I have a newly overhauled engine. Previously, I had a quick drain with a
barb connector to allow using a hose to drain the oil in a bucket. I just stuck a lenght of garden hose on the barb and opened it up. I now have this quick drain that has no barb connection. I don't see any threads to put a barb connection. I would guess I'm probably not the only person in the universe that has this problem. Any suggestions? Thanks. |
If you want the hose permanently attached, find a hose that fits as tightly
as possible, drill and pop rivet the hose onto the nipple, dab RTV into the holes and around the top of the hose before you rivet if you want. Safety wire it tightly above and below the pop rivets, add a hose clamp in the middle, over the pop rivets, if you feel it will help. Jim "dlevy" wrote in message ... I have a newly overhauled engine. Previously, I had a quick drain with a barb connector to allow using a hose to drain the oil in a bucket. I just stuck a lenght of garden hose on the barb and opened it up. I now have this quick drain that has no barb connection. I don't see any threads to put a barb connection. I would guess I'm probably not the only person in the universe that has this problem. Any suggestions? Thanks. |
You might want to consider not putting any permanet hose on as anything
that touches or cocks the hose under the cowl will cause the quick drain to leak - sometimes to the point of losing all the engine oil. There is the classic engine failure story of the A/C that bumped the hose with the nosewheel on retraction and dumped all the oil overboard. Bad day............ |
Thats an easy question.. Demand the shop that did the overhaul to
replace the original fitting. By them changing it to another style without a 337 is probably not kosher,,,, If ya can't get them to admit to the fact they" altered" the certified version then a call to the feds is in order, that should **** someone off for sure. |
Most likely the quick drain installed on the old engine was not "kosher", no
old entry in the engine logs installing the quick drain, and the engine shop put it back to specs. Be careful who you call... and for what. BT wrote in message ups.com... Thats an easy question.. Demand the shop that did the overhaul to replace the original fitting. By them changing it to another style without a 337 is probably not kosher,,,, If ya can't get them to admit to the fact they" altered" the certified version then a call to the feds is in order, that should **** someone off for sure. |
The WHAT? Of COURSE it was there when I bought the plane.
Jim "BTIZ" wrote in message news:58G3f.5811$MN6.3188@fed1read04... Most likely the quick drain installed on the old engine was not "kosher", no old entry in the engine logs installing the quick drain, and the engine shop put it back to specs. Be careful who you call... and for what. BT |
I guess the sticker with the date must have fallen off my voltage regulator.
"RST Engineering" wrote in message ... The WHAT? Of COURSE it was there when I bought the plane. Jim "BTIZ" wrote in message news:58G3f.5811$MN6.3188@fed1read04... Most likely the quick drain installed on the old engine was not "kosher", no old entry in the engine logs installing the quick drain, and the engine shop put it back to specs. Be careful who you call... and for what. BT |
I use the Curtis drain valve with their drain hose. It works pretty well.
Mike MU-2 "dlevy" wrote in message ... I have a newly overhauled engine. Previously, I had a quick drain with a barb connector to allow using a hose to drain the oil in a bucket. I just stuck a lenght of garden hose on the barb and opened it up. I now have this quick drain that has no barb connection. I don't see any threads to put a barb connection. I would guess I'm probably not the only person in the universe that has this problem. Any suggestions? Thanks. |
On 13-Oct-2005, "dlevy" wrote: I now have this quick drain that has no barb connection. I don't see any threads to put a barb connection. I would guess I'm probably not the only person in the universe that has this problem. Any suggestions? Thanks. If it's just an issue of the end of the hose slipping off the smooth fitting, here's a suggestion. First, you need to experiment with various rubber/plastic tubing sizes to find one that fits as snugly as possible. Then, put an O-ring around the end of the tubing where it slips over the quick drain fitting. The O-ring should be of a size that slightly compresses the tubing, providing a clamping pressure on the quick drain fitting. You may find it useful to cut a groove around the tubing in order to keep the O-ring in place. -- -Elliott Drucker |
"dlevy" wrote in message ... I have a newly overhauled engine. Previously, I had a quick drain with a barb connector to allow using a hose to drain the oil in a bucket. I just stuck a lenght of garden hose on the barb and opened it up. I now have this quick drain that has no barb connection. I don't see any threads to put a barb connection. I would guess I'm probably not the only person in the universe that has this problem. Any suggestions? Thanks. I probably have the same quick drain. I found a piece of tubing that is a press fit, and press it on every time I drain the oil, then pull it off afterwards. |
| Spider in Archer Sump Drain | Bob Chilcoat | Owning | 3 | June 29th 05 11:29 PM |
| QUICK EASY CASH | [email protected] | Owning | 1 | April 20th 05 08:18 PM |
| QUICK EASY CASH | [email protected] | Piloting | 0 | April 10th 05 03:56 AM |
| QUICK EASY CASH | [email protected] | Soaring | 0 | April 10th 05 03:55 AM |
| sump drain cleaning | Mike Noel | Owning | 15 | August 15th 03 03:41 AM |
