Endeavouring to defuse tensions that flared again recently over which
finish procedure to employ at comps, SSA are rumoured to be considering a change that could quell the rancor and invective over the two practises: viz., finish line v. finish ring/cylinder. As America's gliding overseers are steadfast in taking no formally sanctioned position on this controversy, the proposed action more accurately comprises a redefinition, not a procedural change. SSA earnestly hope that re-labeling the rival options with more descriptive, less inflammatory terms--ones not yet hurled about like rallying cries at a football match--will reduce the emotional, almost primitive responses that erupt each time this contentious subject is reopened. To wit, the procedure customarily employing a FINISH LINE shall henceforth be known as GUIDED APPROACH, reflecting the orderly, predictable, proven way in which gliders approach a tightly defined finish line along a narrow glide path, pull up smoothly, and naturally sequence themselves into the circuit to land. Likewise, the practise utilising what is commonly referred to as a FINISH CYLINDER shall be known as RANDOM ARRIVAL, indicative of the unpredictable courses taken by gliders returning to the airfield at the conclusion of a task and elbowing their way into the circuit erratically from different directions, altitudes, and speeds. Notwithstanding SSA's officially impartial stance, a grizzled Western spokesperson expressed his view bluntly. "Let's call a spade a spade, I say. Most o' these bozos can't navigate anyhow--they need a GPS to find the toilet. So how's they supposed to aim at an invisible cylinder without being heads down and locked?" "We seen it before. Some o' the scariest times at comps is trying to get back on the ground after the CD cancels the day. Same thing happens after a big cylinder finish. You safety wimps think a crowded gaggle is bad? [uttering an oath]--you ain't seen nothin' till ya got 20 or 30 gliders comin' in from all directions, every last one of 'em glued to their little TV screens, then lookin' up for the first time when they's right on top of the airfield. And all of 'em dead set on landin' by their trailers!" [breaking wind and uttering another oath] And from another, somewhat more temperate representative: "A cylinder full of gliders after a mass finish is like tossing a $100 note on the floor during the briefing and saying 'go to it.' It's utter chaos, don't you see?" "Mind you, I'm not opposed to change. Making use of cylinders at turnpoints, for example, isn't so dodgy--there's a lot of sky up there. In fact, I quite like the 'beer can.' I'm referring to turn cylinders and not lagers, of course." "But finish cylinders are another matter entirely, being uncommonly dangerous. I call them 'fear cans' for the sheer terror that their officially sanctioned mayhem can incite in even the stoutest airman's heart!" ------------- GUIDED APPROACH + RANDOM ARRIVAL. SSA plan to seek concurrence from the U.S.A. Rules Committee although the proposed modification in nomenclature is purely administrative, requires no Rules change, and accordingly is not subject to pre-notification. Upon receiving the blessing of the Rules Committee, it will be put into effect straight away. SoarPoint ![]() |
SoarPoint,
So did everyone confuse irony for reality this time? Or is the whole issue so ridiculous that no one can tell the difference? Or, in a weird twist of perception, did I confuse reality for irony? Hmmm?! Larry "SoarPoint" wrote in message oups.com: Endeavouring to defuse tensions that flared again recently over which finish procedure to employ at comps, SSA are rumoured to be considering a change that could quell the rancor and invective over the two practises: viz., finish line v. finish ring/cylinder. As America's gliding overseers are steadfast in taking no formally sanctioned position on this controversy, the proposed action more accurately comprises a redefinition, not a procedural change. SSA earnestly hope that re-labeling the rival options with more descriptive, less inflammatory terms--ones not yet hurled about like rallying cries at a football match--will reduce the emotional, almost primitive responses that erupt each time this contentious subject is reopened. To wit, the procedure customarily employing a FINISH LINE shall henceforth be known as GUIDED APPROACH, reflecting the orderly, predictable, proven way in which gliders approach a tightly defined finish line along a narrow glide path, pull up smoothly, and naturally sequence themselves into the circuit to land. Likewise, the practise utilising what is commonly referred to as a FINISH CYLINDER shall be known as RANDOM ARRIVAL, indicative of the unpredictable courses taken by gliders returning to the airfield at the conclusion of a task and elbowing their way into the circuit erratically from different directions, altitudes, and speeds. Notwithstanding SSA's officially impartial stance, a grizzled Western spokesperson expressed his view bluntly. "Let's call a spade a spade, I say. Most o' these bozos can't navigate anyhow--they need a GPS to find the toilet. So how's they supposed to aim at an invisible cylinder without being heads down and locked?" "We seen it before. Some o' the scariest times at comps is trying to get back on the ground after the CD cancels the day. Same thing happens after a big cylinder finish. You safety wimps think a crowded gaggle is bad? [uttering an oath]--you ain't seen nothin' till ya got 20 or 30 gliders comin' in from all directions, every last one of 'em glued to their little TV screens, then lookin' up for the first time when they's right on top of the airfield. And all of 'em dead set on landin' by their trailers!" [breaking wind and uttering another oath] And from another, somewhat more temperate representative: "A cylinder full of gliders after a mass finish is like tossing a $100 note on the floor during the briefing and saying 'go to it.' It's utter chaos, don't you see?" "Mind you, I'm not opposed to change. Making use of cylinders at turnpoints, for example, isn't so dodgy--there's a lot of sky up there. In fact, I quite like the 'beer can.' I'm referring to turn cylinders and not lagers, of course." "But finish cylinders are another matter entirely, being uncommonly dangerous. I call them 'fear cans' for the sheer terror that their officially sanctioned mayhem can incite in even the stoutest airman's heart!" ------------- GUIDED APPROACH + RANDOM ARRIVAL. SSA plan to seek concurrence from the U.S.A. Rules Committee although the proposed modification in nomenclature is purely administrative, requires no Rules change, and accordingly is not subject to pre-notification. Upon receiving the blessing of the Rules Committee, it will be put into effect straight away. SoarPoint ![]() |
Finish Gate Accident no. 2 | [email protected] | Soaring | 50 | April 2nd 05 06:58 AM |
Seniors Contest | Bob Fidler | Soaring | 68 | March 17th 05 03:50 AM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Procedure Turn | Bravo8500 | Instrument Flight Rules | 65 | April 22nd 04 03:27 AM |
