a (hopefully) simple quaternion question
Old October 5th 05, 07:26 PM
Default a (hopefully) simple quaternion question
Say my aircraft is in a current orientation of
phi (roll, x-axis) = 0 degrees
theta (pitch, y-axis) = 30 degrees
psi (yaw, z-axis) = 20 degrees
which corresponds to a quaternion
Q = 0.952 + 0.045i + 0.255j + 0.168k
But my desired orientation is
phi = 0 degrees
theta = 0 degrees
psi = 0 degrees
-OR-
Q = 1 + 0i + 0j + 0k
If I am thinking in terms of Euler notation, then I know there is a
pitch error of 30 degrees and need to deflect the elevator to correct
this. Likewise, the 20 degree yaw error must be countered by rudder
deflection. However, if I'm thinking in terms of quaternions, then how
can I go about this?
Thanks in advance,
weg
Old October 6th 05, 01:01 PM
john hawkins
I think you better post this one to sci.aeronautics
it has more engineers that this one.
phi = 0 degrees
theta = 0 degrees
psi = 0 degrees
-OR-
Thanks in advance,
weg
Simple Green Pirep JJS Owning 13 May 19th 05 03:35 AM
millionaire on the Internet... in weeks! Malcolm Austin Soaring 0 November 5th 04 11:14 PM
Handheld battery question RobsSanta General Aviation 8 September 19th 04 03:07 PM
A question on Airworthiness Inspection Dave S Home Built 1 August 10th 04 05:07 AM
Phoenix AIM-54A (QUESTION) Krztalizer Naval Aviation 10 February 23rd 04 07:22 AM
