I have a friend who has a 1978 Cessna 310Q. (At least I think he told
me it was a 1978 model). Here is the question: He wants to plug in some electrical equipment, a computer and a GPS unit into the cigar lighter plug. The aircraft has a 24 volt electrical system. He has been told that the cigar lighter voltage has been dropped to 12 volts because there is a large resistor in the wire that feeds power to the cigar lighter. When he checks the voltage at the contacts of the lighter receptacle, he finds 24 volts. We think that this is because there is no load on the circuit, and if there was, the voltage would drop due to the inline resister. However, he reports that when he tries to run both devices from the power from the cigar lighter, it does not seem to work. Any ideas on what to do in his case would be appreciated. Thanks. Zenith CH-300 Driver. |
Tim Hickey wrote:
I have a friend who has a 1978 Cessna 310Q. (At least I think he told me it was a 1978 model). Here is the question: He wants to plug in some electrical equipment, a computer and a GPS unit into the cigar lighter plug. The aircraft has a 24 volt electrical system. He has been told that the cigar lighter voltage has been dropped to 12 volts because there is a large resistor in the wire that feeds power to the cigar lighter. When he checks the voltage at the contacts of the lighter receptacle, he finds 24 volts. We think that this is because there is no load on the circuit, and if there was, the voltage would drop due to the inline resister. However, he reports that when he tries to run both devices from the power from the cigar lighter, it does not seem to work. Any ideas on what to do in his case would be appreciated. Thanks. Zenith CH-300 Driver. Look at ebay under avionics for a dc-dc converter. I have seen quite a few 24 VDC - 12 VDC converters. It would be nice to find one that goes the other way. I have been looking for one. Dan, U.S. Air force, retired |
Use an LM340T12 (or LM7812C-V) voltage regulator. On the spec sheet you
will find the diode, and 2 capacitor sized need to ensure it's clean. Something like this (see diagram in Courier font) diode ------|-------- | | | XXXXX | | 7812C | | XXXXX | _in_24V_| | |___12V___out_ | | | 0.33uF | 0.1uF | | | _|______|_____|___ | earth Rgds, Brett "Tim Hickey" wrote in message ... I have a friend who has a 1978 Cessna 310Q. (At least I think he told me it was a 1978 model). Here is the question: He wants to plug in some electrical equipment, a computer and a GPS unit into the cigar lighter plug. The aircraft has a 24 volt electrical system. He has been told that the cigar lighter voltage has been dropped to 12 volts because there is a large resistor in the wire that feeds power to the cigar lighter. When he checks the voltage at the contacts of the lighter receptacle, he finds 24 volts. We think that this is because there is no load on the circuit, and if there was, the voltage would drop due to the inline resister. However, he reports that when he tries to run both devices from the power from the cigar lighter, it does not seem to work. Any ideas on what to do in his case would be appreciated. Thanks. Zenith CH-300 Driver. |
1/72 Cessna 300, 400 series scale models | Ale | Owning | 3 | October 22nd 13 03:40 PM |
Wow - heard on the air... (long) | Nathan Young | Piloting | 68 | July 25th 05 06:51 PM |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Aviation Marketplace | 1 | November 4th 03 12:57 AM |
FORSALE: HARD TO FIND CESSNA PARTS! | Enea Grande | Products | 1 | November 4th 03 12:57 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
