Metric Instruments
Old August 24th 05, 05:48 PM
Roy Bourgeois
Default Metric Instruments
This may be a silly question - but are all metric altimeters
configured with 'Zero at 6 O'clock' as I saw in France?
I did not have trouble converting to meters/kilometers
but I did have trouble quickly reading the altimeter
with the zero at the bottom of the instrument face
(especially on the little 57mm instruments). Just
curious.
Roy
Old August 24th 05, 07:25 PM
Bill Daniels
Does it strike some of the digerati here that expensive mechanical
altimeters with easily mis-read clock-like hands locked into either the
metric or US measurement systems are archaic?
GPS provides highly accurate, although not ATC compliant, altitude. Various
vendors provide electronic pressure altimeters with digital displays that
can be switched between meters and feet with the push of a button. Digital
pressure altitude sensors drive the "glass cockpits" of new GA aircraft.
I seems to me that clock-like altimeters designed 70 years ago and
maintained by watchmakers must be nearing their well-deserved retirement.
Bill Daniels
"Bert Willing" wrote in
message ...
Yes, they are.
Bert Willing
ASW20 "TW"
"Roy Bourgeois" a écrit dans le message
de
news: ...
curious.
Roy
Old August 24th 05, 08:07 PM
Stefan
No, it doesn't. Most probably because the are not archaic, but still
much superior to digital displays, ergonomic wise. Besides, I really
appreciated their purely mechanic design when my battery died in flight.
Stefan
Old August 24th 05, 09:47 PM
Malcolm Austin
I believe there was some research some years ago, on a similar vein.
The fact seemed to be we "read" clocks almost without thinking. Just the
position of the hands "tells us" what the time is (think of 15 mins to 3
o'clock)
Maybe the altimeter view works the same, which would also make it more
difficult
to adjust to, when it isn't mounted to fit our usual expectations.
(also makes me question the way electrical switches are down for off and up
for
on, in opposition to domestic reality, then we go to hand throttle's!)
Malcolm...
"Bill Daniels" wrote in message
Various
Digital
Bill Daniels
message ...
Yes, they are.
Bert Willing
ASW20 "TW"
de
news: ...
curious.
Roy
Old August 24th 05, 09:52 PM
Andreas Maurer
On Wed, 24 Aug 2005 11:25:51 -0600, "Bill Daniels"
How many times have you praised yourself for having instruments on
board that do not need electricity to work properly?
I did that dozens of times - electricity is definitely not a reliable
thing in gliders.
Bye
Andreas
Old August 24th 05, 11:17 PM
Bill Daniels
"Andreas Maurer" wrote in message
thing in gliders.
Bye
Andreas
This amazes me. Electricity not reliable? I know this is "conventional
wisdom" but, I have never had an electronic device fail in flight but many,
many mechanical instruments have failed me. In fact, even when an
electronic device seemed to fail, it was always a mechanical switch or
battery contact that failed and not the device itself. (Hint: Use the best
electrical hardware money can buy.)
I sit here typing on an incredibly complex device called a Personal
Computer. The CPU alone has over 10 million transistors in it. If the PC
ever fails, the reason will almost certainly be the mechanical hard drive.
If the power grid fails to provide electricity, the UPS will keep it running
long enough for a graceful shutdown.
In just the last month, we have had a mechanical altimeter fail. The only
way we knew was that it couldn't be set to local field elevation. We had an
airspeed indicator fail to work at all. I had mechanical altimeter suddenly
lose 2000 feet as it became unstuck. The Winter mechanical vario in one
glider spends most of the time stuck at +10 Kts. so we rely on the only
reliable one - the Cambridge L-Nav. (If I ask, "Why the mechanical vario",
I hear, "For backup".) Mechanical instruments are neither rugged nor
reliable.
Mike Borgelt makes an excellent case for using his B40 with it's internal 9V
battery as a backup. Unlike the Winter, it has audio even while running on
the internal battery.
As for readability, I don't think you will find a "three hand" altimeter in
an airliner anymore. They have had drum-type digital displays since
sometime in the 1960's. Many studies have shown the digital readout is
harder to mis-read. Although, today these are likely to be just the back-up
to the digital "glass cockpit".
Bill Daniels
Old August 24th 05, 11:35 PM
Stefan
I had the battery fail twice on me: During my first 300km flight and
during my second 300km flight. Which meant that I had done two
successful 300km flights without GPS and acoustic vario, but none of
them was logged. :-P
Stefan
Old August 24th 05, 11:49 PM
Raphael Warshaw
I'll second the use of the B40 as a backup. I don't have a mechanical vario
at all. As a precaution, I change the B40 internal battery on the same
schedule as the one on the MH Oxygen system, wasteful perhaps, but
reassuring.
Ray Warshaw
1LK
thing in gliders.
Bye
Andreas
many,
best
running
an
suddenly
vario",
reliable.
9V
on
in
back-up
Bill Daniels
Old August 25th 05, 02:33 AM
Andreas Maurer
On Wed, 24 Aug 2005 15:17:23 -0600, "Bill Daniels"
Glad that you never had a problem.
I have lost count of the numbers where my clubs glider's batteries
were forgotten to charge after flight or ran out of energy because
they had reached their service life...
Not to mention more than a couple of GPS failures over the years...
Of course - there have been more than a couple of mechanical (Winter)
altimeter failures, too - but at least the altimeter didn't stop
working at all but only lost precision.
It's pretty impossible to convince me of the superiority of something
that needs to be charged as long as more than one owner is involved.
This includes a backup battery. vbg
Bye
Andreas
Metric measuring tool source? DL152279546231 Home Built 12 April 29th 04 03:13 AM
Reverse Vacuum Damging to Instruments? O. Sami Saydjari Owning 8 February 16th 04 05:00 AM
metric system newsgroup call for votes #1 Paul Hirose Military Aviation 72 November 16th 03 07:59 PM
Edwards air show B-1 speed record attempt Paul Hirose Military Aviation 146 November 3rd 03 06:18 PM
Wanted - Metric Altimeters RHWOODY Soaring 0 September 13th 03 11:20 PM
