Builders who plan to fly in mountains needing higher altitude should
consider their engine choices. Typical Lycoming low compression engines have a limit of about 13,500 feet. You need higher compression engines or turbocharging for higher altitudes. I tested my high compression (10.5) Franklin 6A-350 to 18,000 legal VFR limit and quit - still was doing about 200ft/min. A friend of mine with a 0-320 maxed out at 13,300. ----------------------------------------- SQ2000 canard: http://www.abri.com/sq2000 |
![]() "abripl" wrote in message ups.com... Builders who plan to fly in mountains needing higher altitude should consider their engine choices. Typical Lycoming low compression engines have a limit of about 13,500 feet. You need higher compression engines or turbocharging for higher altitudes. I tested my high compression (10.5) Franklin 6A-350 to 18,000 legal VFR limit and quit - still was doing about 200ft/min. A friend of mine with a 0-320 maxed out at 13,300. ----------------------------------------- SQ2000 canard: http://www.abri.com/sq2000 Yes, and consider the ignition source. The loss of one magneto, like the loss of one engine in a twin, will decrease altitude performance dramatically. In many cases, the remaining performance won't keep you above terrain. Been there, done that, have the new seat cushion to prove it. Bill Daniels |
Some of the LOM engines are supercharged in their stock form. I
suspect they would provide good high altitude performance, but don't have any data to back that up. Anybody fly one of their boosted engines up high yet? -Matt |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
ROP masking of engine problems | Roger Long | Piloting | 1 | September 25th 04 07:13 PM |
Engines and Reliability | Dylan Smith | Piloting | 13 | June 30th 04 03:27 PM |
Diesel engine | Bryan | Home Built | 41 | May 1st 04 07:23 PM |
Motorgliders and gliders in US contests | Brian Case | Soaring | 22 | September 24th 03 12:42 AM |
