smoothing rough concrete hangar floor?
Old August 16th 05, 06:34 AM
Default smoothing rough concrete hangar floor?
We put in a concrete hangar floor and the finish is less than
desirable. There are patches where it's recessed (about 1/8"- 1/4"
recessed and rough) and then other areas where it's rough and proud
(about 1/8") with swirl marks.
Is there anything we can do to mechanically smooth this? Do they make
a big sander for concrete and how well does it work?
Is there anything we can do about the low spots or do we just knock off
the high spots and then not do anything about the low spots?
This is a new hangar floor (a couple months old) that hasn't had any
oils, etc on it yet.
We were hoping to level/smooth it pretty nice and then put some sort of
paint or sealer on it so that we could use a dust mop instead of a
broom . Recommendations on the best smooth sealer for the money
(knowing that it's a new floor and won't have oils, etc in it yet)?
Old August 16th 05, 09:13 AM
Roger
Some one must make the equivalent of a sander or grinder for the rough
surface but I've never seen one.
I have four coats of the two part epoxy garage floor coating sold by
Lowe's on all but one end of the shop which has three coats with the
top coat sanded. The four coats are like a mirror.. It's a name brand
but I've forgotten which. I still have two gallons some where out in
the shop so I could look it up.
Even for a new, clean floor you acid etch and wash the concrete.
A power washer is nice for that.
You mix it, let it set for a few minutes and then roll it on with a
paint roller. The solvents are nasty and flammable (more like ether
fumes). I'd suggest a full hood breathing apparatus.
The stuff works great. Fills well and is durable.
www.rogerhalstead.com
Old August 16th 05, 11:48 AM
Scott
How slippery is the stuff when wet?
Old August 17th 05, 08:36 AM
Roger
On Tue, 16 Aug 2005 10:48:35 +0000, Scott
Slippery? evil grin
Sawdust or wet? Kinda like snot on a door knob.
I went over it with an industrial orbital sander where I bring in the
equipment. That gave a dull finish and one where you won't bust you
butt trying to walk. The shiny part was more like going out onto the
ice with your skate guards still on.
The rest was like a freshly waxed floor for about the first year. Now
I don't notice any difference between the two areas except the finish.
Old August 17th 05, 11:42 AM
Lou
You can buy a product commonly known as floor leveler. Mixed right it
will do just what your asking, fill in all the valleys up to the
highest point provided the highest point isn't more than 3/4". Get
yourself a set of knee pads and a finishing trowel and do small areas
at a time. Home Depot selles it, I don't know about lowes since I've
only been in 2 of them and found they have the dumbest employees.
You can also hire a concrete company to do this but I'm going to guess
that how the floor ended up the way it did. You can go the epoxy way
but I'll bet you spend almost as much on that as the floor itself.
Lou
Old August 16th 05, 07:45 PM
On Tue, 16 Aug 2005 04:13:43 -0400, Roger
There is. It's called a Terrazo grinder. Or is it terazzo.No, it's
Terrazzo. Anyway - it does exist. Terco and Oztec are two names.
Check local concrete and flooring contractors - most of the good ones
around here are either Italian or Portugese.
Old August 16th 05, 12:16 PM
GeorgeB
There is a standard process, terrazzo, which accomplishes the lowering
of high spots. There are ADVERTISED "thinset" products to fill in the
low spots. Contact some of oyur local concrete folks and ask them.
Quite a few finishes are available for concrete whihc will give a
smooth, oil and tire resistant finish. Again, ask the local concrete
guy for recommendations. Lowes and The Home Depot both have several.
Some work much better than others, I understand.
IMO, someone incorrectly specified the final finishon the concrete; it
could have easily been finished "real slick" (that's a technical term
for slicker than snot on a doorknobg) rather than "broom finish"
which you apparently got. BTW, broom finsih IS a real term, and is
common when it might get wet so one walking doesn't fall on his
backside.
The Auction Hangar - Completely free aviation auction site. The Auction Hangar Instrument Flight Rules 10 April 19th 04 12:37 AM
The Auction Hangar - Completely free aviation auction site. The Auction Hangar General Aviation 1 April 6th 04 07:17 AM
The Auction Hangar - Completely free aviation auction site. The Auction Hangar Home Built 0 April 6th 04 12:57 AM
The Auction Hangar - Completely free aviation auction site. The Auction Hangar Home Built 0 April 6th 04 12:56 AM
Rules on what can be in a hangar Brett Justus Owning 13 February 27th 04 05:35 PM
