Hi Warrior/Cherokee pilots...
How full do you keep your engine? (oil level? ) Seems anything above 6 1/2 it just leaves... 5 1/2 - 6 it hardly consumes any oil at all... Ours is 1976 150 hp Lyc, 600 hrs SMOH, 4 new cyls 60 hrs ago. Compression all 73 - 76 Aircraft is new to us, we learning it... ![]() Thoughts? Dave |
It depends on your engine. In my IO-360 lycoming, I used to keep 8
quarts. Then, after about 500SMOH the engine started to blow out anything above 7 quarts. It depends how much blow by you get on your cylinders, I think. I teach in a Warrior, and I know the book says you can run it on very little oil but I would want to keep at least 6 quarts in it. |
Yep, we always kept 6 quarts in our O-320-powered Warrior. Anything above that just blew overboard. We kept 8 quarts in O-360-powered Archers, for the same reasons. And we now keep 9-10 quarts in our O-540-powered Pathfinder. Of course, now we have an air/oil separator, so we *could* keep 12 quarts in it... -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" "Dave" wrote in message ... Hi Warrior/Cherokee pilots... How full do you keep your engine? (oil level? ) 5 1/2 - 6 it hardly consumes any oil at all... Ours is 1976 150 hp Lyc, 600 hrs SMOH, 4 new cyls 60 hrs ago. Compression all 73 - 76 Aircraft is new to us, we learning it... ![]() Thoughts? Dave |
On Tue, 11 Oct 2005 03:59:40 +1300, Dave Doe wrote:
You *will* keep 12 quarts in it - after you've experienced a serious oil leak in flight. From 12 down to 10 in a 235 IS a serious oil leak. Only takes about 40 minutes to blow out the first qt, and about another hour for the second. z |
For my IO360 (8 qts suggested) I fill to 7, don't re-fill until it
drops below 6. |
![]() "Paul kgyy" wrote in message oups.com... For my IO360 (8 qts suggested) I fill to 7, don't re-fill until it drops below 6. ditto |
Dave wrote:
Hi Warrior/Cherokee pilots... How full do you keep your engine? (oil level? ) Seems anything above 6 1/2 it just leaves... 5 1/2 - 6 it hardly consumes any oil at all... Ours is 1976 150 hp Lyc, 600 hrs SMOH, 4 new cyls 60 hrs ago. Compression all 73 - 76 Aircraft is new to us, we learning it... ![]() Thoughts? Dave We don't put much more than 6 quarts in our 67 Arrow. Matt |
slow roll in a super decathlon | Nobody | Aerobatics | 4 | August 24th 05 02:36 AM |
Below sea level | Hilton | Piloting | 13 | June 14th 05 04:42 PM |
Displaced AFSS "controllers" heading for BIL and GRB | Chip Jones | Instrument Flight Rules | 12 | April 10th 05 09:22 PM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Date of effect now 1 April 2004 for revised IGC-approval for certain legacy types of GNSS flight recorder | Ian Strachan | Soaring | 56 | December 2nd 03 08:08 AM |
