The weather's great this time of year in Northern California and
almost perfect for flying. Nevertheless I was getting bored with the same $25 lunch trips which now were approaching $50. I wanted something different that might also cause me to learn something new. So last weekend I thought I'd teach myself to fly from the right seat. Straight-off I gotta say, don't try this in a touchy or complicated aircraft without an instructor. But I figured I could do it by myself in my Aircoupe. I took off from my home airport using the left seat as always to hop over to an airport just a few miles away that has a much wider and longer runway, 6000x100 feet. That offered more room to learn, though it also had a right-hand pattern which I don't often practice. But maybe that would work out well from the right-hand seat! I landed and taxied over to the fuel pumps, where there is a little room to park for a bit, and shut down. Switching to the right seat was easy: just slide on over, strap on the harness on the new seat and snug it closed the vacated seat. OK, let's see how things look.... Was I still in the same plane? I was amazed at how different everything was. I instinctively reached for the control wheel with my left hand, and didn't find the push-to-talk switch: it was on the right side of the yoke for the right hand. My right hand was grasping for a throttle which wasn't there; a moment later I watched my left hand fumble around trying to find the ignition switch and starter. OK, this is going to require some deliberate thought. I practiced finding the controls and thought I was ready. My usual start sequence is mixture in, master on, pump throttle once (no primer knob), pull starter, let the prop turn about two seconds, turn the ignition key to both; after the engine catches generator toggle on, strobe toggle on, avionics toggle on. which I can do without thinking and have the engine ticking over within 15 seconds; from the right seat it took almost a minute for my hands to figure out what they were supposed to do and get things turning. Taxing was interesting too. The Aircoupe has toe brakes on both rudder pedals on the left seat which operate the mains together, no independent brakes. The right seat has only one toe brake on the left rudder pedal. This makes it hard to brake and turn to the left at the same time, but I dodged the fuel pumps and slowly made my way to the runup area. By now I was getting a little more accustomed to the odd sight picture and my hands were acquiring new reflexes. A runup gave me a bit more practice and time to takeoff. Acceleration was easy enough, but the first surprise came at rotation and liftoff. The sight picture during climb was very different from what I was used to, and the airspeed indicator was far, far away. Fortunately the Coupe is a forgiving airplane so up we struggled to pattern altitude. Turns were another shock but at least I had a great view of the runway with the right-hand pattern. The real test would come during landing. 100 hours of J-3 Cub time helped a little, as that too required right hand on stick, left on throttle. I concentrated deliberately on the throttle in case I needed to save the landing, but the wide, long runway allowed for a safe but sloppy touchdown. No touch-and-go this time. I let the plane slow, taxied off, and paused for a second. One trip around the pattern accomplished. How had it been? The difference in a mere change of seating surprised me, yet I felt reasonably safe throughout, though certainly challenged at times. I felt good for another couple of pattern trips. After a few landings the strangeness was over. My reflexes were still slow and an engine-out emergency or similar would have tested my new skills to the maximum, but it was worth the experience. Still in the right seat, I departed again, this time to practice slow flight, stalls, and steep turns. When I finally landed at my home base over an hour later I was satisfied. I will practice right-seat flying some more to polish the skills and keep learning. Eventually when it is natural I can offer passengers or fellow pilots the left seat should they wish to see what it's like to fly a Coupe from the proper position. A new skill acquired instead of redoing an old lunch trip. |
"Bob Fry" wrote in message
... So last weekend I thought I'd teach myself to fly from the right seat. Straight-off I gotta say, don't try this in a touchy or complicated aircraft without an instructor. But I figured I could do it by myself in my Aircoupe. When I finally landed at my home base over an hour later I was satisfied. I will practice right-seat flying some more to polish the skills and keep learning. Eventually when it is natural I can offer passengers or fellow pilots the left seat should they wish to see what it's like to fly a Coupe from the proper position. A new skill acquired instead of redoing an old lunch trip. Bob, Great report! I have thought about trying some right-seat flying in my Ercoupe but I think I'll get another pilot or CFI to ride with in the left seat before I try it solo. Mine has a bit different starting sequence and doesn't have those rudder pedal thingies, only a single brake pedal on the left side. I did try taxiing once from the fuel pumps to my hangar from the right seat, about 50 yards without much problems. If I ever decide to go for the Sport Pilot CFI add-on to do some SP training in my Ercoupe, I'll get some right-seat training and practice. -Greg B. (remove dot) |
I flew my cherokee from the right seat once. Coming back from Oshkosh with
another pilot. I gave him the left seat for the return trip. I landed once, pretty badly on a 150 x 7000 runway. Since that time, I have forced myself to taxi from the right seat any time I won't be taking off. Typically to the gas pumps. It's also a little easier as the cherokee only has a door on the right, so I don't have to climb over to the left seat. I'll have to find someone to sit in the left seat for me one of these days. "N93332" wrote in message ... "Bob Fry" wrote in message ... I did try taxiing once from the fuel pumps to my hangar from the right seat, about 50 yards without much problems. |
Steve Foley wrote:
Since that time, I have forced myself to taxi from the right seat any time I won't be taking off. Typically to the gas pumps. It's also a little easier as the cherokee only has a door on the right, so I don't have to climb over to the left seat. I've always taxied from the fuel pump to tie down from the right seat for exactly that reason. I've been threatening to actually fly from the right seat, but fortunately for those that share the airport with me, I have yet to do so. -m -- ## Mark T. Dame ## VP, Product Development ## MFM Software, Inc. (http://www.mfm.com/) "Never underestimate the power of a Dark Clown!" -- Tripping The Rift: Darph Bobo |
![]() "Mark T. Dame" wrote I've been threatening to actually fly from the right seat, but fortunately for those that share the airport with me, I have yet to do so. I have always wondered where flying from the left seat for the PIC came from. It seems like the proper way (rules of right of way in consideration) would be like the boaters do. Anyone know when and why this convention started? -- Jim in NC |
"Morgans" wrote:
"Mark T. Dame" wrote I've been threatening to actually fly from the right seat, but fortunately for those that share the airport with me, I have yet to do so. I have always wondered where flying from the left seat for the PIC came from. It seems like the proper way (rules of right of way in consideration) would be like the boaters do. Anyone know when and why this convention started? Appers to have originated with the Wright brothers: http://www.aopa.org/pilot/100/news0308.html "The Wrights moved to a seated pilot position and upright hand controls with the prototype airplane made in 1908 for the U.S. Army Signal Corps. Additionally, another seat with dual controls was added at this time. The pilot controlled the throttle with the left hand, and the wing warping, rudder, and elevator with the right hand. The pilot sat in the left seat. In 1909, on a Model B aircraft, the brothers modified this scheme for their first "left-handed" pilot, Walter Brookins, who sat in the right seat and worked the wing-warping controls with his left hand. That way he could train students sitting in the left seat. A foundation for modern instructing was born." |
![]() " "Mark T. Dame" wrote I've been threatening to actually fly from the right seat, but fortunately for those that share the airport with me, I have yet to do so. Morgans" wrote in message ... I have always wondered where flying from the left seat for the PIC came from. It seems like the proper way (rules of right of way in consideration) would be like the boaters do. How do the boaters do? My boat has a left hand steering position. Allen |
![]() Bob.. I have yet to fly from the right seat solo in a plane that is typically piloted single pilot from the left. When I was "teaching" myself to fly right seat, I always had a rated pilot who was checked out in the plane in the left seat who I could hand things back over to, or have manipulate any switches/levers that were not within easy reach. It might be prudent for you to consider bringing along someone who is familiar with the plane from the left seat, to serve as a backup.. especially when you are dealing with things that look "different" from the right, like crabbed crosswind landings and such. Just a thought, and no matter what, ENJOY. Its nice to be able to take newly minted pilot friends and let them share the joy of flying from the (comfort of the) left seat. Its also a good start for working on your CFI. Having the skills mastered from the right lets you focus on the "instructional" part of the process of becoming a CFI. Dave |
When I started my CFI training, the biggest hurdle I faced was geting
used to the right seat. The thing you mentioned about using the wrong hand to use the radio and throttle happened to me too. My biggest problem though, was coordination. I couldn't land the plane without sideloading to save my life. I guess all the cues I got for lining myself up was dependant on where I sat... After about 10 flights, and 6 or so flight hours later, I'm pretty well adjusted to it. |
Sounds pretty good! I have been flying right seat myself lately in a
172. I'll be doing all my commercial training right seat so I can take the CFI exam the week after I do the commercial. My evil instructor made me do a right seat partial panel night ILS in IMC the other day. It wasn't pretty. Bob Fry wrote: The weather's great this time of year in Northern California and almost perfect for flying. Nevertheless I was getting bored with the same $25 lunch trips which now were approaching $50. I wanted something different that might also cause me to learn something new. |
Nearly had my life terminated today | Michelle P | Piloting | 11 | September 3rd 05 02:37 AM |
Gyrocopter Speed | Mark | Rotorcraft | 36 | August 16th 05 11:28 PM |
Cuban Missle Crisis - Ron Knott | Greasy Rider© @invalid.com | Naval Aviation | 0 | June 2nd 05 09:14 PM |
Logging Right Seat Time | CloudyIFR | Instrument Flight Rules | 41 | May 25th 05 12:48 PM |
Wife agrees to go flying | Corky Scott | Piloting | 29 | October 2nd 03 06:55 PM |
