Was talking with some WW2 guys who remembered the use of 10 gauge shotgun
shells to start an aircraft engine. I've seen several movies showing something but my question is how did it work? shell in seperate cylinder from pistons and how push crank over, etc?? |
From what I have read, the output of the firing mechanism, which was really
only a large column of moving air, was fed directly into one of the existing cylinders. If you can get your hands on a copy of the original version of "The Flight of the Phoenix", there's a scene where Jimmy Stewart (who had been a B-24 bomber pilot in WWII), is trying to start a cobbled-together aircraft with a shotgun starter. He only has a limited number of shells; naturally, it starts on the last one. BTW: Did you know that ejection seats were once powered by cannon shells? "Dick" wrote in message t... Was talking with some WW2 guys who remembered the use of 10 gauge shotgun shells to start an aircraft engine. I've seen several movies showing something but my question is how did it work? shell in seperate cylinder from pistons and how push crank over, etc?? |
Lakeview Bill
Yep. 37mm. Used to have one as a desk ornament. I rode the training tower at Willie using these shells. All the jet Pilots and students had to ride tahe ejection training tower. Big John `````````````````````````````````````````````````` `````````````````````````````` On Fri, 30 Sep 2005 21:35:40 GMT, "Lakeview Bill" wrote: From what I have read, the output of the firing mechanism, which was really only a large column of moving air, was fed directly into one of the existing cylinders. If you can get your hands on a copy of the original version of "The Flight of the Phoenix", there's a scene where Jimmy Stewart (who had been a B-24 bomber pilot in WWII), is trying to start a cobbled-together aircraft with a shotgun starter. He only has a limited number of shells; naturally, it starts on the last one. BTW: Did you know that ejection seats were once powered by cannon shells? "Dick" wrote in message et... Was talking with some WW2 guys who remembered the use of 10 gauge shotgun shells to start an aircraft engine. I've seen several movies showing something but my question is how did it work? shell in seperate cylinder from pistons and how push crank over, etc?? |
![]() Dick wrote: Was talking with some WW2 guys who remembered the use of 10 gauge shotgun shells to start an aircraft engine. I've seen several movies showing something but my question is how did it work? shell in seperate cylinder from pistons and how push crank over, etc?? Its called a Kauffmann (sp?) starter. The blast turns a turbine thats geared in to the crankshaft somehow. See the movie Flight of the Phoenix... the original w/ Jimmy Stuart, not the gawd-aweful remake. Harry |
Is it an inertia type starter? I've never seen one but I always assumed
that it was like the air start on the M14P. "wright1902glider" wrote in message oups.com... Dick wrote: Was talking with some WW2 guys who remembered the use of 10 gauge shotgun shells to start an aircraft engine. I've seen several movies showing something but my question is how did it work? shell in seperate cylinder from pistons and how push crank over, etc?? Its called a Kauffmann (sp?) starter. The blast turns a turbine thats geared in to the crankshaft somehow. See the movie Flight of the Phoenix... the original w/ Jimmy Stuart, not the gawd-aweful remake. Harry |
Try this link for info:
http://www.sjvls.org/bens/bf010cs.htm J. Severyn KLVK "Dick" wrote in message t... Was talking with some WW2 guys who remembered the use of 10 gauge shotgun shells to start an aircraft engine. I've seen several movies showing something but my question is how did it work? shell in seperate cylinder from pistons and how push crank over, etc?? |
It's a Coffman, or Eclipse starter. Gun gases spun a wheel, which
could also be spun by hand or foot treadle, an electric motor, or other means in some versions. They were not totally unique to aircraft, a few were used in military vehicles and other oddball applications. They were generally junked and replaced by direct drive electric starters when they became available. Cartridge start was also used on jets. Various bombers and fighters have had cartridge start, as did some civilian aircraft. Boeing 727s sometimes had cartridge start on the center engine (don't ask me how I know...) so the aircraft could start if it diverted to a field with no start cart. You had one shot, then you called out the recovery team. I think United had a Lear for things like that, otherwise, another revenue aircraft had to be internal-chartered, if no other airline had a maintenance presence on field. |
Cool, I knew/heard about these cartridge starters, now I know about the
third engine on the 727. Thanks for the additional info. Bryan "The Monk" Chaisone |
The British Camberra used them. It's a high altitude spy plane that we licensed the design for, so that we could turn it into the U-2. One of the changes we made was to get rid of the cartridge start, because the huge mass of black smoke was considered "not high tech." |
In article .com,
"jmk" wrote: Cartridge start was also used on jets. The British Camberra used them. It's a high altitude spy plane that we licensed the design for, so that we could turn it into the U-2. One of the changes we made was to get rid of the cartridge start, because the huge mass of black smoke was considered "not high tech." Canberra and U-2 were totally separate aircraft! U-2 was a single-engine, indigenous Lockheed design, based on high-performance sailplanes of the day. Canberra was a twin-engined British design for a high-altitude bomber. The Martin Co. modified the Canberra into the B-57; the special reconnaisance aircraft was the "RB-57D/E," which looked somewhat like the B-57, but with much longer wings and different engines. |
Toronto Area Glider Pilot Ground School Starts Thu. February 24, 2005 | Ulf | Soaring | 0 | February 3rd 05 06:16 PM |
EAA Airventure 2005 Starts on a Monday | Fitzair4 | Home Built | 9 | September 21st 04 03:04 AM |
Air Force Raptor fighter starts operational trials, By John J. Lumpkin | Otis Willie | Military Aviation | 0 | May 1st 04 10:18 PM |
Training starts with aerospace physiology | Otis Willie | Military Aviation | 2 | December 4th 03 11:03 AM |
Toronto Area Glider Pilot Ground School Starts Wed. November 19 | Ulf | Soaring | 0 | November 1st 03 11:09 AM |
