Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Rotorcraft
New Co-axial kit helicopter
Old August 28th 05, 07:00 AM
Blue
Default New Co-axial kit helicopter
Interesting new co-axial from Russia. Not too much info yet as it is a
prototype. However all static and ground tests made, flying time only 12
hours. More info will be available after all tests. Check out these web
sites for info.
http://www.airtrikes.net/heli.jpg
http://delta.wtr.ru/wtboard/40671.shtml
www.clubrotor.ru
Old August 28th 05, 07:10 AM
Shiver
sites for info.
www.clubrotor.ru
Well that's a good looking little ship.
Powered by a four cyliner if my tired eyes are seeing correct.
Old August 28th 05, 11:44 AM
Blue
Yep, thats a 912ULS sitting up there.
Regards
Blue
"Shiver" wrote in message
sites for info.
www.clubrotor.ru
Old August 29th 05, 04:24 AM
Stuart & Kathryn Fields
Very interesting. I can't see any pitch control linkage to the blades.
Don't read Russian, but do they say anything about autorotation?
Stuart Fields
Experimental Helo magazine
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478
(760) 408-9747 general and layout cell
(760) 608-1299 technical and advertising cell
www.vkss.com
www.experimentalhelo.com
"Blue" wrote in message
u...
sites for info.
www.clubrotor.ru
Old August 29th 05, 10:53 AM
Peter Seddon
This website gives quite an interesting history of Kamov who have been
making co-axials for many years
http://avia.russian.ee/vertigo/peopl...v/index_2.html and are the makers
of this latest one.
On this latest single place the lower swashplate is visible in some photos
and it looks like the pitch arms for the upper rotor go down the center of
the main shaft.
Regards Peter
"Stuart & Kathryn Fields" wrote in message
Stuart Fields
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478
www.vkss.com
u...
sites for info.
www.clubrotor.ru
Old August 30th 05, 09:10 PM
Terry Spragg
of this latest one.
the main shaft.
Regards Peter
I don't see any evidence of pitch links at all, unless they are
hydraulic, with rotating hydraulic joints, hydraulic tubes inside
the shafts, and very small actuators.
For autorotation, it could use engine torque actuated linkages to
adjust collective for autorotation. If engine torque goes to zero,
pitch goes to negative, pilot alarm is momentary negative gees and
imposed descent - forced autorotation on power loss. I suggested
such an idea several years ago on this forum. You don't think they
stole my idea? Or maybe they adjust pitch by moving the relative
position of three concentric rotating shafts up and down a half inch
or so? There might not be any cyclic control at all.
Why not?
Yaw control by differential rotor torque and tailfin in downwash /
slipstream?
Now, if it was only quiet enough to tolerate in your back yard,
everyone would want one. The tranny design is a doddle kept secret
by commercial mil / ind complex, its an automotive differential,
with one half turned inside out.
Terry K
Old September 5th 05, 01:29 AM
Terry: Your description sounds interesting but it also sounds like side
translation would not be possible without cyclic which would make hovering
quite a dance.
Stuart Fields
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478
www.vkss.com
"Terry Spragg" wrote in message
makers
of this latest one.
photos
of
the main shaft.
Regards Peter
Why not?
slipstream?
Terry K
Old September 5th 05, 05:24 PM
Peter Seddon
This was the pic that made me think the pitch links go down the main shaft
for the top rotor. http://www.clubrotor.ru/album/gel8.jpg
The pic also shows the botton swash and pitch links.
All the kamaov machines that I have seen on their webiste have both rotors
controlled by pitch links.
Regards Peter
makers of this latest one.
photos and it looks like the pitch arms for the upper rotor go down the
center of the main shaft.
Regards Peter
I don't see any evidence of pitch links at all, unless they are hydraulic,
with rotating hydraulic joints, hydraulic tubes inside the shafts, and
For autorotation, it could use engine torque actuated linkages to adjust
collective for autorotation. If engine torque goes to zero, pitch goes to
negative, pilot alarm is momentary negative gees and imposed descent -
forced autorotation on power loss. I suggested such an idea several years
ago on this forum. You don't think they stole my idea? Or maybe they
adjust pitch by moving the relative position of three concentric rotating
shafts up and down a half inch or so? There might not be any cyclic
control at all.
Why not?
slipstream?
Now, if it was only quiet enough to tolerate in your back yard, everyone
would want one. The tranny design is a doddle kept secret by commercial
mil / ind complex, its an automotive differential, with one half turned
inside out.
Terry K
Old September 5th 05, 05:51 PM
Peter: Thanks, that picture definitely shows the pitch links on the top
blades. However, look at the mass of engine and transmission mounted so
high. To avoid a nose-over, all slide on landings should be conducted
either on ice or a teflon coated airstrip. Alternatively the skids should
be extended out front considerably farther...Dynamic roll overs should be a
lot easier in this bird also. That said, I wish them luck in developing
their pretty bird.. I will definitely have a mention in the next magazine
and use this photo.
Thanks
Stuart Fields
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478
www.vkss.com
"Peter Seddon" wrote in message
for the top rotor.
Regards Peter
Regards Peter
hydraulic,
to
years
rotating
control at all.
Why not?
slipstream?
inside out.
Terry K
Old August 29th 05, 12:02 PM
Simon Robbins
u...
sites for info.
Beautiful looking machine. How does one go about type rating training on a
single seater, btw?
Si
Mini-500 Accident Analysis Dennis Fetters Rotorcraft 16 September 3rd 05 11:35 AM
Lockheed wins Presidential helicopter contract Tiger Naval Aviation 0 January 29th 05 05:24 AM
Musings of a Commercial Helicopter Pilot Badwater Bill Home Built 6 February 27th 04 09:11 AM
Musings of a Commercial Helicopter Pilot Badwater Bill Rotorcraft 0 February 25th 04 06:39 PM
Helicopter crash video James Blakely Piloting 17 December 30th 03 03:21 PM
