Landing Light Flasher Circuit
Old January 12th 05, 04:51 PM
ELIPPSE
Default Landing Light Flasher Circuit
If you are looking for a simple, inexpensive, somewhat easy to make
light-flasher for your landing lights, check this out:
geocities.com/eaa170/techc/AircraftLightFlasher.pdf .
Old January 12th 05, 06:05 PM
RST Engineering
1. The URL given pops up "Page Not Found". Try this instead:
www.geocities.com/eaa170/techc/ and then click on the Aircraft Light Flasher
pdf file.
2. The difficulty with this circuit is that we generally expect one side of
both lamps to be grounded, one a taxi lamp and one a landing lamp. This
design requires both sides of one lamp to be floating.
3. There is a different way of doing it, with both lamps grounded at one
terminal, and using an inrush current limiter to achieve the same goals at
http://www.rst-engr.com/kitplanes/KP0003/KP0003.htm . This design also
uses FETs that are a little easier to come by than the ones suggested in the
referenced article.
"ELIPPSE" wrote in message
"bush flying" in the suburbs? [email protected] Home Built 85 December 28th 04 11:04 PM
Would a 3 million Candlepower spotlight make a good landing light? Legrande Harris Home Built 6 June 15th 04 06:32 AM
Off topic - Landing of a B-17 Ghost Home Built 2 October 28th 03 04:35 PM
Effect of Light Sport on General Aviation Gilan Home Built 17 September 24th 03 06:11 AM
Landing Gear Lights-Need Wiring Help BG Home Built 2 August 16th 03 11:21 PM
