Greek plane crash questions
Old August 24th 05, 11:19 PM
Jose
Default Greek plane crash questions
The useful consciousness time as it reaches its high-altitude minimum is mostly the transit time of the already oxygenated blood that just left your lungs on the way to the brain at the "moment" of pressure loss--when that low oxygen blood gets there, your conscious brain cells, which have some of the most rapid replenishment rates of any tissue in the body, go to sleep almost immediately.
Ok, so why don't I collapse right away after taking a breath of helium
to talk like Donald Duck?
And...btw... this is a perfect example of why I trim newsgroups. I
originally sent this as a "reply", as I was told to do by people here
who have some issue with my trimming groups and/or indicating which ones
I follow.
My newsreader is dumb.
The reply went =only= to alt.disasters.aviation, where I will never see
a reply and will probably be accused of hit and run posting, an
accusation I will also never see. Followups had been set to that group,
and I didn't catch that. I don't follow that group. But discussion
seems to be happening here too.
So now I'm replying manually here only, so that if there is a reply,
I'll actually see it.
Jose
p.s. My newsreader is dumb.
Quantum Mechanics is like this: God =does= play dice with the universe,
except there's no God, and there's no dice. And maybe there's no universe.
Old August 24th 05, 11:59 PM
Bushleague
Actually it is referred to as oxygen partial pressure. With time of
usefull conciousness at FL350 less than 90 seconds, the PIC
(whether the pilot flying or not) usually donns his mask first,
switches the mixer box from boom to mask in order to establish
communications, regains control of the aircraft, then instructs the
F/O to do the same.
Part of Rome was built in a day.
Bush
Old August 25th 05, 03:21 AM
George Patterson
Because at anything close to sea level, the oxygen that is already in your
bloodstream stays there. At altitude, it comes out of your bloodstream. At
altitude, none of the blood leaving the lungs contains enough oxygen to do you
any good. When you take a breath of helium, there won't be any transfer of
oxygen into the bloodstream from that breath, but there is still oxygen left in
that portion of the blood from the last time it passed through the lungs.
George Patterson
Give a person a fish and you feed him for a day; teach a person to
use the Internet and he won't bother you for weeks.
Old August 25th 05, 03:49 AM
Jose
When you take a breath of helium, there won't be any transfer of oxygen into the bloodstream from that breath, but there is still oxygen left in that portion of the blood from the last time it passed through the lungs.
There was an earlier message concerning somebody breathing nitrogen by
accident (I presume at sea level) and going into immediate convulsions.
Why nitrogen and not helium?
Jose
Old August 25th 05, 04:17 AM
George Patterson
Dunno.
George Patterson
Old August 25th 05, 10:32 AM
Stefan
Nobody said immediate.
The point is you can't entirely empty you lungs by just exhaling, the
human body just isn't built for this. So there's still oxygen in the
lungs even when you take one or two breathes of pure helium (or
nitrogen, for that matter). If however you continue to breathe pure
helium, you will loose consisiousness pretty quickly.
If the environmental pressure falls, this is an entirely different
situation.
Stefan
Old August 25th 05, 03:26 PM
Dave
Isn't our atmosphere made up of 70% nitrogen?
"Jose" wrote in message
Jose
universe.
Old August 25th 05, 05:25 PM
Ron Lee
Closer to 78 %. But why quibble over 8-9%
Ron Lee
My first aerobatic lesson Marco Rispoli Piloting 6 April 13th 05 02:21 PM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 November 1st 03 06:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 August 1st 03 07:27 AM
