If you guys aren't tired of arithmetic, I'm wondering if any fighter
pilots have shot themselves down. Probably not, but imagine you're flying straight and level at 1000 mph and fire a 500 mph projectile at an enemy that's directly ahead but at a higher altitude. You miss him; the bullet follows a parabolic path, returning to your altitude just as you overtake it. Discounting air friction, at what angle was the bullet fired? (extra credit question -- how many rivets could you have installed in the time you wasted thinking about this question?) |
I'd suspect that the caliber - the loading of the bulltets (propellent and bullet weight and shape) would have influence onn the outcome as well ~ to answer your question. extra credit question -- Five carefully measured and placed, 50 if placed haphazardly. This also depends on the dificulty of the location of rivets to be installed. Bryan "The Monk" Chaisone |
fired? Discounting air friction the angle would be 90 degrees, straight up. |
Bill Chernoff wrote:
Discounting air friction, at what angle was the bullet fired? Discounting air friction the angle would be 90 degrees, straight up. But that would neglect the coriolis force... :-) Matt |
"Bill Chernoff" wrote:
Discounting air friction, at what angle was the bullet fired? Discounting air friction the angle would be 90 degrees, straight up. Yep. I was going to say "impossible" since he was firing at a plane ahead of him, and I incorrectly translated that to a barrel angle with some forward component. But you are right, the 90-degree angle may well have been the firing solution for the target ahead of him, given differences in the plane's velocities. Glad I read your correct answer before giving my answer of "impossible"! -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
Smitty Two asked:
If you guys aren't tired of arithmetic, I'm wondering if any fighter pilots have shot themselves down. Probably not, but imagine you're flying straight and level at 1000 mph and fire a 500 mph projectile at an enemy that's directly ahead but at a higher altitude. You miss him; the bullet follows a parabolic path, returning to your altitude just as you overtake it. Discounting air friction, at what angle was the bullet fired? Before you find yourself in the same trap as me, let me ask for some clarification: 1. Since you stipulate a vacuum, are we flying above the Earth? 2. How high? 3. Are we flying at an absolute altitude, e.g. following an orbital path? 4. Is the plane flying level at the moment of firing with only the gun pointed up at the target airplane? Rich "Without a clue" S. |
"Rich S." wrote: Smitty Two asked: If you guys aren't tired of arithmetic, I'm wondering if any fighter pilots have shot themselves down. Probably not, but imagine you're flying straight and level at 1000 mph and fire a 500 mph projectile at an enemy that's directly ahead but at a higher altitude. You miss him; the bullet follows a parabolic path, returning to your altitude just as you overtake it. Discounting air friction, at what angle was the bullet fired? Before you find yourself in the same trap as me, let me ask for some clarification: 1. Since you stipulate a vacuum, are we flying above the Earth? 2. How high? 3. Are we flying at an absolute altitude, e.g. following an orbital path? 4. Is the plane flying level at the moment of firing with only the gun pointed up at the target airplane? Rich "Without a clue" S. I think I'm already in that trap, but it wasn't my intention (or yours, I know) for this to be a trick question based on ambiguity in the phrasing. But, sure, I'll address your concerns. 1. I didn't stipulate a vacuum. My engine and wing don't work very well without air. I said, to simplify calculations, ignore the effects of friction on the projectile. We are flying above the earth. 2. At an altitude at which acceleration due to gravity is 32 feet per second per second. Assume this remains constant throughout. 3. With the exception of the airplanes and the guns, this is a pre-Columbian question. The earth is flat. Or, if you prefer, we're flying tangentially to its curved surface. 4. The plane is flying level, as I believe I stated. |
"Smitty Two" wrote in message
news ![]() I think I'm already in that trap, but it wasn't my intention (or yours, I know) for this to be a trick question based on ambiguity in the phrasing. But, sure, I'll address your concerns. 1. I didn't stipulate a vacuum. My engine and wing don't work very well without air. I said, to simplify calculations, ignore the effects of friction on the projectile. We are flying above the earth. 2. At an altitude at which acceleration due to gravity is 32 feet per second per second. Assume this remains constant throughout. 3. With the exception of the airplanes and the guns, this is a pre-Columbian question. The earth is flat. Or, if you prefer, we're flying tangentially to its curved surface. 4. The plane is flying level, as I believe I stated. Kewl! That makes it easy! I don't know. Rich S. |
![]() Smitty Two wrote: 1. I didn't stipulate a vacuum. My engine and wing don't work very well without air. I said, to simplify calculations, ignore the effects of friction on the projectile. We are flying above the earth. You said discounting air friction. This is key to the problem. No air friction would be the physical equivalent of being in a vacuum. If there were no air friction, the projectile would continue ahead with a forward speed of 1500 mph - its own 500 mph from its spent propellant charge, and the 1000 mph imparted to it from the airframe. Air friction, however, acts on the projectile from the moment it departs the muzzle, and acts to slow the projectile in a continuous manner. The aircraft continues to maintain its 1000 mph since it has a propulsive device that is assumed to continue to operate. Air friction (along with gravity) are the forces that conspire to ALLOW the aircraft to overtake its projectile and contribute to shooting itself down. So... are we or are we not including air friction? If we are, I am not going to hazard a guess.. my math gland atrophied long ago after I passed calculus. If we are not, then the problem is unsolvable in level flight on earth. Dave |
In article t,
Dave S wrote: Smitty Two wrote: 1. I didn't stipulate a vacuum. My engine and wing don't work very well without air. I said, to simplify calculations, ignore the effects of friction on the projectile. We are flying above the earth. You said discounting air friction. This is key to the problem. No air friction would be the physical equivalent of being in a vacuum. If there were no air friction, the projectile would continue ahead with a forward speed of 1500 mph - its own 500 mph from its spent propellant charge, and the 1000 mph imparted to it from the airframe. Air friction, however, acts on the projectile from the moment it departs the muzzle, and acts to slow the projectile in a continuous manner. The aircraft continues to maintain its 1000 mph since it has a propulsive device that is assumed to continue to operate. Air friction (along with gravity) are the forces that conspire to ALLOW the aircraft to overtake its projectile and contribute to shooting itself down. So... are we or are we not including air friction? If we are, I am not going to hazard a guess.. my math gland atrophied long ago after I passed calculus. If we are not, then the problem is unsolvable in level flight on earth. Dave It's a hypothetical question, of course. I think I stated it fairly clearly. Bill has already answered it correctly, with a second from Alex. My calculus skills have also eroded over the years, which is one reason I wanted to discount friction. But, I'd be curious to learn what the real world answer would be, including friction, which of course is dependent on a whole host of factors. (Of course, by the time the plane caught up with the bullet in the real world, the friction would likely have reduced its speed to something *relatively* harmless.) Now, for some practical math, I hope one of these WW1 guys around here can help me not shoot the prop off my RV when I put the .50 on the front. |
They really *are* shooting at the helicopters... | Jay Honeck | Piloting | 42 | September 8th 05 05:12 AM |
Helicopter Physics info online anywhere?? | [email protected] | Rotorcraft | 4 | April 24th 04 04:18 PM |
Accurate plane performace? | R | Simulators | 27 | December 19th 03 04:54 AM |
FA: 1944 The Physics of Aviation (Flight Theory) | Oldbooks78 | Aviation Marketplace | 0 | July 28th 03 10:47 PM |
Is shooting down a V-! better than shooting down an ME 109? | alf blume | Military Aviation | 26 | July 20th 03 07:51 AM |
