The only test and recertification station to serve Utah refuses to test
and fill the german factory bottles for the DG-400 since they do not have a USA DOT stamp on them. The official regulations (which he showed me) state that foreign bottles without the DOT stamp can only be tested for "EXPORT" use. ie, airliner, ship, etc....leaving the USA for its use. Oxygen suppliers theoretically should not even be filling the bottles without the DOT stamp on them. I got two bottles out of date and the last one nearing out of date ( so far I have local airports filling them if the date stamp is ok, they don't know about the DOT stamp requirement regarding refills.) On the DG-400 as most of you know the bottle which has a smaller diameter than USA bottles and fits in a fiberglass sleeve that threads its way from the cockpit past the fuel tank without much room to spare. 90% of my flight time is on Oxygen in the Rockies so it is getting critical to solve this stalmate with oxygen bottle testing. DG-400 owners, what are you doing to solve this problem??? |
this is why we started again offering STEEL bottles......these are slightly
smaller diameter than the later Aluminum and Kevlar bottles please see my page : http://www.wingsandwheels.com/page35.htm tim Wings & Wheels www.wingsandwheels.com wrote in message oups.com... The only test and recertification station to serve Utah refuses to test and fill the german factory bottles for the DG-400 since they do not have a USA DOT stamp on them. The official regulations (which he showed me) state that foreign bottles without the DOT stamp can only be tested for "EXPORT" use. ie, airliner, ship, etc....leaving the USA for its use. Oxygen suppliers theoretically should not even be filling the bottles without the DOT stamp on them. I got two bottles out of date and the last one nearing out of date ( so far I have local airports filling them if the date stamp is ok, they don't know about the DOT stamp requirement regarding refills.) On the DG-400 as most of you know the bottle which has a smaller diameter than USA bottles and fits in a fiberglass sleeve that threads its way from the cockpit past the fuel tank without much room to spare. 90% of my flight time is on Oxygen in the Rockies so it is getting critical to solve this stalmate with oxygen bottle testing. DG-400 owners, what are you doing to solve this problem??? |
Tim: I'm glad I posted this item so I could see all these comments.
You are right of course that just finding someone to test it isn't the answer because without the DOT stamp an alert O2 station shouldn't fill it. I can't understand why the USA and Germany couldn't have agreed that for EXPERIMENTAL gliders the German bottle was exempt. Mine are certified to 2900psi and we only fill generally to 1800psi. What is the circumference of your "small" diameter bottles? and how long are they? Capacity ? Cost ? |
you can see these bottles (and a lot more) on my page
http://www.wingsandwheels.com/page35.htm the bottles measure 4 3/16" O.D. essentially, when the major manufacturers of these cylinders went to Aluminum bottles they kept the same inside volume, but since steel is stronger they made the wall thickness on the aluminum bottles thicker and gained a few mm in the process... And for what it's worth, I spoke directly with the principles at DG and the former LS a few years ago and told them of the problem....asked why they couldn't just simply make the openings a few silly millimeters larger to accommodate the US owners .they in both cases simply shrugged it off and said to anyone in the USA it's "your problem" in Germany we have no problems.. real satisfaction I'd say... tim Wings & Wheels www.wingsandwheels.com wrote in message oups.com... Tim: I'm glad I posted this item so I could see all these comments. You are right of course that just finding someone to test it isn't the answer because without the DOT stamp an alert O2 station shouldn't fill it. I can't understand why the USA and Germany couldn't have agreed that for EXPERIMENTAL gliders the German bottle was exempt. Mine are certified to 2900psi and we only fill generally to 1800psi. What is the circumference of your "small" diameter bottles? and how long are they? Capacity ? Cost ? |
you can Hydro test anything.......even a Pepsi can.......but you cannot
legally fill oxygen bottles in the USA without the DOT approval and stamp. tim "Gary Evans" wrote in message ... German 02 bottles can be hydro tested at the following facility. Just had mine done and the cost was $47.50 plus shipping. TYM's 414 West Arbor Vitae Street Inglewood, Ca 90301 310-673-3330 Fax 310-673-0580 At 18:18 30 August 2005, wrote: The only test and recertification station to serve Utah refuses to test and fill the german factory bottles for the DG-400 since they do not have a USA DOT stamp on them. The official regulations (which he showed me) state that foreign bottles without the DOT stamp can only be tested for 'EXPORT' use. ie, airliner, ship, etc....leaving the USA for its use. Oxygen suppliers theoretically should not even be filling the bottles without the DOT stamp on them. I got two bottles out of date and the last one nearing out of date ( so far I have local airports filling them if the date stamp is ok, they don't know about the DOT stamp requirement regarding refills.) On the DG-400 as most of you know the bottle which has a smaller diameter than USA bottles and fits in a fiberglass sleeve that threads its way from the cockpit past the fuel tank without much room to spare. 90% of my flight time is on Oxygen in the Rockies so it is getting critical to solve this stalmate with oxygen bottle testing. DG-400 owners, what are you doing to solve this problem??? |
I'd be interested in seeing a link to that rule. My inderstanding was
that it was illegal to transport uncertified cylinders not that it was illegal to fill them. What is the jurisdiction of DOT? One advantage of a self-serve club oxygen system I suppose. Andy |
until your inspection date runs out.. and then how do you pass the annual
condition inspection for the glider? B "Andy" wrote in message oups.com... I'd be interested in seeing a link to that rule. My inderstanding was that it was illegal to transport uncertified cylinders not that it was illegal to fill them. What is the jurisdiction of DOT? One advantage of a self-serve club oxygen system I suppose. Andy |
Take to bottle out at annual inspection!!
duh ![]() Al BTIZ wrote: until your inspection date runs out.. and then how do you pass the annual condition inspection for the glider? B "Andy" wrote in message oups.com... I'd be interested in seeing a link to that rule. My inderstanding was that it was illegal to transport uncertified cylinders not that it was illegal to fill them. What is the jurisdiction of DOT? One advantage of a self-serve club oxygen system I suppose. Andy |
how do you fill them if you can't transport them? isn't flying a glider, or
trailering a glider also transporting???? tim "Andy" wrote in message oups.com... I'd be interested in seeing a link to that rule. My inderstanding was that it was illegal to transport uncertified cylinders not that it was illegal to fill them. What is the jurisdiction of DOT? One advantage of a self-serve club oxygen system I suppose. Andy |
| Thread Tools | |
| Display Modes | |
| What's minimum safe O2 level? | PaulH | Piloting | 29 | November 9th 04 08:35 PM |
| more radial fans like fw190? | jt | Military Aviation | 51 | August 28th 04 05:22 AM |
| Reprise - Oxygen concerns | Neptune | Soaring | 20 | May 27th 04 04:27 PM |
| Need oxygen information | Neptune | Soaring | 4 | May 6th 04 09:11 PM |
| Catastrophic Decompression; Small Place Solo | Aviation | Piloting | 193 | January 13th 04 09:52 PM |
