Is there a proper phraseology for reporting leaving 33,500? The AIM
doesn't say; it always assumes you're at a whole number flight level. |
![]() "Scott Draper" wrote in message ... Is there a proper phraseology for reporting leaving 33,500? The AIM doesn't say; it always assumes you're at a whole number flight level. Why can't you say FL 335? After all 33,000ft is FL 330. |
Uh....if you're between 18K and 60K in the US, then you are required
to be on an IFR flight plan, hence only at even number altitudes. 33,500 is inappropriate. |
![]() Blanche wrote: Uh....if you're between 18K and 60K in the US, then you are required to be on an IFR flight plan, hence only at even number altitudes. 33,500 is inappropriate. Number one that's wrong. Number two that wasn't the point of the question. |
![]() "Blanche" wrote in message ... Uh....if you're between 18K and 60K in the US, then you are required to be on an IFR flight plan, hence only at even number altitudes. 33,500 is inappropriate. That's not correct. You're required to be on an IFR flight plan in Class A airspace, but not all airspace between 18K and 60K in the US is Class A. By the way, 33,500 IS an even number. |
In a previous article, "Steven P. McNicoll" said:
"Blanche" wrote in message ... Uh....if you're between 18K and 60K in the US, then you are required to be on an IFR flight plan, hence only at even number altitudes. 33,500 is inappropriate. That's not correct. You're required to be on an IFR flight plan in Class A airspace, but not all airspace between 18K and 60K in the US is Class A. By the way, 33,500 IS an even number. Plus 33,500 is a perfectly valid altitude on an IFR flight plan if you're climbing, descending, VFR-OTP, given a block altitude or on a cruise clearance. -- Paul Tomblin http://xcski.com/blogs/pt/ please excuse my typing, but my whole left arm is in a cast. and i don't mean _the king and i_. |
![]() "Paul Tomblin" wrote in message ... In a previous article, "Steven P. McNicoll" said: "Blanche" wrote in message ... Uh....if you're between 18K and 60K in the US, then you are required to be on an IFR flight plan, hence only at even number altitudes. 33,500 is inappropriate. That's not correct. You're required to be on an IFR flight plan in Class A airspace, but not all airspace between 18K and 60K in the US is Class A. By the way, 33,500 IS an even number. Plus 33,500 is a perfectly valid altitude on an IFR flight plan if you're climbing, descending, VFR-OTP, given a block altitude or on a cruise clearance. VFR On Top at 33,500? |
Steven P. McNicoll wrote:
"Blanche" wrote in message Uh....if you're between 18K and 60K in the US, then you are required to be on an IFR flight plan, hence only at even number altitudes. 33,500 is inappropriate. That's not correct. You're required to be on an IFR flight plan in Class A airspace, but not all airspace between 18K and 60K in the US is Class A. By the way, 33,500 IS an even number. My bad. I meant all thousands, not the half thousands that we're used to in VFR. Second my bad...what airspace in the US 18K and 60K is not Class A? Not counting the big mountain in Washington state. (sorry, can't remember the name) |
![]() "Blanche" wrote in message ... Second my bad...what airspace in the US 18K and 60K is not Class A? There's no Class A airspace over Hawaii, the Alaska Peninsula west of longitude 160° 00' 00" West, the California islands Santa Barbara and Farallon, and the Florida keys south of latitude 25° 04' 00" North. Not counting the big mountain in Washington state. (sorry, can't remember the name) I think you mean Alaska. The highest point in the contiguous states is California's Mt. Whithey at 14,494 feet. The airspace above 18,000' but less than 1,500 feet above the surface of the earth in Alaska is not Class A. |
Most reliable homebuilt helicopter? | tom pettit | Home Built | 35 | September 29th 05 02:24 PM |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Washington DC airspace closing for good? | tony roberts | Piloting | 153 | August 11th 05 12:56 AM |
