Navcom - handheld VS panel ?
Old October 29th 05, 12:13 AM
Default Navcom - handheld VS panel ?
Hello everyone - my first posting here.
I'm in the process of equipping my Earthstar thundergull with avionics.
This is a very light tandem 2 seater.
I was wondering what type of navcom to go with...handheld or panel
mounted.
Panel space is limited , so a panel radio choice would probably be the
Microair. But this is substantially more expensive than handhelds.
What are the disadvantages of a handheld ?
Would you recommend a specific handheld make & model ?
The aircraft does have an external antenna.
I do intend to fly into class C & D airspaces.
I do need intercom.
I do need squelch.
All input much appreciated.
thanks
Pavan Bhatnagar (PPASEL to be)
Old October 29th 05, 01:51 AM
mounted.
Well...it's not exactly an "either/or" situation. Check out the panel mounting
of an ICOM IC-A5 in my Fly Baby:
http://www.wanttaja.com/hhrad2.JPG
The radio is wired to conventional panel jacks, and is powered by the aircraft
12V bus by a "Battery Eliminator" purchased from Batteries America. No
modifications to the radio were needed...I just built a cage from 1.25" aluminum
channel (actually square tubing with one side cut away) and purchased the
four-conductor plug that fits into the headset adaptor jack for about $7.
The radio assembly is essentially self-contained...the headset jacks mounted
onto the side rails of the aluminum channel. The only wiring on the airplane
was a 4-conductor plug for power and PTT switch (plus the antenna, of course).
http://www.wanttaja.com/hhrad.JPG
The potentiometer is used to adjust the volume without being able to access the
knob on top. Everyone seems to understand me (quite unlike RAH :-), I can
receive stations 75 miles away, and whole installation weighs less than a pound
and cost less than $300.
I made a couple of postings about it to the Fly Baby mailing list:
http://groups.yahoo.com/group/flybabylist/message/5006
Old October 29th 05, 03:11 AM
tom pettit
I'll second Ron's use of a portable. I've been doing the same in my
homebuilt Savannah, also with an external antenna. It works fine. Mine is
an Icom A23. The VOR function is pretty lame, so I would save my money and
get a com only radio next time. The range seems to be as good as the "real"
radios in rental planes.
Don't forget that you'll need a transponder to go into a class C airport.
tom
"Ron Wanttaja" wrote in message
mounted.
mounting
aircraft
aluminum
mounted
airplane
course).
access the
pound
Old October 30th 05, 01:12 AM
Jase Vanover
Yeah whatever regarding the radio... I like the gauge on the right hand side
of your panel Ron. Nice to see that even sitting in the hangar it's pegged
at the redline ;-)
mounted.
mounting
aircraft
aluminum
mounted
airplane
course).
access the
pound
Old October 30th 05, 02:19 AM
keepitrunning
Default Fun Gauge
Ron, that is so cool, I want a fun gauge! Any suggestions as to where I
might find one?
Gary Melton
N320GG LNC2
"Jase Vanover" wrote in message
side of your panel Ron. Nice to see that even sitting in the hangar it's
pegged at the redline ;-)
mounting
Old October 30th 05, 02:50 AM
Default Fun Gauge
On Sun, 30 Oct 2005 02:19:30 GMT, "keepitrunning"
mounting of an ICOM IC-A5 in my Fly Baby:
might find one?
Your junk box, if you're lucky. The Fun Meter started out as a small voltmeter
made out of plastic. Once disassembled, the meter face was found to be a small
plastic disk held in place with a couple of tiny screws. I noted the size, drew
up my own meter, printed it on photo paper, and glued it over the old face.
Reassemble the meter, and the rest is history:
http://www.bowersflybaby.com/stories/meter.JPG
Originally, I kept the original needle movement but the needle eventually broke
when I had to take the meter apart to replace the paper face. I now use just a
scrap of white-insulated wire.
I've got a large empty instrument hole where the old radio used to go, and I'm
considering some kind of similar goofy project. Currently, I've just got a Fly
Baby logo in the hole...
http://www.wanttaja.com/hhrad2.JPG (Towards the bottom)
.... but I'd like to put in either a dummy radar or possibly a "weapons status"
display.
Old October 30th 05, 06:55 AM
Dan, U.S. Air Force, retired
Default Fun Gauge
might find one?
display.
How about a retractible cup holder or phaser/warp drive panel? In
the Air Farce one of our mockups had an instrument hole covered by a
square of alumininum labelled "phaser/warp drive." It was even once
written up by QC as "phaser/warp drive panel missing screws" since it
was held in place by 2 screws instead of 4 with 2 screw holes open. You
tax dollars at w**k
Old October 30th 05, 02:13 PM
Frank Stutzman
Default Fun Gauge
status" display.
No where as cute, but a one time I owned a 172 that landing gear switch
with indicator lights. I always wanted to figure out the circuit that
would make the lights "fail" randomly once every 20 hours or so.
Frank Stutzman
Bonanza N494B "Hula Girl"
Hood River, OR
Old October 30th 05, 03:56 PM
I would recommend the Microair, it can be purchased with an intercom.
I beleive the handheld may be problematic with an intercom and much
more of a hassel using and you still have to mount it somewhere.
Richard
www.craggyaero.com
Old October 31st 05, 08:08 PM
Thanks for all the input , folks.
regards
Pavan.
Panel mount for handheld Garmin GPSMap X96 series Brock Boss Owning 2 September 25th 05 01:26 AM
Why not a hinged panel? Jay Honeck Owning 22 March 7th 05 11:15 PM
Upgrade handheld GPS, or save for panel mount? [email protected] Owning 7 March 8th 04 03:33 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 01:10 PM
C182 Glass Panel Scott Schluer Piloting 15 February 27th 04 03:52 PM
