![]() Well, I did a bit of playing around with my new 396, and discovered that it WILL NOT accept flight plan data from my KLN-94 or KLN-90B. The problem is that the serial data output by the King units terminates each item with a CR character, while the Garmin panel-mounts send a CR-LF sequence. Not sure if this is an over-sight on Garmin's part, or an attempt to make their panel-mounts work better than King's, but either way, the only way to hook-up the 396 is going to be to design and build a protocol converter to add the extra characters. Luckily, there are some very nice little micros available these days, and I'm figuing I can make something that will easily fit in a box that is small enough to go between the yoke mount and the yoke itself. The 396 will then automatically pick-up the flight plan data from my panel-mount, avoiding the need to enter the data once again. I'll report back once I get it working in case anyone else is interested... |
Mike Granby wrote:
Well, I did a bit of playing around with my new 396, and discovered that it WILL NOT accept flight plan data from my KLN-94 or KLN-90B. The problem is that the serial data output by the King units terminates each item with a CR character, while the Garmin panel-mounts send a CR-LF sequence. CR-LF is the conventional DOS/Windows end of line sequence. Unix uses LF. Apple uses CR. |
Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 12:56 AM |
Boeing Boondoggle | Larry Dighera | Military Aviation | 77 | September 15th 04 02:39 AM |
us air force us air force academy us air force bases air force museum us us air force rank us air force reserve adfunk | Jehad Internet | Military Aviation | 0 | February 7th 04 04:24 AM |
Real World Specs for FS 2004 | Paul H. | Simulators | 16 | August 18th 03 09:25 AM |
