The original poster got it right with his use of the phrase "Runway ID",
because it is, in fact, an ID based on a number, as opposed to some type of number. What is the magnetic heading of Runway 5? If someone is named "Fred", do you refer to them as "Zero Fred"? The point is, we are dealing with a "name" which consists of a numeral, as opposed to an actual number. The runway is NAMED Runway 5. Why would you prepend a zero to a NAME? |
![]() AIM 4-2-10 "Directions: .... Examples 1. (Magnetic course) 005 .....zero zero five 2. (True course) 050.............zero five zero true ....." The magnetic heading of Runway 5 is zero five zero. The discussion of name versus direction reminds me of the discussion by the Mad Hatter in Through the Looking Glass. It was used in a computer class to exemplify the difference between something and its name. "Lakeview Bill" wrote in message . .. The original poster got it right with his use of the phrase "Runway ID", because it is, in fact, an ID based on a number, as opposed to some type of number. What is the magnetic heading of Runway 5? If someone is named "Fred", do you refer to them as "Zero Fred"? The point is, we are dealing with a "name" which consists of a numeral, as opposed to an actual number. The runway is NAMED Runway 5. Why would you prepend a zero to a NAME? |
"The magnetic heading of Runway 5 is zero five zero."
No... The magnetic heading of Runway 5 can be any heading between 046 and 054. From the Pilot/Controller Glossary: RUNWAY - ...Runways are normally numbered in relation to their magnetic direction rounded off to the nearest 10 degrees... Go to http://www.airnav.com/ and examine some of their airport information sheets. For example at KIGQ, with a magnetic variation of 02W (1995), RWY 18 has a heading of: 182 magnetic, 180 true. So, it really is best to think of a "runway number" not as a number, but as a name composed of numeric characters 0-9 plus "L", "R", "C". "Daniel L. Lieberman" wrote in message m... AIM 4-2-10 "Directions: ... Examples 1. (Magnetic course) 005 .....zero zero five 2. (True course) 050.............zero five zero true ...." The magnetic heading of Runway 5 is zero five zero. The discussion of name versus direction reminds me of the discussion by the Mad Hatter in Through the Looking Glass. It was used in a computer class to exemplify the difference between something and its name. "Lakeview Bill" wrote in message . .. The original poster got it right with his use of the phrase "Runway ID", because it is, in fact, an ID based on a number, as opposed to some type of number. What is the magnetic heading of Runway 5? If someone is named "Fred", do you refer to them as "Zero Fred"? The point is, we are dealing with a "name" which consists of a numeral, as opposed to an actual number. The runway is NAMED Runway 5. Why would you prepend a zero to a NAME? |
. .. The magnetic heading of Runway 5 can be any heading between 046 and 054. From the Pilot/Controller Glossary: RUNWAY - ...Runways are normally numbered in relation to their magnetic direction rounded off to the nearest 10 degrees... Go to http://www.airnav.com/ and examine some of their airport information sheets. For example at KIGQ, with a magnetic variation of 02W (1995), RWY 18 has a heading of: 182 magnetic, 180 true. So, it really is best to think of a "runway number" not as a number, but as a name composed of numeric characters 0-9 plus "L", "R", "C". If you don't think of the runway number as a number (corresponding to an approximate heading), then how do you form an expectation about which direction to fly to enter, say, a downwind leg for a particular runway? --Gary |
Good point...
I was dealing with "runway numbers" while communicating, where it probably is best to think of them as a "name". But, as you point out, one would want to think of it as a number while aviating... "Gary Drescher" wrote in message ... "Lakeview Bill" wrote in message . .. The magnetic heading of Runway 5 can be any heading between 046 and 054. From the Pilot/Controller Glossary: RUNWAY - ...Runways are normally numbered in relation to their magnetic direction rounded off to the nearest 10 degrees... Go to http://www.airnav.com/ and examine some of their airport information sheets. For example at KIGQ, with a magnetic variation of 02W (1995), RWY 18 has a heading of: 182 magnetic, 180 true. So, it really is best to think of a "runway number" not as a number, but as a name composed of numeric characters 0-9 plus "L", "R", "C". If you don't think of the runway number as a number (corresponding to an approximate heading), then how do you form an expectation about which direction to fly to enter, say, a downwind leg for a particular runway? --Gary |
. .. "Gary Drescher" wrote in message ... "Lakeview Bill" wrote in message . .. So, it really is best to think of a "runway number" not as a number, but as a name composed of numeric characters 0-9 plus "L", "R", "C". If you don't think of the runway number as a number (corresponding to an approximate heading), then how do you form an expectation about which direction to fly to enter, say, a downwind leg for a particular runway? Good point... I was dealing with "runway numbers" while communicating, where it probably is best to think of them as a "name". But, as you point out, one would want to think of it as a number while aviating... But if you're going to think of runway numbers as names while communicating but as numbers while aviating, then why not make the same distinction for the numbers that designate headings, altitudes, airspeeds, etc.? There are some numbers in aviation that are really just names (airway designations, aircraft model designations, tail numbers, etc.). But runway numbers are really numbers. --Gary |
Seems most appropiate to simply use the name painted on the end of the
runway. |
I always love it when they have to rename/repaint the runway because the
magnetic heading for the runway changed.. and to the non-informed... no.. the earth did not move to change the runway.. I'm betting some ol'timers out there remember when the leading zero was painted on... 05 so it was Runway zero five BT "Gary Drescher" wrote in message ... "Lakeview Bill" wrote in message . .. The magnetic heading of Runway 5 can be any heading between 046 and 054. From the Pilot/Controller Glossary: RUNWAY - ...Runways are normally numbered in relation to their magnetic direction rounded off to the nearest 10 degrees... Go to http://www.airnav.com/ and examine some of their airport information sheets. For example at KIGQ, with a magnetic variation of 02W (1995), RWY 18 has a heading of: 182 magnetic, 180 true. So, it really is best to think of a "runway number" not as a number, but as a name composed of numeric characters 0-9 plus "L", "R", "C". If you don't think of the runway number as a number (corresponding to an approximate heading), then how do you form an expectation about which direction to fly to enter, say, a downwind leg for a particular runway? --Gary |
![]() "BTIZ" wrote in message news:PBg4f.10452$MN6.7877@fed1read04... I always love it when they have to rename/repaint the runway because the magnetic heading for the runway changed.. and to the non-informed... no.. the earth did not move to change the runway.. Only in the case of Mayor Daley. |
![]() "BTIZ" wrote in message news:PBg4f.10452$MN6.7877@fed1read04... I'm betting some ol'timers out there remember when the leading zero was painted on... 05 so it was Runway zero five The real ol' timers remember when runways were numbered sequentially clockwise from north. |
Pilots | Slick | Piloting | 4 | November 20th 04 11:21 AM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Instrument Flight Rules | 117 | July 22nd 04 05:40 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Owning | 114 | July 22nd 04 05:40 PM |
Diamond DA-40 with G-1000 pirep | C J Campbell | Piloting | 114 | July 22nd 04 05:40 PM |
Rwy incursions | Hankal | Piloting | 10 | November 16th 03 02:33 AM |
