Flyers,
This was part of a post in "Selling my Garmin 296" and decided to make it a separate post. Sorry for the redundancy. Kobra wrote: ...I toasted my engine about 3 weeks ago. Urgh. Sorry to hear that. What happened? I have a Cardinal RG with a IO-360A1B6 with 1000 hours on it. On one short 30 min. flight to Cape May, NJ (WWD) I noticed a small amount of oil running down the nose gear door. I did a cursory look and found the oil level unchanged and saw nothing through the oil access door. I wiped it off. On the flight back all oil indicators were fine. When I landed the drip of oil was back. No big oil loss, but when you fly the same airplane you know what's suppose to be there and what's not. I called my mechanic and co-owner and explained the problem. At first the mechanic was not concerned. My partner flew a few days later on a short flight and when he landed the A&P came over to say hello. He then noticed the oil on the gear door. He grounded the plane and the next day called me to the airport. He showed me a pretty good leak coming through something called a "though-bolt" on the number two cylinder. A though-bolt is a long bolt that goes completely through the engine from one cylinder to the other and helps keep the case enlighten and tight. That wasn't the big problem though, he said I could fly with a minor leak at the through-bolt to TBO. Next he did a dye penetrate test and found a crack in the case in front of the number 4 jug at one of the studs for that cylinder. That did it. The engine had to come off, the case split and a new case was ordered. The story goes on though. As he was taking the engine off he found one other interesting item. One of the through-bolt nuts on the bottom of cylinder number 3 was sheared off completely flush the cylinder base. That's when the hair on the back of my neck stood up. I have to think that all this was related as the nut was still laying in the bottom of the engine. This was recent! Next I had a recollection of starting the engine before my flight to WWD and I remember that I heard a "snap!" just as the engine caught. It was loud enough to make me say, "...what the %$#@ was that?!" and just soft enough for me to dismiss it and ponder, "...did you really hear what you think you heard?" The rest is speculation, but maybe that was the nut snapping off and something bad happened in the engine causing the leak at the through bolt on number two cylinder. Maybe the engine was ready to self-destruct in the air on the next flight. Who knows? But I hope to learn more when the engine is broken down and inspected. I will keep you all posted if you are interested. Kobra |
Kobra wrote:
But I hope to learn more when the engine is broken down and inspected. I will keep you all posted if you are interested. I am interested. Thanks for the story and my condolences. -- Peter ----== Posted via Newsfeeds.Com - Unlimited-Uncensored-Secure Usenet News==---- http://www.newsfeeds.com The #1 Newsgroup Service in the World! 120,000+ Newsgroups ----= East and West-Coast Server Farms - Total Privacy via Encryption =---- |
Definitely warrants a separate post. With an 800 hour (SMOH) engine, this
news definitely has raised an eyebrow. Any more stories of "early" overhauls that anyone care to share? Marco Leon "Kobra" wrote in message ... Flyers, This was part of a post in "Selling my Garmin 296" and decided to make it a separate post. Sorry for the redundancy. Kobra wrote: ...I toasted my engine about 3 weeks ago. Urgh. Sorry to hear that. What happened? I have a Cardinal RG with a IO-360A1B6 with 1000 hours on it. On one short 30 min. flight to Cape May, NJ (WWD) I noticed a small amount of oil running down the nose gear door. I did a cursory look and found the oil level unchanged and saw nothing through the oil access door. I wiped it off. On the flight back all oil indicators were fine. When I landed the drip of oil was back. No big oil loss, but when you fly the same airplane you know what's suppose to be there and what's not. I called my mechanic and co-owner and explained the problem. At first the mechanic was not concerned. My partner flew a few days later on a short flight and when he landed the A&P came over to say hello. He then noticed the oil on the gear door. He grounded the plane and the next day called me to the airport. He showed me a pretty good leak coming through something called a "though-bolt" on the number two cylinder. A though-bolt is a long bolt that goes completely through the engine from one cylinder to the other and helps keep the case enlighten and tight. That wasn't the big problem though, he said I could fly with a minor leak at the through-bolt to TBO. Next he did a dye penetrate test and found a crack in the case in front of the number 4 jug at one of the studs for that cylinder. That did it. The engine had to come off, the case split and a new case was ordered. The story goes on though. As he was taking the engine off he found one other interesting item. One of the through-bolt nuts on the bottom of cylinder number 3 was sheared off completely flush the cylinder base. That's when the hair on the back of my neck stood up. I have to think that all this was related as the nut was still laying in the bottom of the engine. This was recent! Next I had a recollection of starting the engine before my flight to WWD and I remember that I heard a "snap!" just as the engine caught. It was loud enough to make me say, "...what the %$#@ was that?!" and just soft enough for me to dismiss it and ponder, "...did you really hear what you think you heard?" The rest is speculation, but maybe that was the nut snapping off and something bad happened in the engine causing the leak at the through bolt on number two cylinder. Maybe the engine was ready to self-destruct in the air on the next flight. Who knows? But I hope to learn more when the engine is broken down and inspected. I will keep you all posted if you are interested. Kobra Posted Via Usenet.com Premium Usenet Newsgroup Services ---------------------------------------------------------- ** SPEED ** RETENTION ** COMPLETION ** ANONYMITY ** ---------------------------------------------------------- http://www.usenet.com |
Saying the engine has 800 hours doesn't really say much. I'd be more
interested in how many years since overhaul. There are a lot of planes for sale out there with low time engines that have sat for many years. I would not feel comfortable flying behind an 800 hour engine if it has sat for 10 years. -Robert |
Robert M. Gary wrote:
I would not feel comfortable flying behind an 800 hour engine if it has sat for 10 years. I'm a little nervous flying behind one that has sat for 6 months. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
Kobra wrote:
My partner flew a few days later on a short flight and when he landed the A&P came over to say hello. He then noticed the oil on the gear door. He grounded the plane and the next day called me to the airport. Sounds like you have a pretty good A&P there. George Patterson Give a person a fish and you feed him for a day; teach a person to use the Internet and he won't bother you for weeks. |
I'd love to know what caused the through bolt to shear or snap.
Thanks for posting. Jim "Kobra" wrote in message ... Flyers, This was part of a post in "Selling my Garmin 296" and decided to make it a separate post. Sorry for the redundancy. Kobra wrote: ...I toasted my engine about 3 weeks ago. Urgh. Sorry to hear that. What happened? I have a Cardinal RG with a IO-360A1B6 with 1000 hours on it. On one short 30 min. flight to Cape May, NJ (WWD) I noticed a small amount of oil running down the nose gear door. I did a cursory look and found the oil level unchanged and saw nothing through the oil access door. I wiped it off. On the flight back all oil indicators were fine. When I landed the drip of oil was back. No big oil loss, but when you fly the same airplane you know what's suppose to be there and what's not. I called my mechanic and co-owner and explained the problem. At first the mechanic was not concerned. My partner flew a few days later on a short flight and when he landed the A&P came over to say hello. He then noticed the oil on the gear door. He grounded the plane and the next day called me to the airport. He showed me a pretty good leak coming through something called a "though-bolt" on the number two cylinder. A though-bolt is a long bolt that goes completely through the engine from one cylinder to the other and helps keep the case enlighten and tight. That wasn't the big problem though, he said I could fly with a minor leak at the through-bolt to TBO. Next he did a dye penetrate test and found a crack in the case in front of the number 4 jug at one of the studs for that cylinder. That did it. The engine had to come off, the case split and a new case was ordered. The story goes on though. As he was taking the engine off he found one other interesting item. One of the through-bolt nuts on the bottom of cylinder number 3 was sheared off completely flush the cylinder base. That's when the hair on the back of my neck stood up. I have to think that all this was related as the nut was still laying in the bottom of the engine. This was recent! Next I had a recollection of starting the engine before my flight to WWD and I remember that I heard a "snap!" just as the engine caught. It was loud enough to make me say, "...what the %$#@ was that?!" and just soft enough for me to dismiss it and ponder, "...did you really hear what you think you heard?" The rest is speculation, but maybe that was the nut snapping off and something bad happened in the engine causing the leak at the through bolt on number two cylinder. Maybe the engine was ready to self-destruct in the air on the next flight. Who knows? But I hope to learn more when the engine is broken down and inspected. I will keep you all posted if you are interested. Kobra |
There aren't a lot of possibilities, are there?
1. The case crack set up a vibration or torque that overstressed the bolt -- and since it happened on startup when things are running less than smooth in a Lyc, I'd bet on this one. 2. The bolt was WWAAAYYY overtorqued on installation. You'll never know about this one. However, a through bolt shearing and a case crack by another through bolt leads me to check the calibration on somebody's torque wrench. 3. Something else in the engine was vibrating ... not likely as the whole AIRplane would have been vibrating to shear a through bolt. 4. Defective bolt ... not likely as throughbolts get magnafluxed or x-rayed at overhaul. 5. (Add yours here) Oh, and BTW, mechanics cannot ground airplanes. IAs cannot ground airplanes. The FAA (unless they pull the airworthiness cert.) cannot ground airplanes. I know it is a common phrase, but the mechanic simply suggested that it would be less than wise to fly the airplane in its current condition. Jim "Jim Burns" wrote in message ... I'd love to know what caused the through bolt to shear or snap. Thanks for posting. Jim |
It could be undertorqued too. In that case there would be a lot of
fretting under the base flange of the cylinder, and probably on the main bearing webs too. If it hasn't been disassembled yet, you might check the other throughstuds to see what torque is required to very slightly further tighten them - giving you an indication of how close to the spec the previous assembler was. Another possibility is the hardness of the thru studs I don't know what the spec is (probably not published ) but maybe Rockwell C = 48 to 52 or so? That engine wouldn't have gone much further at all. You were lucky. |
"nrp" wrote in message oups.com... It could be undertorqued too. In that case there would be a lot of fretting under the base flange of the cylinder, and probably on the main bearing webs too. Yes, but that wouldn't have sheared the bolt at the jug stud ring as the OP said it did. You would get fretting at that location, but I don't see a failure mode in shear. If it hasn't been disassembled yet, you might check the other throughstuds to see what torque is required to very slightly further tighten them - giving you an indication of how close to the spec the previous assembler was. And how much torque it takes to loosen a couple of them. Jim |
| Engine Balancing and Resonance Vibration Problem | AllanFuller | Owning | 13 | September 12th 05 01:51 AM |
| Proposals for air breathing hypersonic craft. I | Robert Clark | Military Aviation | 2 | May 26th 04 07:42 PM |
| Car engine FAA certified for airplane use | Cy Galley | Home Built | 10 | February 6th 04 04:03 PM |
| What if the germans... | Charles Gray | Military Aviation | 119 | January 27th 04 12:20 AM |
| Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 05:09 PM |
