Mike Schumann wrote:
'See and avoid has NEVER failed?????' Well, maybe this once. And rather dramtically, I might ad. If this had happened in Minnesota, I would have said 'Ouf dah!' http://www.aigaviation.com/salvage/Salvagecraftlz.aspx Steve Leonard |
Steve Leonard wrote:
Mike Schumann wrote: 'See and avoid has NEVER failed?????' Well, maybe this once. And rather dramtically, I might ad. If this had happened in Minnesota, I would have said 'Ouf dah!' http://www.aigaviation.com/salvage/Salvagecraftlz.aspx Steve Leonard The rest of the story: http://www.ntsb.gov/ntsb/brief2.asp?...A134B &akey=2 Well if you see and don't avoid... Shawn |
Here's another one for you. Sadly, had the glider on tow not released, the
tow plane would not have turned into the other glider. http://www.ntsb.gov/ntsb/brief.asp?e...12X18789&key=2 "Steve Leonard" wrote in message ... Mike Schumann wrote: 'See and avoid has NEVER failed?????' Well, maybe this once. And rather dramtically, I might ad. If this had happened in Minnesota, I would have said 'Ouf dah!' http://www.aigaviation.com/salvage/Salvagecraftlz.aspx Steve Leonard |
Just imagine the outcome if "see and avoid" was considered sufficient
on the road - No traffic lights, no stop signs, no multilane roads, you get the picture. And it is much easier to spot and avoid a car than aircraft. So why is it acceptable in the air, where the outcome is almost always catastrophic, and not on the ground, especially now, when we have the technology to avoid midairs? Mind boggling... Ramy Jim Vincent wrote: Here's another one for you. Sadly, had the glider on tow not released, the tow plane would not have turned into the other glider. http://www.ntsb.gov/ntsb/brief.asp?e...12X18789&key=2 "Steve Leonard" wrote in message ... Mike Schumann wrote: 'See and avoid has NEVER failed?????' Well, maybe this once. And rather dramtically, I might ad. If this had happened in Minnesota, I would have said 'Ouf dah!' http://www.aigaviation.com/salvage/Salvagecraftlz.aspx Steve Leonard |
