New Cessna
Old October 4th 05, 05:01 PM
gwengler
Default New Cessna
I talked to someone who has seen a drawing of the new Cessna line of
models. It will be high wing and it is planned to have four doors. Up
to six seats should be possible. The cabin width will be 54". The
interior will be more "automotive" style with G1000 avionics. It will
be as fast as the Cirrus airplanes. The engine hasn't been decided,
but apparently Cessna is considering a Diesel engine as an option. A
turbo charged engine will be an option for sure. Plastic or metal
hasn't been decided either; however, Cessna's long term aluminum
supply contract will end in 2007.
Gerd
Old October 4th 05, 06:11 PM
Interesting. I read a while back that SMA or Thielert was talking to "a
major OEM airframe mfr" about providing engines for future aircraft.
The four-door idea is curious though, I don't recall Cessna ever doing
that before in a single.
Plastic or metal hasn't been decided either; however, Cessna's long term aluminum
Is this the same company (Alcoa?) that sold them bad stock that ended
up on the '97 model year 172/182? I can't imagine (although I'd love to
see it) them building a composite aircraft because of the high
development cost involved(?)
It will be as fast as the Cirrus airplanes. The engine hasn't been decided
Seems that maybe they ARE thinking glass? To go that fast with a diesel
would require pretty high HP and a slick airframe IMO. It would be neat
to see Cessna break the mold in a big way and come out with something
really spectacular.
Old October 5th 05, 02:07 AM
George Patterson
Matt Whiting wrote:
You don't need glass to make a slick airframe.
No, but the slickest ones use compound curves, which are much more easily made
using composites.
George Patterson
Drink is the curse of the land. It makes you quarrel with your neighbor.
It makes you shoot at your landlord. And it makes you miss him.
Old October 5th 05, 05:11 AM
Dave Stadt
"George Patterson" wrote in message
news:4HF0f.3921$WD5.549@trndny06...
made
using composites.
Slickest and fastest are made of metal.
George Patterson
neighbor.
Old October 5th 05, 11:21 AM
Matt Whiting
easily made using composites.
Only if you are talking making them by hand or with low volume
production equipment. If hydroforming or stretch forming equipment is
used, compound curves in metal are much faster to make than in composite
materials. It is hard to be essentially a pressing/stamping process for
speed, once you make the capital investment required to do this.
Detroit makes all sorts of compound curves in metal at costs much less
than for composites. Ask GM which is cheaper to produce, the metal body
for a large sedan or the fiberglass body of the Vette.
Matt
Old October 5th 05, 04:45 PM
George Patterson
But that's what you're doing if you're building light aircraft.
George Patterson
Old October 5th 05, 06:39 PM
The 210 already goes as fast as a Cirrus
It certainly does. My point was that kind of speed requires HP (and a
clean airframe) and IIRC the highest power aviation diesel now is the
230hp SMA. I'm not sure if that's enough for a 180kt cruise. I'd love
to see an updated Cardinal with flush-riveted skin and the latest aero
tweaks, if that's what Cessna has in mind.
1/72 Cessna 300, 400 series scale models Ale Owning 3 October 22nd 13 03:40 PM
Wow - heard on the air... (long) Nathan Young Piloting 68 July 25th 05 06:51 PM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Owning 1 November 4th 03 12:57 AM
