H2 Combustion-Booster Claimed
Old September 19th 05, 08:03 AM
Default H2 Combustion-Booster Claimed
Here's one I just read:
http://www.canada.com/montreal/montr...ry.html?id=cfe...
Some fellow is claiming he has a small device that will boost
combustion efficiency and save drivers lots of money, while reducing
emissions.
Obviously, plenty of claims have been made before, so I'm asking --
does this sound on the level?
It sounds reasonable that injecting H2 into your fuel stream can
improve the combustion. I assume that combusting the H2 in your
cylinders along with the regular fuel will boost temperature to give a
cleaner burn. Would the higher temperature harm your engine life at
all?
Since this device supposedly only holds a limited supply of distilled
H2O, KOH, etc which get periodically replaced, can I assume that it's
catalytically cracking some hydrogen from the hydrocarbon fuel stream
itself, so that hydrogen can improve the combustion of the remaining
fuel at the cylinder?
Is this somehow akin to a sort of turbocharger, but which uses hydrogen
instead of pressurized oxygen? Can it work for other things like
aircraft engines, in order to boost their operating ceiling?
Hmm, I dunno, I feel a little puzzled or suspicious of how he's
achieving a net energy gain here. Can anyone debunk any obvious
fallacies here?
Old September 19th 05, 08:23 AM
Jeff
emissions.
Water injection has been around for a long time, both for internal
combustion and aircraft jet engines, it does improve efficiency, reduce
temperatures and reduce some emissions. It depends what is being claimed for
the actual device.
Regards
Jeff
Old September 23rd 05, 04:19 PM
Mike Rapoport
Water injection does not increase efficiency, it lowers it. The water goes
in as a liquid and goes out as a gas. The energy to do that comes from
burning fuel. It will always take more fuel to produce a given amount of
power with water injection than without. Water injection does allow higher
MP or higher compression so the engine can produce more power. Piston
engine fighters used it for more peak horsepower and some turbines use it
for the same purpose but it definately come at the price of higher fuel burn
per horsepower.
Mike
"Jeff" wrote in message
emissions.
for the actual device.
Regards
Jeff
Old September 23rd 05, 07:29 PM
Bill Daniels
"Mike Rapoport" wrote in message
ink.net...
goes
higher
burn
per horsepower.
Mike
Hmm, consulting my ancient copy of Ricardo's "High Speed Internal Combustion
Engines", Sir Harry said that water injection can be substituted for any
excess fuel consumed for the purpose of reducing cylinder temperature and/or
increasing detonation margin. Further, evaporation of the water reduces the
intake charge temperature so as to reduce pumping losses. He goes on to say
that, while there is energy lost to evaporating the water droplets, the
overall fuel economy of an aircraft engine at max power setting will be
improved by use of water injection particularly if the compression ratio has
been increased to take advantage of the increased detonation margin.
Bill Daniels
Old September 24th 05, 04:57 AM
Mike Rapoport
"Bill Daniels" wrote in message
ink.net...
goes
higher
burn
per horsepower.
Mike
Combustion
and/or
say
has
Bill Daniels
Yes, water injection can replace fuel used for cooling. I was not precise
enough in my wording. In the case of using water injection at lower power
settings (where excess fuel for cooling is not used) efficiency will be
reduced. I used water injection in a Corvette that had 11:1 compression to
stop detonation. It worked but power was definately less than with high
octane gasoline and without water injection.
Mike
Old September 24th 05, 02:00 PM
Peter Stickney
ink.net...
water
goes
from
amount of
allow
higher
Piston engine fighters used it for more peak horsepower and some
turbines use it for the same purpose but it definately come at the
burn
per horsepower.
Mike
Combustion
for any excess fuel consumed for the purpose of reducing cylinder
temperature and/or
reduces the
on to say
the overall fuel economy of an aircraft engine at max power setting
will be improved by use of water injection particularly if the
margin.
Bill Daniels
precise
power settings (where excess fuel for cooling is not used)
efficiency will be
compression to
high octane gasoline and without water injection.
That's because you weren't running a lean mixture at high manifold
pressures while the water was going in. An integral part of ADI
(Anti Detonant Injection) systems on the big reciprocating airplane
engines was that the mixture would be leaned much closer to
stochiometric, and specific power and fuel burn would increase.
For example, the Wright R3350-32WA used on the P2V Neptune patrol
airplane, and on most Constellations and DC-7s, burned 45 lbs/minute
at max Dry Power (277 BMEP/2900 RPM), 'bout 3400 HP. The equivalent
info with ADI operating was 34 lbs/min at 301 BMEP/2900 RPM, giving
3700 HP. These engines generally ran on 115/145 Octane fuel.
While you can make water injection work by just dumping water in,
you don't get the full benefit unless you can adjust the fuel flow
properly.
Pete Stickney
Java Man knew nothing about coffee.
Old September 23rd 05, 07:49 PM
burning fuel.
Same thing is true of a steam engine. In a steam engine it is
the phase-change of the water that makes it possible to convert
the heat from burning fuel into mechanical energy.
does allow higher
The thermodynamic efficiency of a heat engine is a function of the
compression ratio. Increasing the compression ratio increases
the efficiency. That is not to say that with water injection
there are not also increased losses that negate that advantage,
but the fact remains that increased compression ratio, absent
other factors, increases efficiency.
Piston
per horsepower.
Ok, I believe you.
FF
Old September 23rd 05, 09:10 PM
Mike Rapoport
goes
burning fuel.
Yes but the steam engine takes the high-energy water vapor and produces
mechanical energy while returning the water as a low energy liquid.
Mike
Old September 24th 05, 04:10 PM
goes
burning fuel.
Actually the conversion to mechanical energy ceases before the vapor
condenses. Condensate in a turbine or even a steam piston is
undesireable.
Regarding water-injection of an internal combustion engine
I would assume the water is injected during the intake stroke,
evaporates completely or almost so near TDC and then mechanical
energy is extracted from the water vapor, along with the combustion
products, during the power stroke. One of those combustion
products was already water, so it's not like such an engine
doesn't already extract energy from expanding water vapor.
There is an increase in entropy associated with the phase change.
That energy is irretreiveably lost and probably accounts for
why the water-injected engine is less efficient than a 'dry'
engine despite the improved thermodynamic efficiency resulting
from the higher compression ratio.
But I'm not about to attempt the math. Entropy always make my
brain hurt.
FF
Old September 23rd 05, 10:26 PM
Big John
Mike
Yep
Big John
On Fri, 23 Sep 2005 15:19:07 GMT, "Mike Rapoport"
per horsepower.
Mike
emissions.
Regards
Jeff
General Zinni on Sixty Minutes WalterM140 Military Aviation 428 July 1st 04 11:16 PM
fetters or fetter's booster? Cy Galley Home Built 11 March 12th 04 10:46 PM
high-speed camera view of a piston intake, combustion, exhaust R.Hubbell General Aviation 0 February 20th 04 03:36 AM
59% increase in pulling power is claimed for an unusual new rotor propeller for airplanes Larry Dighera Piloting 5 November 21st 03 02:13 AM
