Flying on the Cheap - Again
Old January 22nd 05, 02:30 AM
Default Flying on the Cheap - Again
To All:
A fellow homebuilder spotted a female air-hose quick-connect fitting on
a fuel I'd just finished sloshing (riveted aluminum tank) and told me
he hadn't bothered to pressure-test his tank since it was gravity feed
and he figured just filling it up was enough of a test. He went on to
say that it hadn't leaked so I guess he was right.
I didn't bother to tell him the fitting wasn't there for the purpose of
pressure-testing.
Heat the end of your 2-ply fuel line in oil, you can push it onto a
female air-hose quick-connect fitting. Safety wire or even a
hose-clamp for the rich *******s, you got yourself a fuel-line fitting.
Why? Because it costs less than half a buck and works perfectly well.
Gettem from Harbor Freight. Three females and one male, plus a
quick-connect coupler. Wait for the sale, you can pick up the kit for
$1.79 (otherwise, it's about $3).
No big deal? Maybe not, if you got lots of money to waste.
Personally, I prefer aluminum tubing for fuel, vent & vacuum lines.
Old habits, etc. But if you have to squeeze ever nickle until the
buffalo farts, hose is makes pretty good sense. When properly
installed & supported, frequently inspected and periodically replaced,
hose can be made to serve for the plumbing in a minimum-cost,
VW-powered puddle jumper. Assuming you've got a drawer full of
fittings.
Back around Thanksgiving I reached in the drawer and came up empty and
the local auto-parts place wanted something like three bucks for ONE
1/4"-NPT to hose fitting, I needed four of them and they only had the
one in stock. I could turn them up on the lathe faster than they could
order them but on the way home I stopped by the Harbor Freight store in
Escondido and they had a whole bin of air-hose fittings on sale.
Bought a bunch. Worked fine.
They're cast brass rather than extruded. And only come in straights,
male or female. But a gravity-feed system doesn't see any pressure to
speak of and space isn't at a premium in this particular airframe so
straight works okay.
Yeah, it's outside the box. No, it isn't unsafe; not when properly
installed. And the proof is no farther away than testing it for
yourself.
-R.S.Hoover
Old January 22nd 05, 10:06 AM
Ken Reynolds
Excellent idea Bob
What about the effect of the fuel on the rubber or whatever seals in the
couplings.
Ken
To All:
pressure-testing.
fittings.
yourself.
-R.S.Hoover
Old January 22nd 05, 11:46 AM
Ken Reynolds wrote:
Excellent idea Bob
couplings.
Dear Ken,
You don't use the quick-disconnect couplings, just the straight,
one-piece fittings, over which you slide the hose, secured with safety
wire or hose-clamps.
-R.S.Hoover
Old January 22nd 05, 12:52 PM
Blueskies
wrote in message ups.com...
Ken Reynolds wrote:
Excellent idea Bob
couplings.
Dear Ken,
-R.S.Hoover
Yup, and you could even chuck it in the lathe turn some 'barbs' on it if you really wanted to...
Old January 23rd 05, 03:20 PM
Vaughn
"Blueskies" wrote in message
om...
really wanted to...
True, but I am mystified why you would bother. I am holding in my hand a
nice brass NPT to hose barb fitting that I purchased at Ace hardware just
yesterday for 57 cents. Just how many of those things do you use in a
homebuilt and how much is your time worth?
Vaughn
Old January 23rd 05, 04:25 PM
Blueskies
"Vaughn" wrote in message
"Blueskies" wrote in message om...
True, but I am mystified why you would bother. I am holding in my hand a nice brass NPT to hose barb fitting that
I purchased at Ace hardware just yesterday for 57 cents. Just how many of those things do you use in a homebuilt and
Vaughn
I think the original issue was the parts were not available. The ones identified are steel, also. I don't see the need
for the 'barbs' now that I have seen the actual parts.
Old January 22nd 05, 03:21 PM
Morgans
wrote
Dear Ken,
-R.S.Hoover
You have me good and confused. If you are talking about the coupling that
comes three of one kind and one of the other kind in a pack, and are quick
connect, the three are of the "male" designation, not the female as you
posted. Then, of course, you can get male or female pipe threads on either
of the types of couplings.
Or are you talking about the barbed fittings you can get that are used for
air hose repairs?
I like reading your write-ups, but this one lost me.
Jim in NC
Old January 22nd 05, 07:54 PM
Dave S
Morgans wrote:
wrote
Dear Ken,
-R.S.Hoover
air hose repairs?
i THINK he is saying... use the male end of the "quick connect fittings"
the part with no moving parts, no o rings... just a metal fitting... and
use it as a poor mans "barb". Of course, you could just as easy go to a
tool store and get barbed fittings too for not a whole lot more.
Dave
Old January 22nd 05, 09:11 PM
coupling that
quick
you
posted.
Whatever.
I was picking them out of a bin, onesy-twosy, found out about the kit
later, obviously mis-read (or mis-typed) its description. Sorry for
the confusion.
I used a female fitting and a modified nipple as a bulkhead fitting
(ie, to the gascolator), male fittings everywhere else.
used for
air hose repairs?
Definitely not.
-R.S.Hoover
Old January 23rd 05, 05:04 AM
flybynightkarmarepair
http://www.harborfreight.com/cpi/cta...emnumber=42444
Brass
http://www.harborfreight.com/cpi/cta...temnumber=4873
Steel
Picture jamming the hose over the part of the coupling that normally is
the "Male" part of the quick release coupling.
Compare to:
http://tinyurl.com/6r8wg
although this may not the the exact equivalent size for the hose Bob is
using, you get the picture.
Marske Flying Wing discussion Group mat Redsell Home Built 0 September 19th 04 01:58 PM
How many non flying pilots John Home Built 19 September 17th 04 04:16 AM
Goodyear Brake Pucks - Cheap! Ron Wanttaja Home Built 7 July 16th 04 06:45 AM
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 05:07 PM
Flying Wing Design workshop in july 04 mat Redsell Home Built 1 May 5th 04 01:53 PM
