Just saw a video on local (Houston) news of a Grumman C2 making a belly
landing on a paved runway at Norfolk, VA. Over 25 souls on board, everyone ok. The left fan was turning, the right one was feathered. Apparently the right engine failure prevented the gear from being extended. I would have figured the military a/c would have the ability to extend the gear inspite of an engine out. Anyone familiar with the systems on these birds, and wether the right engine is "critical" with regards to this function, or is there likely a double failure of some kind (powerplant AND hydraulics). Flaps were extended/down, but I am unsure if they were in full landing, or approach setting, nor am I sure of how they are actuated. Dave |
Most a/c have hydraulics on both engines PLUS a blowdown or bleed air
valve to provide emergency gear extension. |
In article et, Dave S wrote:
The left fan was turning, the right one was feathered. Apparently the right engine failure prevented the gear from being extended. I would have figured the military a/c would have the ability to extend the gear inspite of an engine out. Perhaps they were saving the starboard engine from a tear down inspection. |
inspection. The aircraft is a high wing twin. The props appear to clear the ground... and the left one continued to operate quite briskly until AFTER the landing. I think the Navy would hang someone from the yardarm (if they still have em) if someone stowed a perfectly good, taxpayer supplied turbine engine with 25 passengers.. Dave |
Dave S wrote:
I think the Navy would hang someone from the yardarm (if they still have em)..... Until the termites finish off the U.S.S. Constitution, the Navy will have quite a few yardarms. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
Could it be possible the one prop was turning and the other one was stopped
to help get rid of any excess speed? Just a thought. Patrick student SPL aircraft structural mech "George Patterson" wrote in message news:NwcMe.166$zb.14@trndny04... Dave S wrote: I think the Navy would hang someone from the yardarm (if they still have em)..... Until the termites finish off the U.S.S. Constitution, the Navy will have quite a few yardarms. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
![]() "W P Dixon" wrote Could it be possible the one prop was turning and the other one was stopped to help get rid of any excess speed? Just a thought. I doubt it. They would use close to normal speed, and plus, they con control speed all they want, with prop pitch. If anything, I'll bet they can adjust speed better, with both burning. -- Jim in NC |
A stopped/feathered prop has less drag than a windmilling prop, so if there
were any effect on speed it would be an increase, not a decrease. Bob Gardner "W P Dixon" wrote in message ... Could it be possible the one prop was turning and the other one was stopped to help get rid of any excess speed? Just a thought. Patrick student SPL aircraft structural mech "George Patterson" wrote in message news:NwcMe.166$zb.14@trndny04... Dave S wrote: I think the Navy would hang someone from the yardarm (if they still have em)..... Until the termites finish off the U.S.S. Constitution, the Navy will have quite a few yardarms. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
the right engine was secured for evacuation purposes. They did not want
anyone to run into a turning prop. Michelle Dave S wrote: Perhaps they were saving the starboard engine from a tear down inspection. The aircraft is a high wing twin. The props appear to clear the ground... and the left one continued to operate quite briskly until AFTER the landing. I think the Navy would hang someone from the yardarm (if they still have em) if someone stowed a perfectly good, taxpayer supplied turbine engine with 25 passengers.. Dave |
![]() "Michelle P" wrote the right engine was secured for evacuation purposes. They did not want anyone to run into a turning prop. That makes perfect sense. How did you find out, or is that just the answer that makes sense to you? -- Jim in NC |
A&P heroics | Jim | Piloting | 31 | July 18th 05 07:26 PM |
Judge halts work on Navy landing field in eastern N.C. | Otis Willie | Naval Aviation | 1 | April 21st 04 12:04 PM |
Cessna landing gear legs Reserve MET! | Bill Berle | Restoration | 0 | February 22nd 04 07:50 PM |
Landing gear door operation | Elliot Wilen | Military Aviation | 11 | July 8th 03 03:30 AM |
Landing gear door operation | Elliot Wilen | Naval Aviation | 11 | July 7th 03 03:47 PM |
