idiot lights
Old September 22nd 05, 02:50 PM
Doug Palmer
Default idiot lights
I need to wire some basic idiot lights for my homebuilt. Some are simple
independent switched light circuits but others indicate motors, such as a
fuel pump is active.
Are there any basic schematics/resources available on the web to show how to
run an indicator in parallel with something like a pump motor. My guess
would be that a diode needs to be included someplace. BTW I will probably
be using LEDs with drop down resistors
Thanks, Doug
Old September 22nd 05, 05:19 PM
RST Engineering
The "D" in LED means Diode, so you will have a diode there whether or not
you want it. The simple answer is that a resistor in series with an LED
across an active circuit (like a motor) will light up. THe problem is the
reverse voltage spike (back EMF) of an inductive circuit like a motor when
it is shut off. You may wish (and probably should) break the current limit
resistor to the LED into two parts and put a fairly hefty snubber diode in
the circuit.
Like so:
+ bus ----- switch ----- motor --- ground
resistor
|------resistor---LEDA-LEDK---ground
diodeK
diodeA
ground
"Doug Palmer" wrote in message
ink.net...
to
Thanks, Doug
Old September 22nd 05, 06:38 PM
ejb
Hi Doug,
I'm planning on doing this kind of thing also.
Can you give some example part numbers for a snubber diode. Are you
referring to zener diodes?
the circuit.
Like so:
resistor
diodeK
diodeA
ground
ink.net...
to
Thanks, Doug
Old September 22nd 05, 06:47 PM
RST Engineering
The 1N400x series are generally hefty enough to use for snubbers. For a
small motor like a fuel pump, I'd probably use a 1N4004 or above.
"ejb" wrote in message
Hi Doug,
Panel lights failure in Piper WarriorII Piperflyer Owning 6 September 23rd 04 07:26 AM
Panel Lights - Need Help Barnyard BOb - Home Built 2 May 29th 04 07:51 PM
Anti collision light mod for Piper Arrow 1968 model? Frode Berg Owning 4 May 20th 04 05:16 AM
Building chasing airport lights -- Attn: Jim Weir? Jay Honeck Owning 79 February 29th 04 02:10 PM
LEDs for Nav Lights - Jim Weir Scott Gettings Home Built 3 February 17th 04 01:53 AM
