Eclipse Lands Gear up.. an Idea....
Old September 9th 05, 12:23 AM
Default Eclipse Lands Gear up.. an Idea....
I heard that one of the Eclipse test aircraft landed gear up officially due to pilot error.
This is supposed to be a truely smart aircraft...
It has a fully integrated flight control system.
It knows where you are, how high you are, how fast you are,
It should know if the gear is down.
It has a database with airports in it.
If you are within one mile of an airport
if you less than 1000 ft AGL at that airport
if you are heading toward that airport
if you are less than 150 knots
if your gear is still up
Then the gear horn should be so loud that your ears hurt and it makes your fillings fall out.
IMHO The one problem with a traditional power based gear horn is that it is dumb,
It goes off when you are doing things other than landing,such as
descending at low power, practicing stalls, or other wise screwing around.
Since it may go off in non landing normal flight, for safety sake,
it can't be so loud that you can't ignore it.
Eclipse has a "Smart" airplane it can know things like height AGL,
are if you are close to an airport, etc....
So the number of cases where the gear horn goes off when your
not landing can be reduced to zero?
Their horn should curl your hair.
I once fired a flight instructor because he had me out doing slow flight and stalls
with the gear up, whenever the gear horn went off I put the gear down,
he complained that I would not follow his direction.
I explained to him that I never ever wanted to maintain a plane in a flight
condition where the gear horn was on, as I did not want
to become accustomed to that noise.
He was not ok with that I found a different instructor.
Paul
Old September 9th 05, 03:08 AM
Flyingmonk
Too bad about the mishap. Glad all crew came out unscaved.
The Eclipse people said that it proved how well the design could handle
the mishap. Duh! What else can they say? Hehehe. To their credit,
the plane and the crew did come out pretty well. They said that it
should be repaired and be back in the air soon.
Good looking plane, but I like the look of the Epic LT more. I know,
apples and oranges ~ twin jet vs. turbo prop single. I still like the
Epic LT more.
Bryan "The Monk" Chaisone
Old September 9th 05, 03:54 AM
Jay Honeck
True, but they will soon find out what it's like to be "unemployable",
methinks.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old September 9th 05, 10:39 PM
Don Hammer
Lots of strange things happen in flight test. Consider that they may
have had the warning system disabled to accomplish their test card.
It wouldn't be the first time this has happened. Just ask Bombardier.
Old September 9th 05, 03:50 PM
Marco Leon
Why not just keep the power-based gear warning and have it resettable with a
button. When the power resumes, it will then arm itself again.
Marco Leon
due to pilot error.
fillings fall out.
is dumb,
and stalls
flight
Paul
A&P heroics Jim Piloting 31 July 18th 05 07:26 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 1 November 24th 03 02:46 PM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 2 November 24th 03 05:23 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart Hull Home Built 0 November 24th 03 03:52 AM
Aluminum vs Fiberglass landing gear - Pro's and cons. Bart D. Hull Home Built 0 November 22nd 03 06:24 AM
