Light Sport Aircraft
Old January 3rd 05, 05:16 PM
Willard
Default Light Sport Aircraft
I am planning to buy a factory-built LSA within a few months. All the
aircraft I am considering will be built by companies with a history of
selling kits - e.g., Rans, Kolb, Kitfox, etc. Any homebuilders out
there have any opinions about any of these companies and their
products?
Thanks
Old January 3rd 05, 05:26 PM
Gig Giacona
Are any of those aircraft built under the "consensus standards"? Are the
consensus standards even finalized yet?
"Willard" wrote in message
products?
Thanks
Old January 3rd 05, 08:54 PM
On Mon, 3 Jan 2005 11:26:29 -0600, "Gig Giacona"
products?
The consensus standards have been released, you can order them from www.astm.org
(Stock number: Aircraft04). It's an 80-page document, used in lieu of a few
hundred pages of conventional FAR. Interesting read. The maintenance standard
is still under discussion, but it will probably be out soon. The FAA is having
its first course for DAR-LSAs this month, but I believe a standard DAR (or, of
course, the local FSDO) can do the safety sign-off for a production LSA.
Old January 3rd 05, 09:26 PM
Gig Giacona
roups.com...
products?
www.astm.org
few
standard
having
(or, of
So it is. Though I couldn't find it with AVIATION04 as a search I did find
this http://www.astm.org/COMMIT/F37.htm just ordered a copy.
That still begs the question as to if a plane has been built to this
standard yet or will be in a few months as the OP seemed to beleive.
Old January 3rd 05, 10:07 PM
Morgans
www.astm.org
few
standard
having
(or, of
Is it correct to say that the consensus standards do not apply, when it is a
plans built? How about kit meeting 51% self built rule?
I'm still not exactly sure I understand what an experimental LSA is, and
what hoops must be jumped through.
Jim in NC
Old January 3rd 05, 10:30 PM
sleepy6
says...
www.astm.org
of a
few
ce
standard
A is
having
AR
(or, of
LSA.
t is a
nd
Jim in NC
An ELSA is simply an SLSA that has been pulled off the production line
at whatever point the customer wants. The customer then finishes the
planes following the EXACT factory instructions but it must be
identical to the SLSA. All factory parts and no modifications at all.
It is subject to the same maintaince ect requirements as SLSA but can
not be used for instruction or rental.
Old January 3rd 05, 11:24 PM
On Mon, 03 Jan 2005 22:30:18 GMT, (sleepy6) wrote:
says...
it is a plans built? How about kit meeting 51% self built rule?
and what hoops must be jumped through.
It is subject to the same maintaince etc requirements as SLSA but can
Sleepy is correct. The LSA regs do not affect the classic 51% homebuilts *at
all*. The same old process is in effect. If your 51% homebuilt meets the
definition of a Light Sport Aircraft (gross weight, stall speed, etc.) it can be
flown by a person with Sport Pilot privileges (either someone with an actual
Sport Pilot license, or someone with a higher license and an lapsed medical) but
the licensing and maintenance regulations are the same as they've always been.
One small point that I'll correct Sleepy on: The Experimental LSA is not quite
subject to the same maintenance requirements of a Special Light Sport Aircraft.
On the SLSA:
1. Preventative maintenance can be performed by the owner (just like FAR 23
aircraft).
2. Normal/major maintenance must be performed by an A&P or a person with a
Light Sport-Maintenance (LS-M) Repairman Certificate
3. Annual inspections must be performed by either an A&P or a person with a
LS-M Repairman Certificate.
For the ELSA:
1&2. Preventative AND Normal/major maintenance can be performed by the owner
3. Annual inspections must be performed by an A&P, a person with a LS-M
Repairman Certificate, or someone with the other new Repairman Certificate,
Light Sport- Inspection (LS-I).
The LS-I Repairman Certificate is similar to the Amateur-Built aircraft
repairman certificate, with two significant exceptions:
First, the applicant must complete a 16-hour training course. You can NOT
receive an LS-I just by assembling an ELSA. You MUST take the course.
Second, a person with an LS-I may perform the annual inspection on *any* ELSA
they own. Unlike the Amateur-Built Repairman Certificate, it is not applicable
to only one aircraft. Once you earn the LS-I, you can buy another ELSA kit or a
completed ELSA aircraft and perform the annual inspections on it.
Sleepy touches on one sporty item about the ELSA category. Like he says, the
ELSA kit *must* be built exactly to the LSA kit manufacturer's instructions.
You cannot install an alternate engine, use a different covering system, etc.
It must be built precisely to the manufacturer's callout.
However... as far as I can tell, the owner can then modify the aircraft however
they chose, once the plane receives its formal ELSA airworthiness certificate.
Owners of SLSAs (the production LSAs) must maintain their aircraft in precise
accordance to the manufacturer's maintenance plan and continued safety
directives to continue to conform to the consensus standard. But the FAA also
says that owners of SLSAs can avoid having to follow the SLSA's manufacturer's
safety directives by changing their plane's airworthiness to ELSA.
It follows, then, that ELSAs are NOT required to continue to comply to the
consensus standard, and owners can modify them once they've received their
original ELSA certification.
Old January 4th 05, 01:21 AM
Morgans
t is a
nd
Jim in NC
Sorry, but you didn't catch what I asked. What about the plans built, or
one that has no assembly, at all? What about the guy that designs one (one
off) that fits under the specs of the rule?
Jim in NC
Old January 8th 05, 04:11 PM
Cy Galley
products?
www.astm.org
few
standard
having
(or, of
Ordinary DAR can NOT do the LSA inspection/certification until he is
qualified by taking the FAA LSA workshop.
Cy Galley
EAA Safety Programs Editor
Always looking for ideas and articles for EAA Sport Pilot
Old January 4th 05, 01:10 AM
Rick Pellicciotti
Williard,
You will, no doubt get a lot of messages in response to your post
regarding the LSA rules, the availability of factory built, sLSA
certified aircraft and so forth.
I will apply good common sense and assume that you will not be buying
one of these airplanes until they are available (whenever that is, two
months or 10 months) and answer the question that you actually asked.
I have experience with RANS and Kitfox aircraft. I have personally
built 5 RANS kitplanes and I have known Randy Schlitter since 1988. The
airplanes are top notch, customer support and service are second to
none. RANS has a production certificate in hand and can build S-7
Couriers today. To my knowledge, this is the only LSA legal, new
airplane that is certified right now. The RANS S-6 Coyote is a great
airplane and is very easy to build. As a matter of fact, I would
encourage you to buy a RANS S-6 kit with Quickbuild option and put it
together yourself. You can license it under Experimental/Amateur Built
and fly it with a no-medical Sport Pilot license. By building it
yourself, you can do your own annual condition inspections and repairs.
One of the S-6's that I built was assembled in 48 days of part time
work. That was before the quickbuild option was available.
In regard to the Kitfox, it is a very nice airplane with good handling
qualities. I have test flown one and ferried one for the owner when it
was sold. I do not have any first hand knowledge of what the Kitfox is
like to build or the company's customer service.
Blue Skies!
Rick Pellicciotti
products?
Thanks
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 03:13 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 1st 04 02:31 PM
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 0 September 2nd 04 05:15 AM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 May 1st 04 07:29 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 2 February 2nd 04 11:41 PM
