis's instructions are. If you really want a quiet exhaust, here's a link to an article by Tony Bingelis on the "Swiss Style Muffler": http://www.piteraq.dk/flight/muffler.html gtm wrote: One of the methods I want to try to reduce the noise of my Tailwind is to modify my exhaust pipe as described on page 101 in Bingelis' book "Firewall Forward." I have a couple of questions. 1) First, has anyone done this and how successful was it? 2) On pages 101 and 106 Bingelis says to bend the rod "back for louver effect." But in the example on page 107 it looks like the rod was bent forward to make the louver. Tony describes it as an "excellent job." Bending back would seem to allow the exhaust gas to escape out the holes and bending forward would seem to allow the relative wind to flow into the holes. In either case the flow of the exhaust gas out the pipe would be disrupted, which, I think is the intent. Any suggestions on which way to go and if one way would work better than another? Thanks, Tom -- J Kimmel www.metalinnovations.com "Cuius testiculos habes, habeas cardia et cerebellum." - When you have their full attention in your grip, their hearts and minds will follow. |
gtm wrote:
John, Thanks for the two links. The article concerning the Swiss Muffler was the most complete one I've seen. Thanks! Tom Essentially they homebuilt their own "Glass Pack" muffler avaliable at most auto parts stores. John |
![]() "UltraJohn" wrote Essentially they homebuilt their own "Glass Pack" muffler avaliable at most auto parts stores. But at a fraction of the weight!. Those things are heavy! I also believe the Auto store's glass packs are built with a steel tube, instead of stainless mesh for the inner tube. They are not nearly as effective, because of that reason. -- Jim in NC |
![]() John Kimmel wrote: ... If you really want a quiet exhaust, here's a link to an article by Tony Bingelis on the "Swiss Style Muffler": http://www.piteraq.dk/flight/muffler.html Is it just me, or does anyone else find it peculiar that he discusses how it may be difficult to find 80 mm Aluminum tube (which I sould think most homebuilders could approximate for themselves using sheet and rivets, with 3" nominal PCV pipe for a mandrel) but says nothing at all about where to get glass cloth, though he IS careful to point out that _fiberglass_ cloth won't work. So, where do you get glass cloth? -- FF |
![]() Ed Sullivan wrote: ... He didn't say don't use fiberglas cloth, he said [don't use] fibergas mat which is not woven. fibergas cloth is glass cloth. use as loose a weave as you can find. Check the Aircraft Spruce catalog. Aha! So it was just me. Thanks. -- FF |
![]() wrote in message oups.com... John Kimmel wrote: ... If you really want a quiet exhaust, here's a link to an article by Tony Bingelis on the "Swiss Style Muffler": http://www.piteraq.dk/flight/muffler.html Is it just me, or does anyone else find it peculiar that he discusses how it may be difficult to find 80 mm Aluminum tube (which I sould think most homebuilders could approximate for themselves using sheet and rivets, with 3" nominal PCV pipe for a mandrel) but says nothing at all about where to get glass cloth, though he IS careful to point out that _fiberglass_ cloth won't work. So, where do you get glass cloth? -- FF For the 80 mm Aluminum tubing, you might contact the local hang glider dealership. Maybe there's a broken cross bar you can beg or buy. Crossbars would usually be 7075, if that makes a difference. Tim Ward |
Exhaust pipe on one side is sooty | Casey Wilson | Piloting | 15 | June 14th 05 08:13 PM |
The Meredith Effect | Corky Scott | Home Built | 19 | September 4th 04 04:01 PM |
P-38 Exhaust | Stephen Harding | Military Aviation | 10 | April 19th 04 07:03 AM |
YF-23 exhaust? | Sir Loin of Beef | Military Aviation | 0 | August 1st 03 04:55 AM |
Exhaust Tape | RobertR237 | Home Built | 19 | July 30th 03 03:06 AM |
