For the ATC guys: I frequently have departed VFR, but then do a popup
if needed. Frequently these are sortof foreseeable possibilities, but often enough I have been able to proceed VFR all the way. I've often wondered just how much of a hassle it is to ATC to have to deal with a popup. |
skym wrote:
: For the ATC guys: I frequently have departed VFR, but then do a popup : if needed. Frequently these are sortof foreseeable possibilities, but : often enough I have been able to proceed VFR all the way. I've often : wondered just how much of a hassle it is to ATC to have to deal with a : popup. ... and a corollary: If one does *NOT* do a popup, but rather files IFR and departs VFR, how much of a hassle is it to open said flight plan mid-stream? Picking up a flight plan filed with a different FSS for departure 3 hours earlier is not likely to work and will degenerate into a popup. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
![]() wrote in message ... ... and a corollary: If one does *NOT* do a popup, but rather files IFR and departs VFR, how much of a hassle is it to open said flight plan mid-stream? Picking up a flight plan filed with a different FSS for departure 3 hours earlier is not likely to work and will degenerate into a popup. Do you mean filing IFR from an untowered field and calling for clearance shortly after departure? That usually works quite well as it is actually easier for the controller. |
Steven P. McNicoll wrote:
: ... and a corollary: If one does *NOT* do a popup, but rather files IFR : and departs VFR, how much of a hassle is it to open said flight plan : mid-stream? Picking up a flight plan filed with a different FSS for : departure : 3 hours earlier is not likely to work and will degenerate into a popup. : : Do you mean filing IFR from an untowered field and calling for clearance : shortly after departure? That usually works quite well as it is actually : easier for the controller. I'm primarily used to untowered fields, so the clearance delivery and void time et al can be kinda a pain. It was the "shortly after departure" that I was thinking about. Basically, planning to make the trip VFR, but filing an IFR plan in case the weather's worse than you expected. If you're 2 hours down the road VFR without having opened your IFR flight plan and you try to open it then and get a clearance, it's probably been flushed from the system and is as bad as a pop-up. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
![]() wrote in message ... I'm primarily used to untowered fields, so the clearance delivery and void time et al can be kinda a pain. It was the "shortly after departure" that I was thinking about. Basically, planning to make the trip VFR, but filing an IFR plan in case the weather's worse than you expected. If you're 2 hours down the road VFR without having opened your IFR flight plan and you try to open it then and get a clearance, it's probably been flushed from the system and is as bad as a pop-up. Even if it's still in the system the controller working the airspace two hours down the road from your filed departure point isn't going to have the flight plan. And you shouldn't expect him to. |
: Even if it's still in the system the controller working the airspace two
: hours down the road from your filed departure point isn't going to have the : flight plan. And you shouldn't expect him to. That's what I was saying. Although it is pretty sad that the nationwide system cannot keep everything together in a unified way. It's not that it's that much data... just that the system is so old that it cannot handle it. If a couple megabytes of memory in a GPS can handle every APT, VOR, ADF, INT for all of north america, regular computers shouldn't have trouble. Anyway... I'm not really bitching... honest... ![]() procedures are due to limitations in the infrastructure AIUI. -Cory -- ************************************************** *********************** * Cory Papenfuss * * Electrical Engineering candidate Ph.D. graduate student * * Virginia Polytechnic Institute and State University * ************************************************** *********************** |
Shouldn't he have some way of getting it though? (well, E.g. 30
minutes down the road rather than 2 hours) ? Here's my specific example. I file IFR flight plan from Temple TPL to San Antonio SAT. I take off VFR and head toward SAT. I'm in Gray approach control's airspace when I take off, but 20 minutes later I'm no longer in Gray's airspace. I decide I'd like to get my IFR clearance so I call Houston Center. Should ZHU have a strip on me? And if not, can they somehow pull it up, to give me a clearance using that flight plan info? I *think* the answers to those last two are no and no. But it seems strange because it's all ZHU airspace, some of which is delegated to Gray. -- Cheers, John Clonts Temple, Texas N7NZ |
![]() "skym" wrote in message ups.com... For the ATC guys: I frequently have departed VFR, but then do a popup if needed. Frequently these are sortof foreseeable possibilities, but often enough I have been able to proceed VFR all the way. I've often wondered just how much of a hassle it is to ATC to have to deal with a popup. Depends on how busy the controller is and how far you need to go. If there's not much going on it's a simple matter for the controller to issue a clearance and enter it in the computer. If he's talking to a lot of planes at the time he may not have an opportunity to enter it in the computer. If it's not entered it's he can't let you go beyond his airspace. |
![]() skym wrote: For the ATC guys: I frequently have departed VFR, but then do a popup if needed. Frequently these are sortof foreseeable possibilities, but often enough I have been able to proceed VFR all the way. I've often wondered just how much of a hassle it is to ATC to have to deal with a popup. I think it VERY much depends on the facility. I've talked with controllers from several different facilities, asking a question basically "if I want to descend through the clouds to land, would you rather I go to FSS first, or just call you for a pop-up?" Invariably, out here in the middle of the CONUS, the answer has been "just give us a call - it's no more work for a pop-up than it is getting the clearance strip through the computer." Only once have I had a controller ask me to file with FSS first, and that (strangely enough) was coming into El Paso, TX. |
