I am working with 40 year old plans that call out AN365-6 Nuts.
Since they are used in conjunction with AN6 Bolts (24 of them) to attach the main spars together, I am assuming they are locknuts. Is the AN363-624 Metal Lock Nut a good match or good substitution? Gotta have something to hold 49 feet of wings together. Prue Super Circa 1963 Standard Class Sailplane. 15 meter all metal 35:1 L/D Clark |
![]() MS20365's are the same part. Why change. They are freely available at most suppliers. ALSO, Irv designed neat airplanes but unless you show somebody HOW the bolt is used, asking about substitutions on the net isn't where I'd get the answers. http://www.aircraft-spruce.com/catal...ages/an363.php Scott. wrote in message oups.com... I am working with 40 year old plans that call out AN365-6 Nuts. Since they are used in conjunction with AN6 Bolts (24 of them) to attach the main spars together, I am assuming they are locknuts. Is the AN363-624 Metal Lock Nut a good match or good substitution? Gotta have something to hold 49 feet of wings together. Prue Super Circa 1963 Standard Class Sailplane. 15 meter all metal 35:1 L/D Clark |
My Genuine Aircraft Hardware says that MS21044N is the replacement for both
obsolete # AN365 and MS20365. These are just Nylon insert, full profile hex nuts. -- Cy Galley - Chair, AirVenture Emergency Aircraft Repair A Service Project of Chapter 75 EAA Safety Programs Editor - TC EAA Sport Pilot "plasticguy" wrote in message ... MS20365's are the same part. Why change. They are freely available at most suppliers. ALSO, Irv designed neat airplanes but unless you show somebody HOW the bolt is used, asking about substitutions on the net isn't where I'd get the answers. http://www.aircraft-spruce.com/catal...ages/an363.php Scott. wrote in message oups.com... I am working with 40 year old plans that call out AN365-6 Nuts. Since they are used in conjunction with AN6 Bolts (24 of them) to attach the main spars together, I am assuming they are locknuts. Is the AN363-624 Metal Lock Nut a good match or good substitution? Gotta have something to hold 49 feet of wings together. Prue Super Circa 1963 Standard Class Sailplane. 15 meter all metal 35:1 L/D Clark |
![]() wrote in message oups.com... I am working with 40 year old plans that call out AN365-6 Nuts. Since they are used in conjunction with AN6 Bolts (24 of them) to attach the main spars together, I am assuming they are locknuts. Is the AN363-624 Metal Lock Nut a good match or good substitution? Yes ... AN363 are a suitable and cheaper alternative. The main difference is that they can be used in higher temperature applications because they don't have the nyloc insert (which I don't think it that important in a glider). Same strength though. Most engineers use metal-loc bolts in preference to Nyloc's these days. You could also use a MS21042 and a whole lot of other part numbers. See the interchangability chart on the MS21042 data sheet (get from STINET on the web). Of course you could also use the MS20365 as the direct replacement for the old AN365. Provided that the bolt is loaded in shear (and it sounds like they are the wing attach fitting bolts so I assume they will be) you have little to worry about with respect to the substitution. I have question for you on the Prue sailplane which is way off topic and I will take that up with you direct - hope you don't mind. Gotta have something to hold 49 feet of wings together. Prue Super Circa 1963 Standard Class Sailplane. 15 meter all metal 35:1 L/D Clark |
Unused plans question | Doc Font | Home Built | 0 | December 8th 04 09:16 PM |
Modifying Vision plans for retractable gear... | Chris | Home Built | 1 | February 27th 04 09:23 PM |
What do you do with you plans? | Bill A. | Home Built | 2 | January 22nd 04 11:48 PM |
Homebuilt plans F.S. | Aaavision51 | Home Built | 1 | November 10th 03 03:50 AM |
Here's a silly question regarding plans | David Hill | Home Built | 21 | October 8th 03 04:17 AM |
