Today I awoke to find a cloud sitting on the ground bringing the vis down
to 1/16th of a mile. All the airlines here in KROC were forced to hold from takeoff until it lifted a little. I know that the part 91 is 0/0 unless otherwise noted, what about part 131 or the airlines? Do they have different takeoff mins? My next question is about the approach to landing....if the wx during the landing was like this morning right, below mins for sure (1/16th SM VV100), could a part 91 still attempt the approach hopeing the was a hole in the scud and see the runway, but knowing its below mins and will most likely go missed? What about the airlines and air carriers, could they attempt the approach when the wx is below mins? I guess what Im trying to ask is.....anyone allowed to attempt a approach when the wx is below mins? What if the field is uncontrolled with an ILS and does have AWOS reporting below mins. Does is matter if its controlled or not? Im just wondering about this, dont get me wrong, I would NEVER attempt a approach thats below mins. Just courious if its stated somewhere in the FARS (I couldnt find it) about the approach to landing with below mins WX.....thanks for the imput! -Ben |
jamin3508 wrote:
Today I awoke to find a cloud sitting on the ground bringing the vis down to 1/16th of a mile. All the airlines here in KROC were forced to hold from takeoff until it lifted a little. I know that the part 91 is 0/0 unless otherwise noted, what about part 131 or the airlines? I couldn't find Part 131. If you mean parts 121 and 135, yes their rules are different. Do they have different takeoff mins? My next question is about the approach to landing....if the wx during the landing was like this morning right, below mins for sure (1/16th SM VV100), could a part 91 still attempt the approach hopeing the was a hole in the scud and see the runway, but knowing its below mins and will most likely go missed? Part 121/135 operators can't accept an approach clearance if the reported weather is below minimums. "see the runway" is not sufficient for Part 91, either. What about the airlines and air carriers, could they attempt the approach when the wx is below mins? No. I guess what Im trying to ask is.....anyone allowed to attempt a approach when the wx is below mins? Part 91. What if the field is uncontrolled with an ILS and does have AWOS reporting below mins. Does is matter if its controlled or not? No. Im just wondering about this, dont get me wrong, I would NEVER attempt a approach thats below mins. Why wouldn't you? Are you operating under Part 121/135? Just courious if its stated somewhere in the FARS (I couldnt find it) about the approach to landing with below mins WX.....thanks for the imput! |
In article
outaviation.com, jamin3508 wrote: Today I awoke to find a cloud sitting on the ground bringing the vis down to 1/16th of a mile. All the airlines here in KROC were forced to hold from takeoff until it lifted a little. I know that the part 91 is 0/0 unless otherwise noted, what about part 131 or the airlines? Do they have different takeoff mins? Part 121, I assume you mean, and yes, they have different takeoff mins. At my company, we basically use the minimums on the Jeppesen charts. It depends how the runway is equipped, but normally we need 1600RVR (1/4mi) on a runway with standard takeoff minimums and adequate visual references. In many places, we can take off with as low as 600 RVR, but that requires multiple RVR sensors and a runway with centerline lights. (Some operators can use 500RVR; 600 is as low as we can go. It's in each specific airline's FAA ops specs.) My next question is about the approach to landing....if the wx during the landing was like this morning right, below mins for sure (1/16th SM VV100), could a part 91 still attempt the approach hopeing the was a hole in the scud and see the runway, but knowing its below mins and will most likely go missed? Sticky area. You can definitely shoot the approach, but landing from it could be problematic. The rules say "flight visibility," which you can only really judge in-flight. Tower visibility really isn't a good indicator of flight visibility, but RVR is a much more accurate view of what you'll probably see from the cockpit. I understand they *have* hung pilots out to dry for landing with RVR below minimums. I don't have a specific cite for that, so it may be urband legend. Perhaps someone can chime in on this one? What about the airlines and air carriers, could they attempt the approach when the wx is below mins? No. If the visibility/RVR is below approach minimums, an air carrier can't continue past the final approach point; he'd have to go missed at that point if there wasn't a report of the visibility being at or above the minimum. If touchdown zone RVR is available, it's the controlling value that decides whether they can start the approach. If not, it's visibility. If they're already on the final approach segment and the visibility/RVR goes down, they may continue the approach, but as far as landing goes, we're back to "flight visibility." If the RVR is below minimums, you're not likely to see the visual cues you need anyway. I'd continue the approach and hope the reported RVR comes back up before DH, but a missed approach is most likely at that point. I guess what Im trying to ask is.....anyone allowed to attempt a approach when the wx is below mins? Yes, part 91 operators are completely free to attempt the approach, at least down to DH. What if the field is uncontrolled with an ILS and does have AWOS reporting below mins. Does is matter if its controlled or not? No, it doesn't matter. It's the only reported weather, which means if it's reporting visibility below minimums, an air carrier can't fly the approach. My company serves a couple of uncontrolled airports, and we run into that from time to time. But a part 91 aircraft can start the approach, definitely. At an uncontrolled airport with an AWOS reporting below minimums, I'd absolutely try the approach under part 91, because the visibility of an AWOS is not often a good indicator of what you'll see. Flight visibility may be just fine on the runway, often because it's on a different part of the airport from the AWOS visibility measurement. I've often seen a fog bank covering just half an airport, leaving most of my landing runway completely clear. Im just wondering about this, dont get me wrong, I would NEVER attempt a approach thats below mins. Just courious if its stated somewhere in the FARS (I couldnt find it) about the approach to landing with below mins WX.....thanks for the imput! The specific FAR is 91.175. It says an aircraft may not descent below DH/MDA unless, among other things, "The flight visibility is not less than the visibility prescribed in the standard instrument approach being used." But it says nothing about *starting* the approach; that's specific to air carrier operations. You're perfectly legal to fly the approach; you just need to meet that reg in order to continue past the bottom of the approach. Hope that hhelps. -- Garner R. Miller ATP/CFII/MEI Clifton Park, NY =USA= |
I've shot approaches below minimums many times. I fly down to the fog
valley when vis is 0/0 and just shot approaches. Its good practice. If you actually land and the approach calls for both a flight visibility minimum AND lists an RVR minimum you could probably get in trouble for landing when the RVR is reported below those mins. -Robert |
One addition to other posters comments on going below DH. You can go below
DH without having the runway in sight if you have the runway environment (approach lighting system) is sight. You are authorized (91 and 135) to 100 feet. At 100 feet you must have the runway (which can mean only the end lights of the runway) in sight. Our FSDO operations inspector wants us to set 100 feet on the radar altimeter because that is the absolute lowest you can go on a typical approach. Many pilots prefer the DH AGL altitude set on the radalt. Paul "jamin3508" wrote in message lkaboutaviation.com... Today I awoke to find a cloud sitting on the ground bringing the vis down to 1/16th of a mile. All the airlines here in KROC were forced to hold from takeoff until it lifted a little. I know that the part 91 is 0/0 unless otherwise noted, what about part 131 or the airlines? Do they have different takeoff mins? My next question is about the approach to landing....if the wx during the landing was like this morning right, below mins for sure (1/16th SM VV100), could a part 91 still attempt the approach hopeing the was a hole in the scud and see the runway, but knowing its below mins and will most likely go missed? What about the airlines and air carriers, could they attempt the approach when the wx is below mins? I guess what Im trying to ask is.....anyone allowed to attempt a approach when the wx is below mins? What if the field is uncontrolled with an ILS and does have AWOS reporting below mins. Does is matter if its controlled or not? Im just wondering about this, dont get me wrong, I would NEVER attempt a approach thats below mins. Just courious if its stated somewhere in the FARS (I couldnt find it) about the approach to landing with below mins WX.....thanks for the imput! -Ben |
"Paul Lynch" wrote
One addition to other posters comments on going below DH. You can go below DH without having the runway in sight if you have the runway environment (approach lighting system) is sight. You are authorized (91 and 135) to 100 feet. At 100 feet you must have the runway (which can mean only the end lights of the runway) in sight. I don't think that you fully understand 91.175.... (3) Except for a Category II or Category III approach where any necessary visual reference requirements are specified by the Administrator, at least one of the following visual references for the intended runway is distinctly visible and identifiable to the pilot: (i) The approach light system, except that the pilot may not descend below 100 feet above the touchdown zone elevation using the approach lights as a reference unless the red terminating bars or the red side row bars are also distinctly visible and identifiable. (ii) The threshold. (iii) The threshold markings. (iv) The threshold lights. (v) The runway end identifier lights. (vi) The visual approach slope indicator. (vii) The touchdown zone or touchdown zone markings. (viii) The touchdown zone lights. (ix) The runway or runway markings. (x) The runway lights. It says that I can go below 100' on the approach lights only, if I have either the red terminating bars or red side row bars visible. The 100' limit is not applicable if I have any of the items (ii) thru (x) in sight, ie, I can descend below DH with only the VASI in sight or...the REILS for that matter. Bob Moore ATP CFI PanAm (retired) |
I guess I miss your point Bob. I don't think I said anything that conflicts
with 91.175. I am ready to be educated, for me that process is painfully endless. "Bob Moore" wrote in message . 122... "Paul Lynch" wrote One addition to other posters comments on going below DH. You can go below DH without having the runway in sight if you have the runway environment (approach lighting system) is sight. You are authorized (91 and 135) to 100 feet. At 100 feet you must have the runway (which can mean only the end lights of the runway) in sight. I don't think that you fully understand 91.175.... (3) Except for a Category II or Category III approach where any necessary visual reference requirements are specified by the Administrator, at least one of the following visual references for the intended runway is distinctly visible and identifiable to the pilot: (i) The approach light system, except that the pilot may not descend below 100 feet above the touchdown zone elevation using the approach lights as a reference unless the red terminating bars or the red side row bars are also distinctly visible and identifiable. (ii) The threshold. (iii) The threshold markings. (iv) The threshold lights. (v) The runway end identifier lights. (vi) The visual approach slope indicator. (vii) The touchdown zone or touchdown zone markings. (viii) The touchdown zone lights. (ix) The runway or runway markings. (x) The runway lights. It says that I can go below 100' on the approach lights only, if I have either the red terminating bars or red side row bars visible. The 100' limit is not applicable if I have any of the items (ii) thru (x) in sight, ie, I can descend below DH with only the VASI in sight or...the REILS for that matter. Bob Moore ATP CFI PanAm (retired) |
"Paul Lynch" wrote
I guess I miss your point Bob. I don't think I said anything that conflicts with 91.175. I am ready to be educated, for me that process is painfully endless. Well....you said: " At 100 feet you must have the runway (which can mean only the end lights of the runway) in sight." I mearly pointed out that you do not have to have the runway (nor the end lights of the runway) in sight. The Touchdown Zone Markings will do quite well as will the VASI and obviously... the Runway Markings. Bob Moore |
Paul Lynch wrote:
I guess I miss your point Bob. I don't think I said anything that conflicts with 91.175. I am ready to be educated, for me that process is painfully endless. Bob is making a distinction that has no practical effect. If you're on G/S and much below 100 feet you can't see any part of the ALS system because it is directly below you rapidly passing behind you. Thus, you will have to see one of the other runway cues or begin the miss approach. |
On Fri, 09 Sep 2005 20:40:16 GMT, Bob Moore
wrote: "Paul Lynch" wrote One addition to other posters comments on going below DH. You can go below DH without having the runway in sight if you have the runway environment (approach lighting system) is sight. You are authorized (91 and 135) to 100 feet. At 100 feet you must have the runway (which can mean only the end lights of the runway) in sight. I don't think that you fully understand 91.175.... (3) Except for a Category II or Category III approach where any necessary visual reference requirements are specified by the Administrator, at least one of the following visual references for the intended runway is distinctly visible and identifiable to the pilot: (i) The approach light system, except that the pilot may not descend below 100 feet above the touchdown zone elevation using the approach lights as a reference unless the red terminating bars or the red side row bars are also distinctly visible and identifiable. (ii) The threshold. (iii) The threshold markings. (iv) The threshold lights. (v) The runway end identifier lights. (vi) The visual approach slope indicator. (vii) The touchdown zone or touchdown zone markings. (viii) The touchdown zone lights. (ix) The runway or runway markings. (x) The runway lights. It says that I can go below 100' on the approach lights only, if I have either the red terminating bars or red side row bars visible. The 100' limit is not applicable if I have any of the items (ii) thru (x) in sight, ie, I can descend below DH with only the VASI in sight or...the REILS for that matter. Bob Moore ATP CFI PanAm (retired) And don't forget 91.175(c)(2) which says that in order to operate below DH, you ALSO need to have "the visibility prescribed in the standard instrument approach being used". Ron (EPM) (N5843Q, Mooney M20E) (CP, ASEL, ASES, IA) |
My Approach and takeoff Videos | A Lieberman | Instrument Flight Rules | 0 | April 16th 05 04:50 AM |
Why fly fast approaches? | EDR | Piloting | 54 | July 8th 04 01:20 AM |
FS2004 approaches, ATC etc | henri Arsenault | Simulators | 14 | September 27th 03 12:48 PM |
