Here's some news that recently came out:
http://www.newscientist.com/article.ns?id=dn7867 http://abc.net.au/science/news/stories/s1439827.htm Apparently, soundwaves can help airflow stay near the wing and increase lift. This can help smaller aircraft to avoid stalling at lower airspeeds. Is this a technology that could be usefully applied to existing small aircraft? Or would it require some totally new design thinking? |
![]() " wrote in message ups.com | Here's some news that recently came out: | | http://www.newscientist.com/article.ns?id=dn7867 | | http://abc.net.au/science/news/stories/s1439827.htm | | Apparently, soundwaves can help airflow stay near the wing and | increase lift. This can help smaller aircraft to avoid stalling at | lower airspeeds. Is this a technology that could be usefully applied | to existing small aircraft? Or would it require some totally new | design thinking? It would also require heavy metal music. Well _somebody_ had to say it. -- Cheers Dave Kearton |
I was thinking perhaps at least drones could benefit from this
technology, since they tend to be smaller and might have to travel at lower speed to do ground surveillance. Hmm, or what about at least toy RC hobby aircraft? Comments? |
Charlie Springer wrote:
On Sat, 20 Aug 2005 16:31:43 -0700, wrote (in article . com): Here's some news that recently came out: http://www.newscientist.com/article.ns?id=dn7867 http://abc.net.au/science/news/stories/s1439827.htm Apparently, soundwaves can help airflow stay near the wing and increase lift. This can help smaller aircraft to avoid stalling at lower airspeeds. Is this a technology that could be usefully applied to existing small aircraft? Or would it require some totally new design thinking? I have some of the piezo polymer film they were probably using (from SONAR experiments, and a steel plate target that tells you where the bullet hit). The amplitudes would be very small, but covering a wing on an RV or Bonanza would be less than five pounds in weight, including the high voltage electrics needed for the piezoelectric material. But New Scientist is not the most reputable source (called New Age Scientist by some, ignored by the rest) and I would have to see this confirmed by another lab. It smells a lot like the kind of signal that screws up your instrumentation. The drive for the film is likely 800 to 1,200 volts and at 400 Hz running on a little model in a wind tunnel with sensitive detectors of various sorts. I'll just say I'm skeptical. -- Charlie Springer No need to be skeptical on this on Charlie. The technique will work. Unfortunately, the five pounds of high-maintainence, active equipment can be replaced with a few ounzes of turbulator strips. I read one of the NASA reports, done YEARS ago, on the Larc website. They used the same techique, using sound waves to re-energize the boundary layer. Pointless was their conclusion if I remember correctly. -- This is by far the hardest lesson about freedom. It goes against instinct, and morality, to just sit back and watch people make mistakes. We want to help them, which means control them and their decisions, but in doing so we actually hurt them (and ourselves)." |
Ernest Christley wrote: Charlie Springer wrote: On Sat, 20 Aug 2005 16:31:43 -0700, wrote (in article . com): Here's some news that recently came out: http://www.newscientist.com/article.ns?id=dn7867 http://abc.net.au/science/news/stories/s1439827.htm Apparently, soundwaves can help airflow stay near the wing and increase lift. This can help smaller aircraft to avoid stalling at lower airspeeds. Is this a technology that could be usefully applied to existing small aircraft? Or would it require some totally new design thinking? I'll just say I'm skeptical. No need to be skeptical on this on Charlie. The technique will work. Unfortunately, the five pounds of high-maintainence, active equipment can be replaced with a few ounzes of turbulator strips. I read one of the NASA reports, done YEARS ago, on the Larc website. They used the same techique, using sound waves to re-energize the boundary layer. Pointless was their conclusion if I remember correctly. Kinda makes you wonder if they used a particular kind of "noisy" sound wave, or simple shapes like sine waves. It'd be really funny if it turned out to work with random or less-patterned noise, and they missed it because they were too organized... -- I don't have a lifestyle. I have a lifeCSS. |
On Sun, 21 Aug 2005 19:22:47 -0700, Chad Irby wrote
(in article ): Kinda makes you wonder if they used a particular kind of "noisy" sound wave, or simple shapes like sine waves. It'd be really funny if it turned out to work with random or less-patterned noise, and they missed it because they were too organized... One would be tempted to think this, but all noise (including triangle and square waves) can be constructed from a sum of sines and cosines. It is called Fourier's Theorem, and it works so well nearly all digital signal processing is based on it to some extent. Note that the researcher's 400 Hz signal (close to the A flat above middle C) could form some pretty irritating beats with the engine/propeller. Concert A is 440 and I suspect anybody who has worked with military aviation is familiar with the sound of the 400 Hz power systems. -- Charlie Springer |
In article l.net,
Charlie Springer wrote: On Sun, 21 Aug 2005 19:22:47 -0700, Chad Irby wrote (in article ): Kinda makes you wonder if they used a particular kind of "noisy" sound wave, or simple shapes like sine waves. It'd be really funny if it turned out to work with random or less-patterned noise, and they missed it because they were too organized... One would be tempted to think this, but all noise (including triangle and square waves) can be constructed from a sum of sines and cosines. Technically, yes, but there could be too many situations where "simple" noise has nothing like the same effect "complex" noise does. Considering that the airflow across the wings of small aircraft is generally subsonic, simple versus complex waveforms could make a real difference (for the generation or prevention of standing waves?). -- I don't have a lifestyle. I have a lifeCSS. |
In article . com,
" wrote: Here's some news that recently came out: http://www.newscientist.com/article.ns?id=dn7867 http://abc.net.au/science/news/stories/s1439827.htm Apparently, soundwaves can help airflow stay near the wing and increase lift. This can help smaller aircraft to avoid stalling at lower airspeeds. Is this a technology that could be usefully applied to existing small aircraft? Or would it require some totally new design thinking? Here's a quote from the article in New Scientist (first reference above): "In wind tunnel tests, Salmon stuck sections of plastic piezo-electric film to wing segments. This film vibrates when an electrical signal is applied, producing sound." This sure sounds (no pun intended) like aftermarket stuff to me. It might find its way into production eventually, but it sounds like you could go stick some tweeters on your Cessna tomorrow and start landing at 35 knots. That'd raise a few eyebrows among the line judges. Of course, the best way to avoid stalls is to learn how to fly. No technology in the world is going to render pilot error obsolete. OK, I'll make one concession, for wind shear on final. It would be nice to stay airborne when dropping through the bottom of a 20 knot headwind layer. |
Well, could this technology be used to augment the performance of
canards? We know that aerobody designs that are optimized for high-speed supersonic flight may unfortunately not be so efficient for low-speed flight around takeoff and landing. Could this sonic lift technology be used instead of canards, or maybe to boost the lift from canards? Then maybe you could have smaller canards at least, although I'm not sure liability canards pose to begin with. Also I don't know what you'd do in the event of an unpowered landing. I was also thinking about how stubby-winged re-entry vehicles like the old X-15 or even the new SpaceshipOne might benefit from that 20% increased lift. What about using this technology for something more exotic, like a martian aeroplane? With the thinner atmosphere producing less lift, perhaps this sonic boost might make a crucial difference. |
Who does flight plans? | Michael 182 | Piloting | 158 | July 4th 05 02:50 AM |
Lift Query | Avril Poisson | General Aviation | 8 | April 21st 05 07:50 PM |
Tamed by the Tailwheel | [email protected] | Piloting | 84 | January 18th 05 04:08 PM |
A Level 1 AOA clarification | Ramapriya | Piloting | 64 | January 9th 05 01:19 AM |
Props and Wing Warping... was soaring vs. flaping | Wright1902Glider | Home Built | 0 | September 29th 03 03:40 PM |
