verifying airspeed indicator
Old October 17th 05, 01:07 PM
Heino & Deanne Weisberg
Default verifying airspeed indicator
I do not believe my airspeed indicator is accurate. Is there a way to
verify/calibrate an airspeed indicator on the ground?
Heino
Old October 17th 05, 03:50 PM
Heino
What sort of ASI do you have?
Have you looked to see if this is addressed in the manual?
For what range of speeds do you want to check/calibrate it?
In the air you can check it vs GPS.
FF
Old October 19th 05, 11:54 AM
Scott
GPS will show groundspeed only, so it would only be accurate in ZERO
wind conditions. However, I've read that you can compensate for wind by
flying N, S, E and W by using a compass for pointing your plane. You
point the nose in each direction and do NOT correct for wind drift (and
do not use the track readout on your GPS). In other words, you point
the nose for 90 degrees, even if your GROUND TRACK may be 98 degrees
because of wind. Take the 4 readings you get and average them. This
should get you in the ballpark.
Scott
Heino
Old October 17th 05, 04:07 PM
Nathan Young
On Mon, 17 Oct 2005 07:07:56 -0500, "Heino & Deanne Weisberg"
It might be easier to calibrate in the air (that is unless your
homebuilt is not flying!).
You can determine true airspeed empirically through the use of a GPS
while flying. Specifically, go to the following website, follow the
instructions to capture the data and then use their 'true airspeed
applet' to calculate true airspeed.
http://www.reacomp.com/true_airspeed/
If you note temperature, pressure, you can work backwards to figure
what the indicated airspeed should have been.
-Nathan
Old October 18th 05, 03:22 PM
Kublai
I don't think testing against GPS makes sense at all, as the ASI will
surely work properly if indicating wrong ground speed at headwind - so
what information do you gain ?
Kublai
Old October 22nd 05, 06:46 AM
I do not know but if you found the answer please tell me.
regards
Old October 22nd 05, 06:49 AM
I am ehsan ashrafi,student of aerospace eng.I would like to share my
experiences with you
where do you live and what is your course
regards
Need glider airspeed indicator [email protected] Soaring 1 June 21st 05 09:57 PM
Inaccurate airspeed indicator Wyatt Emmerich Instrument Flight Rules 20 April 20th 04 12:08 AM
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 12:14 PM
