Perhaps someone here can suggest where to start looking for this
problem: Ocassionally, the electric trim on my '78 Mooney 201 will stop working for "nose up". When I press the button and push forward the trim will run nose down, buy the other way - nothing. While I have the button pressed, the manual trim wheel is difficult to move (like it in being engaged by the electric motor), but when I let go the trim runs fine by hand. I have had this happen a couple of times now, and I am stumped. During the preflight I run the trim full forward and back and it works fine. At some point in the flight it goes out. Voltage on the bus is 13.9, so there is no problem there (unless there is a huge drop at the motor). Anyone here experienced something similar, or have any pointers? Thanks Ian N201ZV @ LZU |
This is a bit off topic but it does involve electric trim and I don't think
I ever gave the group feedback after asking for advice. My Archer's electric trim was working except for the small problem of tripping my over-voltage relay and taking the alternator off-line. The suggested fix was putting a zener diode across the trim motor to shunt the back EMF as the motor turned off. I never got around to making the fix but instead stopped using the electric trim. At my last annual the shop said they found a lot of lubrication points that didn't look like they had been touched in years. After getting my bird back I 1. PIOed the first landing because the yoke was working so freely and 2. Discovered the electric trim now worked without affecting the alternator. so the base cause was too much friction in the trim system. wrote in message oups.com... Perhaps someone here can suggest where to start looking for this problem: Ocassionally, the electric trim on my '78 Mooney 201 will stop working for "nose up". When I press the button and push forward the trim will run nose down, buy the other way - nothing. While I have the button pressed, the manual trim wheel is difficult to move (like it in being engaged by the electric motor), but when I let go the trim runs fine by hand. I have had this happen a couple of times now, and I am stumped. During the preflight I run the trim full forward and back and it works fine. At some point in the flight it goes out. Voltage on the bus is 13.9, so there is no problem there (unless there is a huge drop at the motor). Anyone here experienced something similar, or have any pointers? Thanks Ian N201ZV @ LZU |
Mark 12D Problem??? | three-eight-hotel | Owning | 24 | June 10th 16 12:18 AM |
Mooney Low Voltage | [email protected] | Owning | 22 | August 1st 05 01:01 PM |
B40 rf interference problem | mborgelt | Soaring | 9 | March 13th 05 03:49 PM |
ASW 28 trim lever interference | Andy Durbin | Soaring | 0 | June 28th 04 08:47 PM |
Piper Arrow electric fuel-pump | MC | General Aviation | 7 | June 3rd 04 02:50 AM |
