I'll be a sumbitch, you are right. Here ya go...
Noted French pilot Nicolas Charmont has installed 2 AMT Olympus turbines in his Cri Cri together with AMT on-board automatic start-up units and individual EDT's. The Cri Cri weighs 170 Kg, and should have enhanced performance withover 36 Kg of thrust available. The Cri Cri has made his maiden flight in the weekeind of 7-8 March. Top speed at this flight was 240 km/hour (150 mph). Flying with only one engine the speed is still 160 km/hour (100mph). |
![]() "RST Engineering" wrote in message ... I'll be a sumbitch, you are right. Here ya go... Noted French pilot Nicolas Charmont has installed 2 AMT Olympus turbines in his Cri Cri together with AMT on-board automatic start-up units and individual EDT's. The Cri Cri weighs 170 Kg, and should have enhanced performance withover 36 Kg of thrust available. The Cri Cri has made his maiden flight in the weekeind of 7-8 March. Top speed at this flight was 240 km/hour (150 mph). Flying with only one engine the speed is still 160 km/hour (100mph). You have never seen that before? That has been posted -many- times before. Among the favorite debates, is how long the TBO is. Short, I think, in the almost hundred hour range. Also, they are tremendous fuel hogs. To fly a medium range, you would not have enough weight left (after fuel) to bring the pilot along. It would be an interesting way to log multi and jet time. g -- Jim in NC |
("RST Engineering" wrote)
[snip] The Cri Cri weighs 170 Kg, and should have enhanced performance withover 36 Kg of thrust available. (Copied from a different thread - juan missing JJJJJJJJ) http://www.flight.cz/cricri/english/index.php This page (bottom) says 63 kg and 75 kg ...for the twin prop versions. They list "Weight at take-off" as "170 kg," which is... 70 kg (Cri-Cri) + 100 kg (220 lbs for pilot and fuel) Also this quote: "Whole fuselage weight is about 14 kilograms." I've seen these numbers confused before. I'm still not 100% sure, but I'm leaning toward the Cri-Cri having an empty weight of under 200 lbs (90 kg). Yup, Part 103 legal baby!!! ....well except for the 5 gallon limit on Jet A ....and max speed limit of 55kts/63mph ....g Montblack |
Montblack wrote:
http://www.flight.cz/cricri/english/index.php This page (bottom) says 63 kg and 75 kg ...for the twin prop versions. They list "Weight at take-off" as "170 kg," which is... 70 kg (Cri-Cri) + 100 kg (220 lbs for pilot and fuel) Also this quote: "Whole fuselage weight is about 14 kilograms." I've seen these numbers confused before. I'm still not 100% sure, but I'm leaning toward the Cri-Cri having an empty weight of under 200 lbs (90 kg). Yup, Part 103 legal baby!!! ....well except for the 5 gallon limit on Jet A ...and max speed limit of 55kts/63mph ....g Does the twin-jet Cri-Cri still exist or does someone need to build one to get the Guiness mistake fixed? |
("Darrel Toepfer" wrote)
Does the twin-jet Cri-Cri still exist or does someone need to build one to get the Guiness mistake fixed? Light Sport Pilot has the restrictions of no turbines and no twins, however, Part 103 has no such restrictions - but 103 does have the fuel limit of 5 gallons, speed limit of 63 mph and the weight limit of 254 lbs. Safety equipment can be added above and beyond the 254 limit ...like how about another 5 gallons of fuel please - for safety! http://www.ultralighthomepage.com/FAR.part103.html FAR Part 103: Montblack |
Montblack wrote:
("Darrel Toepfer" wrote) Does the twin-jet Cri-Cri still exist or does someone need to build one to get the Guiness mistake fixed? Light Sport Pilot has the restrictions of no turbines and no twins, however, Part 103 has no such restrictions - but 103 does have the fuel limit of 5 gallons, speed limit of 63 mph and the weight limit of 254 lbs. Safety equipment can be added above and beyond the 254 limit ...like how about another 5 gallons of fuel please - for safety! http://www.ultralighthomepage.com/FAR.part103.html FAR Part 103: Guiness World Record smallest jet, only cares about it being a "jet" and "162 kg" max weight... Now if you actually want to fly it (apparently Yawn doesn't), then you can do the FAA paperwork for what classification you desire... I will contribute to the cause, that has the current record holder replaced... |
![]() Darrel Toepfer wrote: Montblack wrote: ("Darrel Toepfer" wrote) Does the twin-jet Cri-Cri still exist or does someone need to build one to get the Guiness mistake fixed? Light Sport Pilot has the restrictions of no turbines and no twins, however, Part 103 has no such restrictions - but 103 does have the fuel limit of 5 gallons, speed limit of 63 mph and the weight limit of 254 lbs. Safety equipment can be added above and beyond the 254 limit ...like how about another 5 gallons of fuel please - for safety! http://www.ultralighthomepage.com/FAR.part103.html FAR Part 103: Guiness World Record smallest jet, only cares about it being a "jet" and "162 kg" max weight... Now if you actually want to fly it (apparently Yawn doesn't), then you can do the FAA paperwork for what classification you desire... I will contribute to the cause, that has the current record holder replaced... There appear to be new contenders: http://www.priceless420.com/Pr081905planepractice1.jpg -- FF |
![]() "Darrel Toepfer" wrote in message ... Guiness World Record smallest jet, only cares about it being a "jet" and "162 kg" max weight... Nope. The Cri-cri is _longer_ than the BD-5J. That's why the BD-5J has held the record for more than 25 years. |
On Fri, 12 Aug 2005 14:00:59 -0500, "Montblack"
wrote: ("Darrel Toepfer" wrote) Does the twin-jet Cri-Cri still exist or does someone need to build one to get the Guiness mistake fixed? Light Sport Pilot has the restrictions of no turbines and no twins, however, Part 103 has no such restrictions - but 103 does have the fuel limit of 5 gallons, speed limit of 63 mph and the weight limit of 254 lbs. Safety equipment can be added above and beyond the 254 limit ...like how about another 5 gallons of fuel please - for safety! Hmmmm at 30 GPH per side, (those little engines use a lot of fuel) That's about 5 minutes total . Yah outta be able to make some where around 5,000 to 10,000 feet before flame out. Gas is needed for climb, but optional for landing. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com http://www.ultralighthomepage.com/FAR.part103.html FAR Part 103: Montblack |
Roger wrote:
Hmmmm at 30 GPH per side, (those little engines use a lot of fuel) That's about 5 minutes total . Yah outta be able to make some where around 5,000 to 10,000 feet before flame out. Gas is needed for climb, but optional for landing. Wow, that RC/B52 had 8 of them... Seems excessive, without going back to research it on the manufacters website for a looksee... |
