Boeing's Electric Taxi Motor
Old August 17th 05, 02:30 AM
Larry Dighera
Default Boeing's Electric Taxi Motor
BOEING CO. has tested an electric motor that could allow
commercial jets to taxi around airports without using their
engines or ground-based towing vehicles, the company said.
Boeing said its Phantom Works unit had used the nose-wheel
motor, built by Chorus Motors Plc, to move around an Air Canada
Boeing 767 jet in tests simulating various runway conditions in
June. The system could offer a glimmer of hope to U.S.
airlines, which have been scouring for ways to boost economies
amid record fuel prices, by directing pilots to taxi with
single engines, among other steps. It was unclear how soon the
motor would be ready or how much it would cost. Boeing said the
companies are working to overcome various technical issues that
had surfaced during the tests. The motors could save airlines
money by eliminating the use of airport tow tugs and boost
efficiency by running their jets less, as well as reduce
emissions, the companies said.
(Reuters 11:44 AM ET 08/01/2005)
Mo
http://q1.schwab.com/s/r?l=248&a=111...a&s=rb050 801
Old August 17th 05, 04:02 AM
Ben Hallert
So... do you still log the taxi time as PIC? : )
Ben Hallert
PP-ASEL
Old August 17th 05, 05:01 AM
Jose
Sure. There are no regs on what is supposed to be powering the
aircraft.
What I wonder is which weighs more - the fuel that would have been used,
or the motor that the airplane has to carry around for the whole flight.
Jose
Quantum Mechanics is like this: God =does= play dice with the universe,
except there's no God, and there's no dice. And maybe there's no universe.
Old August 17th 05, 05:35 AM
Peter Duniho
"Jose" wrote in message
t...
Doesn't really matter. The weights are probably comparable (and the fuel
may well weigh more), but more important is that the airline has to keep
buying the substance that makes up the weight of the fuel (that is, the fuel
itself), while they can buy the electric motor once (or some very small
number of times over the lifetime of the airframe).
Unless the electric motor were vastly heavier than the fuel (and that seems
unlikely), this seems like a pretty good idea to me. It wasn't clear at all
from the press release what the nature of the motor would be. Is it a
permanent installation, or is it attached to the airplane only while at the
airport? Does it have an internal battery, or does it run off of some kind
of external power source (like the airplane's APU).
I don't think the answers are all that critical to the success of the
device, but they are things I wonder about. Ironically, the link Larry
labeled as "More" simply repeats the exact text he posted. Duh. I guess
"More" just means "more formatted and other extraneous crap".
Pete
Old August 17th 05, 06:25 AM
Happy Dog
"Peter Duniho"
fuel itself), while they can buy the electric motor once (or some very
small number of times over the lifetime of the airframe).
seems unlikely), this seems like a pretty good idea to me. It wasn't
clear at all from the press release what the nature of the motor would be.
Is it a permanent installation, or is it attached to the airplane only
while at the airport? Does it have an internal battery, or does it run
off of some kind of external power source (like the airplane's APU).
How many kilowatts does a passenger jet consume to run all the other stuff
that must be powered whilst taxiing? A/C, lighting, avionics etc.
Batteries seem an unlikely solution for all that. Additional batteries plus
the power from an idling engine? Third rail?
moo
Old August 17th 05, 09:01 AM
Bucky
Yeah, I agree. Maybe the engines drive an alternator, which powers the
electric motor.
Peter Duniho
"Happy Dog" wrote in message
plus the power from an idling engine? Third rail?
IMHO, the most likely solution is to simply run it off the APU. Or maybe
just the regular generator on the engine (which can probably produce enough
power with the engine at idle, which is still a savings over taxiing with
all but one engine shut down). Someone at Boeing was probably driving their
Prius to work and had an epiphany.
My point was simply that the press release is incredibly vague; we really
have no idea *what* this device is, how it works, or how practical it will
be. I suspect it will turn out to be a good idea, but it's hard to know
without any actual information.
Pete
Old August 17th 05, 03:14 PM
Eduardo K.
APU.
Eduardo K. | Some say it's forgive and forget.
http://www.carfun.cl | I say forget about forgiving just accept.
http://e.nn.cl | And get the hell out of town.
| Minnie Driver, Grosse Point Blank
Old August 17th 05, 03:40 PM
N93332
Just brainstorming so this may be a completely wrong idea.
If these electric motors are more effecient than running the engines on the
jets for taxi purposes and will save the airlines 'considerable' fuel costs
for the taxi operations, do the electric motors need to be 'installed' on
the jets? How about using these efficient electric motors on the tugs, use
the tugs to push/pull the jet from the gate all the way to the hold short
line while the jet is just idling. Then have the electric tugs 'race' down a
taxiway to take the arrivals back to a gate. This would mean more tugs and
personnel to drive them.
Just an (dumb?) idea....
Old August 17th 05, 04:17 PM
Garner Miller
I'm quite sure the device will be powered by the APU, which will
produce electricity and air conditioning for all the equipment, and the
pressurized air needed to start the engines later.
An idling jet engine uses a TON of fuel and makes quite a bit of
thrust; aside from initially getting the plane moving, taxiing is
normally done at idle thrust anyway. But it's that high idle fuel
consumption that this will eliminate for the taxi-out, and I think it's
a terrific idea.
Just to throw some numbers out, an older 737's engine (I don't have
specs in front of me for the newer ones) burns about 1200 pounds of
fuel per hour, per engine, at idle.. The APU burns about 300 pounds
per hour. A savings of 900 pounds, or about 135 gallons of fuel per
hour over a single-engine taxi. (315 gallons less than a more-common
two-engine taxi!)
Jet fuel's costing the airlines upwards of $1.75 a gallon. For every
minute the airplane could taxi using only the APU instead of one
engine, an airline would save about $4. A typical 15-minute taxi-out
at a semi-busy airport would save $60. An hour-long taxi on a bad
weather day? $240.
Obviously the economics will be different for each airplane type, and
for some airlines like Southwest that don't normally fly into
delay-prone airports, it might not make financial sense to install this
device.
But an airline that flies to LaGuardia, Chicago O'Hare, Atlanta, etc.,
all day long? It could save a ton of money if they can make it work.
Garner R. Miller
ATP/CFII/MEI
Clifton Park, NY =USA=
Is a Turn Coordinator an electric motor or powered by fan? kickinwing Piloting 5 June 11th 05 01:25 PM
Cherokee Electric Pitch Trim Jonathan Goodish Owning 4 November 18th 04 03:43 AM
Piper Arrow electric fuel-pump MC General Aviation 7 June 3rd 04 03:50 AM
taxi in reverse? Malcolm Teas Home Built 10 February 21st 04 01:26 AM
More on the electric verses turbojet cdubya Soaring 8 September 25th 03 10:16 AM
