turbine in microturbine generator for aircraft?
Old December 19th 04, 05:58 PM
Shin Gou
Default turbine in microturbine generator for aircraft?
I googled, but there's not much infor. about converting the turbine in
the microturbine generator for aircraft use. So I am tossing my idea
here. The Capstone's microturbine generator looks very neat. The
generator has 60kw output, and the turbine itself should have higher
output, enough for a two-seater and it's light,very light.
http://www.capstoneturbine.com/
So how do you think about the idea?
Thank you.
Shin
Old December 19th 04, 06:08 PM
Larry
"Shin Gou" wrote in message
Thank you.
Shin
A pretty feeble attempt at SPAM.
You really don't want to know.
Larry
Old December 19th 04, 07:00 PM
Dave Hyde
Shin Gou wrote...
Probably for good reason - it sure doesn't look like it's
suitable for airplane propulsion without *significant*
modifications. Electrical power? Maybe, but it's got a long
way to go before I replace my ND alternator ($100 a pop).
enough [power output] for a two-seater...
A two-seater *what*? The thing doesn't even appear to
have a PTO shaft or provisions for one and the exhaust
outlet is completely unsuitable for thrust. Other than
that I suppose it's OK.
Dave 'all thrust, no vector' Hyde
Old December 19th 04, 07:15 PM
Shin Gou
Thanks for the input. I see. So seems the microturbine used in
generators have inherent problems to be converted to use on aircraft.
Thank you.
Old December 20th 04, 03:24 PM
Stealth Pilot
Thank you.
the thing that kills these as an idea is the fuel consumption.
a continental O-200 burns about 20 litres per hour.
a jabiru 2200 burns about 13 litres per hour.
the small fadec turbine that aeromodellers use burns about 60 litres
per hour for just 15lbs thrust.
afaik the KR2 powered by a turbine was built wet everywhere (fuel
tanks placed everywhere) and had an endurance of just 18 minutes.
not a practical idea without some serious reengineering.
Stealth (pistons!) Pilot
Old December 20th 04, 10:53 AM
John
Thank you.
I guess my math is wrong they spec 350ml per minute for the 30lb thrust unit
which works out to 21 litres and hour. Sounds a bit fishy but who knows.
5.5 gal/hour for 30lbs thrust, maybe!
John
Old December 21st 04, 03:36 AM
Juan Jimenez
"John" wrote in message
Thank you.
unit
John
If that works out to 1.1 lb/lbf/hr sfc that does sound a bit fishy. Kinda
low for one of these little screamers, IMO. I talked to Bob Carlton a couple
of weeks ago, he does the Silent Wings air show act with the two AMT engines
on the Silent motorglider. _Very_ cool stuff. He's got two 45 lbf AMT-USA's
and he's burning 20 gals/hr total (both engines) at 100% N1.
Old December 20th 04, 09:10 AM
John Kimmel
Those "air bearings" probably work well on a stationary generator, but
I'll bet they bottom out with any bumps or gyro forces. Speaking of
micro turbines, I read an article somewhere about a new gas turbine
being developed to power cell phones. There may yet be a future for
affordable gas turbine powerplants for aircraft--how long before someone
comes up with a gas turbine electric hybrid car?
Thank you.
Shin
John Kimmel
GET YER STINKING PAWS OFF ME YOU DAMN DIRTY APE!
Old December 20th 04, 11:27 AM
Vaughn
"John Kimmel" wrote in message
Never say never, but... I don't expect to see it in my lifetime. Small
turbines have bad fuel specifics. In stationary use, things improve greatly if
you can find a use for the waste heat. In the case of airplanes, turbines have
size and weight advantages that help to offset their thirstiness. Cars are a
whole 'nuther matter.
Vaughn
Old December 23rd 04, 06:53 AM
Slip'er
Don't tell this to Chrysler. They started experimenting with turbine cars
in the 1950s and were getting descent gas mileage. (At least better than my
1977 Trans Am.) Anyway, we won't be seeing them any time soon but, it would
be neat.
http://www.aardvark.co.nz/pjet/chrysler.shtml
Small
greatly if
have
are a
Alternate turbine fuel Robert Bates Home Built 24 June 7th 04 07:16 AM
turbine propeller sebastian Home Built 19 March 21st 04 12:47 AM
Pulsar with a turbine? Badwater Bill Home Built 33 August 28th 03 04:02 PM
