Ideal Display Size Survey
Old August 25th 05, 08:13 PM
john smith
Default Ideal Display Size Survey
This survey is a follow-up to Jay's 396 thread.
As Jay pointed out, the display is too small to adequately present all
the information available in a useful format.
So the question is:
"What is the minimum useful display size adequate for a portable GPS
with the features found in the Garmin 396?"
(Please state you answer in L x W or diagonal dimension and comparison
to any present panel mount displays.)
Old August 25th 05, 09:13 PM
Dan Luke
As Jay pointed out, the display is too small to adequately present all the
No, it isn't. I'm looking at one right now; it is adequate.
So the question is:
"What is the minimum useful display size adequate for a portable GPS with
I'd like to see the 396 display 1" larger, W & L.
Dan
C-172RG at BFM
Old August 26th 05, 12:24 AM
Morgans
5" x 7"
Jay Honeck
Well, I've got the two biggest portable color GPS screens around in my
plane, with the AvMap on one yoke, and the 2000c on the other.
The AvMap, with its huge screen (over twice the size of a 396) would make an
unbelievably marvelous platform for weather -- and AvMap knows it. I spoke
at length with their reps at OSH, and they were EXTREMELY frustrated that
Garmin had beaten them to the XM weather thing. They had been working on it
for a few years (according to Vern, their head cheese), but the
muckity-mucks upstairs had cut the program off to devote more $$$ to their
marine market -- a segment where they make vastly more $$$ than our puny
little aviation market can provide. (Now, of course, boaters need weather,
too -- but apparently aren't as willing to pay for it.)
The Lowrance unit would be second best, and is about the size that Dan is
advocating (an inch bigger than the current 396) -- but more square-ish. I
don't like the screen resolution of the 2000c as well as the AvMap (it's
about the same as the 396s) -- but it would be okay.
One crucial change that must be made is to put the units in portrait mode,
like the AvMap and (sorta) the 2000c. I want my track "up", which means my
route of flight is "up" -- which means the maximum distance out will be at
the TOP of the screen. On the 396, that's the "short direction" (due to
its landscape-only mode), and (as a result) the weather gets cut off --
nearly in half.
In this, size really matters. To be able to adequately depict your entire
route of flight, in a size that can easily be seen, in a resolution that
allows for great detail, will be the ultimate "Holy Grail" of in-flight
weather depiction As with all first-generation electronics, the Garmin 396
is a compromise, and we can all rest assured that the next generation will
be far better. (And bigger! And cheaper!)
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old August 26th 05, 04:14 PM
Dan Luke
an unbelievably marvelous platform for weather --
drool.
I want my track "up", which means my route of flight is "up" --
Much is explained. You should seek counseling immediately!
Dan
C-172RG at BFM
Old August 26th 05, 05:18 PM
George Patterson
So turn it sideways, Jay.
George Patterson
Give a person a fish and you feed him for a day; teach a person to
use the Internet and he won't bother you for weeks.
Old August 26th 05, 12:27 AM
Paul Tomblin
I'd like to see one with a screen the size of an approach plate, with very
little room around the screen for the buttons. Ideally, it should also
display approach plates.
Paul Tomblin http://xcski.com/blogs/pt/
Using vi is kind of like having sex. The first time to use it, it's kind
of awkward, but after using for a while you start to get good at it and
enjoy it. -- Eric Merkel
Old August 26th 05, 04:10 PM
Matt Barrow
"Paul Tomblin" wrote in message
Kinda like this? http://www.motioncomputing.com/produ...blet_pc_ls.asp
Old August 26th 05, 06:43 PM
Paul Tomblin
Yeah, but I also would prefer solid state, and I don't want to spend
$3,000 for hardware plus software. What I like about the 396 (and the
thing that Jay uses) is that it's cheap and it doesn't have a hard drive
to fail at high altitude.
"This country has an auto-immune disease. We are attacking ourselves as
the enemy." - Jose (no last name given), rec.aviation.piloting
KX-155 LEDs Steven Barnes Owning 21 July 11th 13 10:04 AM
A-6 Redar Display? Mike Kanze Naval Aviation 0 September 28th 04 02:34 AM
Pirep: Garmin GPSMAP 296 versus 295. (very long) Jon Woellhaf Piloting 12 September 5th 04 12:55 AM
AVSIM 2004 Demographic Survey Tom Allensworth Simulators 0 June 16th 04 04:00 PM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 10:25 AM
