Last Call - Any Yoke changers out there?
Old August 12th 05, 03:10 AM
Mike Spera
Default Last Call - Any Yoke changers out there?
Still trying to find out if anyone has removed the old bowtie yokes from
their shafts and replaced them with ram's horns. Lots of folks changed
out the yoke/shafts as units, but nobody will fess up that they actually
swapped out the yokes themselves.
Since Piper lists the yoke/shaft as one part number, there probably is
no approved method of separating them.
Looks like I will return the ram's horns with bent shafts I bought from
the boneyard. If you cannot demate/remate them from/with the shafts,
they are useless.
Thanks,
Mike
Old August 12th 05, 03:50 PM
tom418
Mike, it's been around 37 years since I flew a Cherokee with the "Bow Tie"
yokes you described, but, I vaguely remember that the shafts on the B.T.
type yokes had a smaller diameter than those of the "Ram's Horn" variety.
This could explain why they might not be interchangeable?
"Mike Spera" wrote in message
ink.net...
they are useless.
Thanks,
Mike
Old August 12th 05, 04:16 PM
nobody
Mike,
I was really hoping you'd get an answer to this. I have
a 1964 Piper Aztec that I'd like to do the same thing
with, but when I looked at doing this before, it was just
too expensive.
Ronnie
ink.net...
their shafts and replaced them with ram's horns. Lots of folks changed out
Since Piper lists the yoke/shaft as one part number, there probably is no
the boneyard. If you cannot demate/remate them from/with the shafts, they
are useless.
Thanks,
Mike
Old August 12th 05, 11:08 PM
Jim Burns
Hey Ronnie,
I just looked at Avion's site and it looks like it would only cost us $1200
to do the Aztec! Makes you really wonder if they sell any doesn't it?
"nobody" wrote in message
Mike,
too expensive.
Ronnie
ink.net...
out
no
they
are useless.
Thanks,
Mike
Old August 16th 05, 09:49 PM
nobody
Hi Jim,
You nailed it. I do wonder how many are sold.
I found another future source of this, according to
their web site:
http://www.geronimomontana.com/apache.htm
Down a the bottom of the page, they mention 3 items
of interest in the coming-soon category: Ram's-horn
yokes at $1295 per pair, new engine and fuel gauges
(this sound very interesting), and dual brakes.
As a PA-23 owner, you might want to check this site out
if you've not already seen it.
Ronnie
"Jim Burns" wrote in message
Hey Ronnie,
$1200
Mike,
too expensive.
Ronnie
ink.net...
from
out
no
they
are useless.
Thanks,
Mike
Old August 16th 05, 10:54 PM
Jim Burns
Geronimo, as far as I know, is a pretty good outfit. I've talked to them on
the phone a couple times regarding heater upgrades. They've had that note
about the Coming-Soon Ram's horns on their site for quite a while though, so
I'm not holding my breath.
t...
Hi Jim,
their web site:
Ronnie
Hey Ronnie,
$1200
Mike,
too expensive.
Ronnie
ink.net...
from
changed
out
is
no
from
they
are useless.
Thanks,
Mike
Old August 12th 05, 09:38 PM
John Kunkel
ink.net...
are useless.
Since you asked for "confession", I'll speak up. Yes, I did demate the the
large shafts from the ram's horn yokes and install the yokes on my puny
early Cherokee shafts.
The pin that retains the shaft to the ram's horn yokes is driven from the
bottom into a blind hole. With a little precision measuring I determined the
location of the blind end of the pin and drilled a hole in the top of the
yoke which exposed the end of the pin to allow driving it out.
I have a lathe, so I whittled out a couple of fancy looking aircraft quality
aluminum bushings (dimensions long gone from memmory) to adapt the smaller
shafts and repinned them. The hole at the top of the yoke was filled with
plastic aluminum from a tube and sanded to match the contour. My powder
coater assured me that the plastic aluminum filler would survive high temps
of powder coating, there is only a slight, almost imperceptible dimple
caused by shrinkage showing through the powder coat.
Being an A&P, I simply made a log book entry using the Piper conversion kit
number (gasp) since I was pretty sure nobody had ever seen the real Piper
conversion yokes and so far nobody has said a word about it.
Old August 13th 05, 03:33 AM
Mike Spera
What did you use for new pins? Would it not be easier to tap the top and
use an AN bolt instead of a pin? I would not object to a hole at the top.
What does this "Piper conversion kit" do?
Thanks,
Mike
Old August 14th 05, 11:33 PM
John Kunkel
nk.net...
Heavy wall roll pins seemed like a more trouble free installation and don't
require any extra room for a head.
Piper offered a conversion kit to change the bow tie yokes to ram's horn, it
was horribly expensive and rarely available. Since I've never seen one I
have no idea how it's configured.
Thanks,
quality aluminum bushings (dimensions long gone from memmory) to adapt
the smaller shafts and repinned them. The hole at the top of the yoke was
filled with plastic aluminum from a tube and sanded to match the
contour. My powder coater assured me that the plastic aluminum filler
would survive high temps of powder coating, there is only a slight,
almost imperceptible dimple caused by shrinkage showing through the
powder coat.
kit number (gasp) since I was pretty sure nobody had ever seen the real
Piper conversion yokes and so far nobody has said a word about it.
Old August 13th 05, 03:08 PM
: Being an A&P, I simply made a log book entry using the Piper conversion kit
: number (gasp) since I was pretty sure nobody had ever seen the real Piper
: conversion yokes and so far nobody has said a word about it.
Couldn't you simply call this an "owner fabricated part?" Granted, there's a
lot of misinformation on this subject, but the A&P is ultimately responsible for
determining what an "equivalent" part is. IIRC there's no requirement to have
drawings, procedures, etc, etc to replace a factory part... just so long as it is
"equivalent."
Thoughts?
-Cory
* Cory Papenfuss *
* Electrical Engineering candidate Ph.D. graduate student *
Reamed out by Approach Bob Chilcoat Piloting 26 March 29th 05 01:32 AM
Naval Aviators jsmith Piloting 1 March 25th 04 03:56 PM
CH yoke and peddals? Tlewis95 Simulators 8 December 2nd 03 12:58 PM
CH Product Yoke with IP Trainer 6.5 Sanjay Kumar Instrument Flight Rules 2 October 10th 03 08:47 AM
Who do you call? Travis Marlatte Piloting 4 August 21st 03 09:16 AM
