US FAA to revise Commercial Glider PTS
Old September 23rd 05, 05:50 PM
Terry
Default US FAA to revise Commercial Glider PTS
I received an email from the FAA the other day concerning the normal
revision process for the Commercial Pilot Glider Practical Test
Standards. Here is your chance to influence the regulator and make
your pitch for what should be added, deleted or expanded in the current
flight test. Make your best pitch and good luck for your proposals.
Terry Clausssen
FAA Designated Pilot Examiner
Estrella, Arizona
FAA email:
The following Practical Test Standards are now going through their
revision process. If any Designated Pilot Examiners, Aviation Safety
Inspectors, Flight Instructors or Pilots having any recommendations for
these documents please send an email to AFS-630
COMMERCIAL PILOT PRACTICAL TEST STANDARDS GLIDER FAA-S-8081-23
Old September 23rd 05, 10:31 PM
Terry
The email address was copied incorrectly--drop the hyphen:
afs630comments at faa dot gov. Remember the fed's are here to help and
waiting for your thoughtful input.
Terry Claussen
Old September 28th 05, 03:07 PM
Hello Terry, and all other USA CFI-G's and Designated Pilot Examiners.
Please copy your comments and any others you receive regarding the
proposed rewrite of the FAA Com-Glider PTS to the Soaring Safety
Foundation. You can copy/forward them to me at and
I will relay them to the SSF.
The SSF, as the training and safety unit of the SSA, will compile the
suggestions and send them to FAA as a comprehensive commentary to the
FAA.
Burt Compton, Master CFI, FAA DPE
SSF Trustee
Marfa, Texas
Terry Claussen
Old September 30th 05, 05:58 PM
Terry
That sounds like a common sense use of the SSF or SSA website.
Power Commercial to Glider Commercial Mitty Soaring 24 March 15th 05 03:41 PM
Glider cross-country time toward commercial SEL requrements? Matt Michael Soaring 17 November 25th 04 04:45 PM
Bad publicity David Starer Soaring 18 March 8th 04 03:57 PM
Did commercial glider pilots used to give instruction? Mark James Boyd Soaring 7 December 19th 03 07:51 AM
Part 91 Commercial Glider Rides to be Outlawed? Vaughn Soaring 9 October 27th 03 09:26 PM
