Hello Todd,
In a recent thread on R.A..S.(interesting question about stall and airspeed) that morphed into a discussion about coffin corner, Todd explained, "Flutter limits high true airspeed operations, and it is possible to get to the coffin corner where stall speed and Vne approach each other." and Jim suggested we "consider Vne as a TAS". Can I have the groups wisdom and further explanation of the reasons for this and of how Vne changes with altitude. Should we be doing preflight calculations of Vne IAS reductions when planning aerobatics at 9000 ft. or soaring or high speed flight at 15-18,000 ft? Thanks in advance |
VNE can be set for a variety of reasons.
Structural strength. This one is probably limited by IAS/CAS Flutter or other dynamics problems. This is releated to the dynamic behavior of the airflow and is most likely a TAS limit. So to really answer the question you need to know what the limiting VNE factor was for your aircraft. .. On Sun, 11 Sep 2005 04:46:58 GMT, "private" wrote: Hello Todd, In a recent thread on R.A..S.(interesting question about stall and airspeed) that morphed into a discussion about coffin corner, Todd explained, "Flutter limits high true airspeed operations, and it is possible to get to the coffin corner where stall speed and Vne approach each other." and Jim suggested we "consider Vne as a TAS". Can I have the groups wisdom and further explanation of the reasons for this and of how Vne changes with altitude. Should we be doing preflight calculations of Vne IAS reductions when planning aerobatics at 9000 ft. or soaring or high speed flight at 15-18,000 ft? Thanks in advance |
snip
On Sun, 11 Sep 2005 04:46:58 GMT, "private" wrote: snip Can I have the groups wisdom and further explanation of the reasons for this and of how Vne changes with altitude. Thank you all for the informative discussion. Happy landings |
private wrote:
Should we be doing preflight calculations of Vne IAS reductions when planning aerobatics at 9000 ft. or soaring or high speed flight at 15-18,000 ft? Certainly. You'll find the numbers in the POH. (In real life, 9000 ft is no issue. Soaring in wave up to 30'000 ft is.) Stefan |
planning aerobatics at 9000 ft. or soaring or high speed flight at 15-18,000 ft? Many gliders capable of Vne around 146 kias below 10,000 MSL actually have lower IAS Vne charted for altitudes above 10,000ft MSL and in 3000ft blocks. The DG1000 has the following limits. Vne at 10,000ft is 146KIAS, 13,000ft is 138KIAS, 16,000ft is 131KIAS, 20,000ft is 114KIAS, 23,000ft is 117KIAS and 26,000ft is 111KIAS Vne is based on IAS, TAS for the same IAS is higher at higher altitudes. But remember, it's not just airspeed, or airspeed indicator errors associated with altitude changes, but also other dynamic "q" factors on the airframe at higher "effective" airspeeds. Many jets have a Maximum operating Mach limit. Vmo would not change with altitude, but the IAS limit associated with that Mach limit will continually decrease as altitude increases. Eventually that Vmo (IAS) gets down to Vstall, and that is the "coffin corner" in a previous post. BT |
poor choice of wording on "Vne is based on TAS" ....
Vne is actually based on other structral limits, flutter, drag buffets, control etc.. and is equated to a value in speed. Not all GA aircraft have Mach Meters or "barber pole" indications, most only have IAS so that is what is used. One can watch the barber pole move with control changes, altitude changes or changes in wing sweep position. BT "BTIZ" wrote in message news:yN_Ue.14282$ct5.10523@fed1read04... Should we be doing preflight calculations of Vne IAS reductions when planning aerobatics at 9000 ft. or soaring or high speed flight at 15-18,000 ft? Many gliders capable of Vne around 146 kias below 10,000 MSL actually have lower IAS Vne charted for altitudes above 10,000ft MSL and in 3000ft blocks. The DG1000 has the following limits. Vne at 10,000ft is 146KIAS, 13,000ft is 138KIAS, 16,000ft is 131KIAS, 20,000ft is 114KIAS, 23,000ft is 117KIAS and 26,000ft is 111KIAS Vne is based on IAS, TAS for the same IAS is higher at higher altitudes. But remember, it's not just airspeed, or airspeed indicator errors associated with altitude changes, but also other dynamic "q" factors on the airframe at higher "effective" airspeeds. Many jets have a Maximum operating Mach limit. Vmo would not change with altitude, but the IAS limit associated with that Mach limit will continually decrease as altitude increases. Eventually that Vmo (IAS) gets down to Vstall, and that is the "coffin corner" in a previous post. BT |
![]() "BTIZ" wrote in message news:yN_Ue.14282$ct5.10523@fed1read04... snip Vne is based on IAS, TAS for the same IAS is higher at higher altitudes. But remember, it's not just airspeed, or airspeed indicator errors associated with altitude changes, but also other dynamic "q" factors on the airframe at higher "effective" airspeeds. Thank you for the informative reply. Please define "q" |
I remember the thread, and I have yet to have the notion that VNE should
be TAS explained satisfactorily. Dave private wrote: Hello Todd, In a recent thread on R.A..S.(interesting question about stall and airspeed) that morphed into a discussion about coffin corner, Todd explained, "Flutter limits high true airspeed operations, and it is possible to get to the coffin corner where stall speed and Vne approach each other." and Jim suggested we "consider Vne as a TAS". Can I have the groups wisdom and further explanation of the reasons for this and of how Vne changes with altitude. Should we be doing preflight calculations of Vne IAS reductions when planning aerobatics at 9000 ft. or soaring or high speed flight at 15-18,000 ft? Thanks in advance |
"private" wrote
"Flutter limits high true airspeed operations, and it is possible to get to the coffin corner where stall speed and Vne approach each other." Can I have the groups wisdom and further explanation of the reasons for this and of how Vne changes with altitude. It is probably not "flutter" that sets the high speed limit, but rather "critical Mach bufett". Yes, even a glider has a Mmo but no mach meter to indicate it, so an equivalent TAS becomes the limit. Copied from a web site: "The critical Mach number is the free stream Mach number at which sonic flow first appears on the airfoil/wing. Buffeting is the structural response to excitation produced by the shock- induced flow separation, and is ultimtely related to the vortex formation and breakdown. Buffeting may affect different parts of the airframe, but the buffeting on the wing is the most important. As the speed increases the wing is affected by shock stall, whose appearance sets an upper limit to the speed. This limit is a function of the flight altitude. Its envelope is called buffeting boundary." Bob Moore |
