We have these on our Glasair right now and are swapping them out for
Matco's to get better stopping as they are undersized for our weight and landing speed. Would be fine for a lighter plane that had a slower stall speed, like an RV for instance. They actually work O.K. for the Glasair but we would just like to have more stopping power and margin. The wheels are completely functional,no cracks or anything that would be a problem. The rubber grommets around the tube valve stems are probably getting chewed up by now and should be changed out. Plane was always hangered so absolutely no corrossion. Brake discs have normal wear but are not cupped, rippled, wavy, scored, etc. We always replaced the pads before they got too thin and damaged the discs. The disc is Cleveland Part Number 1764-01700 and has a rating of about 117,500 foot-lbs of kinetic energy if you are interested in that. Discs are relatively new, as we replaced them about a year ago. The brake assembly is Cleveland Part Number 30-9. No leaks around the piston O-ring in either brake. But, if I were are installing these, I would pop a new O-ring in the calipers, so cheap and easy to do. The brakes use pad Part Number 66-106, available in a Cleveland version or a cheaper Rapco version. We have a set of 4 brand new pads for re-lining that we will thrown into the package. The wheels are Cleveland Part Number 40-78B. Includes the wheel taper roller bearings. No evidence of galling, heat damage, etc to the bearings or the cones. Not included are the master cylinders under the rudder pedlas as we are re-using them or any brake lines. In short, perfectly working Cleveland stuff at a discount. Please call if interested. These are currently sold as a homebuilder's kit by Aircraft Spruce as P/N 199-102 for $608 a pair. Comparable prices from Chief and Wicks. We would like to get somewhere around $300, half price for the same thing except used. Harvey 714-872-0951 |
WTB: Good Set 500 x 5 Wheels, Tires and Brakes | Steve Sharp | Restoration | 0 | March 20th 04 04:48 AM |
McCaully wheels & brakes available | Roger Long | Owning | 0 | March 4th 04 02:19 PM |
WTB: Pair 500x5 Tires, Wheels, Brakes | Spar | Home Built | 0 | February 16th 04 10:13 PM |
WTB: Pair 500x5 Tires, Wheels, Brakes | Spar | Aviation Marketplace | 0 | February 16th 04 10:13 PM |
WTB: Pair 500x5 Tires, Wheels, Brakes | Spar | Restoration | 0 | February 16th 04 10:13 PM |
