Sudden Flat Tire
Old October 13th 05, 06:54 PM
Kevin Kubiak
Default Sudden Flat Tire
Strange thing happened to me earlier this week (monday).
I flew from home base at KUGN to KDBQ with a friend
for a quick stop and then we were planning to fly up the Mississippi
to look for some fall colors.
Had a nice clear day with light winds. So we land at DBQ, I taxi over to the
FBO for a quick pit stop. Got back in the plane, got ATIS, contacted ground and
given taxi instruction to 36. So I'm # 2 in line, just finish mag check and
now I'm # 1. Start to move forward and seemed like the pedals were hare to
steer. I quickly think I got a flat nosewheel, and shut down the engine, worried
that I might strike the prop. Anyway, contact ground told them on problem and
plane behind me says yep it is flat.
FBO sends a truck to fill the tire, but the air rushed out almost as fast as it
entered. SO we now need a tow back to FBO. 2.5 hrs later I have new tire and
tube and we are off back to KUGN. Luckily I take the old tire & tube back.
Since the plane is owned by the club I'm a member in.
The general manager said I will be reimbursed for the repair, but was curious
about the flat. I was too since the tire looked to be relatively new.
In fact it was only replaced 2 weeks prior. The problem apparently was that
some of the steel cord must have popped up through the tires sidewall and
punctured the tub. If you rub your hand over the inside you can feel the steel
wire protruding through the sidewall.
Does this kind of thing happen frequently. Did I over react by shutting down
the engine, but I was really did not want to add a prop strike
to ruin my day?
Could side load or bad landings, bouncing on the nose cause such a failure?
My landing just prior to the this occurring was fine, mains first, then slowly
down on the nose. Just curious. Also, what would happen if the tire went flat
during flight? I guess I would know the minute the nose settled on the runway.
If that happened, all I could do is hold the nose off by pulling back on the yolk.
Kevin Kubiak PP-ASEL
Old October 13th 05, 07:05 PM
Seth Masia
I can't conceive of an operational situation that would cause a steel cord
to come adrift from inside the molded rubber. This wouldn't be an issue with
the tubeless tires on your car, but I'd hate to have it happen in the air
with an aviation tire -- bad news to land on a flat you didn't know about .
.. . . Sounds like a manufacturing defect to me. Someone should have a
heart-to-heart with the tire manufacturer.
Seth
"Kevin Kubiak" wrote in message
ground and
and
to steer. I quickly think I got a flat nosewheel, and shut down the
engine, worried
and plane behind me says yep it is flat.
as it
tire and tube and we are off back to KUGN. Luckily I take the old tire &
tube back. Since the plane is owned by the club I'm a member in.
curious about the flat. I was too since the tire looked to be relatively
new.
that
steel
down the engine, but I was really did not want to add a prop strike
to ruin my day?
failure?
slowly
flat
runway.
the yolk.
Old October 13th 05, 07:35 PM
Skylune
Thats strange. My car has run flat tires (making blow-outs impossible).
Aren't the same available for planes?
Old October 14th 05, 01:17 AM
Skywise
"Skylune" wrote in
lkaboutaviation.com:
Run-flats can blow out. The difference between them and regular tires
is that they have a stronger sidewall so that if you have you lose
pressure due to a leak or small puncture, the tire will not go so flat
as to ride on the rim. This allows you to drive a short distance at slow
speeds to get to safety and replace/repair your tire.
Someone else would have to answer that.
Brian (who knows what it's like to blow a tire at 85 mph)
http://www.skywise711.com - Lasers, Seismology, Astronomy, Skepticism
Seismic FAQ: http://www.skywise711.com/SeismicFAQ/SeismicFAQ.html
Sed quis custodiet ipsos Custodes? Supernews Sucks!
Old October 13th 05, 09:14 PM
On Thu, 13 Oct 2005 11:05:03 -0700, "Seth Masia"
I can. I was an auto mechanic for 9 years. Tires that had steel
reinforced tread could and did expose them if the tires were run at
low pressure for too long. Happened all the time. Don't see why
airplane tires wouldn't become damaged in the same manner if run with
low pressure.
The tire pressure for a Cessna 172S is 35 psi mains and 43 psi front
according to the POH. Last time I flew the rental, which was during
my biennial flight review a few weeks ago, I noticed the front tire
was low. The instructor had a pressure guage with him and admonished
me to keep one with me at all times myself. We found the front tire
was at 8 psi and both mains were around 10.
According to the CFI, land a bit cockeyed with tire pressures that low
and you could easily blow out a tire.
Corky Scott
Old October 14th 05, 12:21 AM
Peter Duniho
low pressure.
One main reason might be the duration of operation required to cause a
problem. Airplane tires do warm up, but not nearly to the extent that an
automobile tire would. They simply aren't used for the distances and speeds
that an auto tire experiences. The heat that is the cause of failure at low
tire pressures is much less likely to become a factor for an airplane tire
than for auto tires.
I can believe that the tire would separate from the rim, allowing the tire
pressure to be completely relieved. Technically, that would be a "blow out"
IMHO, but it's not the same as a failure of the actual tire material.
Pete
Old October 14th 05, 05:13 AM
BTIZ
Actually what is more common with low tire pressure is that on landing the
rubber tire "slips" on the rim during spin up.. putting pressure on the
valve stem and cutting it or wearing a hole near the valve stem.
BT
out" IMHO, but it's not the same as a failure of the actual tire material.
Pete
Old October 14th 05, 05:22 AM
Dave Stadt
"BTIZ" wrote in message
news:MfG3f.5812$MN6.547@fed1read04...
BT
That has been a problem with tube type tires since the days of the Model T.
It is mostly forgotten nowadays.
Old October 14th 05, 12:58 PM
On Thu, 13 Oct 2005 16:21:20 -0700, "Peter Duniho"
low pressure.
You are coming up with reasonable conjectures as to why steel threads
might not work through the sidewall. The problem is the threads DID
work their way through the sidewall.
Rolling them at low pressure would flex the sidewalls more than they
are designed for.
Corky Scott
Old October 15th 05, 02:17 AM
Peter Duniho
My point is simply that absent a manufacturing defect, the usual mode of
failure due to low tire pressure doesn't apply.
are designed for.
But assuming no manufacturing defect, would not result in tire failure.
Pete
Blanik tire problem Greg Arnold Soaring 5 September 30th 05 06:02 PM
Tire question Jay Honeck Owning 30 February 8th 05 07:55 PM
Flat Spin JJ Sinclair Soaring 34 February 10th 04 05:57 PM
Tire Stiffness & trailer swaying - resolution chris Soaring 6 October 26th 03 03:50 PM
Tire Stiffness & trailer swaying chris Soaring 42 October 22nd 03 03:51 AM
