Wait! He can use a GPS in place of the ADF on that approach. Isn't that
correct? Rich Raine www.eraine.com "Brien K. Meehan" wrote in message ... "Gig Giacona" wrote in message ... And the ILS plate is marked ADF required? Why is that? ... because you need to know where the LOM/IAF called LADOS is. It's an IAF, so there's no previous fix from which you can start timing to find LADOS. DME is not required, so you can't assume you can use it to find LADOS - yes, even though it's clearly marked 5.2NM on the plate. If you want to get into ELD without an ADF, you'll have to use one of the other 3 approaches. Those aren't terrible options. |
Gig,
the initial approach fix (IAF) is defined by the NDB. how would you find this point without an ADF? You'd get around that with radar vectors, but you couldn't fly the full procedure without the NDB. And the missed approach is a hold on the NDB. Same problem. BUT: An approach certified GPS with the NDB in it's database can replace for the ADF. -- Thomas Borchert (EDDH) |
Let's see if I have this straight and please forgive any ignorance on my
part. When I got my PP-SEL in ELD '79-'80 there was no ILS or NDB approach at ELD just VOR. All the pilots bitched including the Lear and Citation pilots and their bosses and ELD gets an ILS. But it gets put in requireing ADF that even then was on the way out. This is the silliest thing I have ever heard of. "Thomas Borchert" wrote in message ... Gig, the initial approach fix (IAF) is defined by the NDB. how would you find this point without an ADF? You'd get around that with radar vectors, but you couldn't fly the full procedure without the NDB. And the missed approach is a hold on the NDB. Same problem. BUT: An approach certified GPS with the NDB in it's database can replace for the ADF. -- Thomas Borchert (EDDH) |
![]() "Gig Giacona" wrote in message ... Let's see if I have this straight and please forgive any ignorance on my part. When I got my PP-SEL in ELD '79-'80 there was no ILS or NDB approach at ELD just VOR. All the pilots bitched including the Lear and Citation pilots and their bosses and ELD gets an ILS. But it gets put in requireing ADF that even then was on the way out. This is the silliest thing I have ever heard of. New NDBs are still being commissioned in the US. Stan |
![]() An instrument approach requires an IAF. In the case of an ILS approach, this must be separate to the ILS localiser and glideslope because of the directive nature of the aid. The most common solution is to use an NDB to provide the IAF and base the procedure on that. NDBs installed in conjunction with instrument approach aids are generally lower power than en-route NDBs. You could, in theory, use a VOR as the IAF as well, however. Also marker beacons are notorious for going on the blink, so a co-located NDB with the outer marker (called "LOC") provides an additional check for ranging on the final approach. (in some cases, the ILS system might not even have marker beacons, in which case an NDB will be required at the OM location). Remember that not all ILS systems have DME associated, so some form of range checking is required. The vast majority of ILS approaches in Europe use an NDB as the IAF and many of them use an NDB LOCator (colocated with outer marker). My local airport has several instrument procedures: ILS/NDB, NDB Only, VOR, and VDF. There is no DME on either the ILS or the VOR and since the VOR is on the A/D and not 7.5 nautical miles out like the NDB, it can't reasonably be used as the IAF for the ILS approach without totally throwing totally non-standard timings into the equation. (as it is already the VOR approach [non-precision] already has a non-standard outbound timing to begin base turn). You will find that even on some of the more advanced European airports, there are NDBs associated with the ILS at the outer marker location. (Heathrow, Gatwick, Stanstead, Luton, East Midlands, Birmingham, Paris Orly, Paris Charles de Gaulle, all have NDB LOCs at around 8 nautical miles out.). Also most holding procedures in the Europe use NDBs as the holding fix. (there are currently NO operationally published GPS approaches in the UK, and the CAA and even JAA are tending to be somewhat wary of implementing GPS procedures for instrument approaches.) Regards, Leland On Wed, 9 Jul 2003 08:40:13 -0500, "Gig Giacona" wrote: Let's see if I have this straight and please forgive any ignorance on my part. When I got my PP-SEL in ELD '79-'80 there was no ILS or NDB approach at ELD just VOR. All the pilots bitched including the Lear and Citation pilots and their bosses and ELD gets an ILS. But it gets put in requireing ADF that even then was on the way out. This is the silliest thing I have ever heard of. "Thomas Borchert" wrote in message ... Gig, the initial approach fix (IAF) is defined by the NDB. how would you find this point without an ADF? You'd get around that with radar vectors, but you couldn't fly the full procedure without the NDB. And the missed approach is a hold on the NDB. Same problem. BUT: An approach certified GPS with the NDB in it's database can replace for the ADF. -- Thomas Borchert (EDDH) |
![]() "Leland Vandervort" wrote in message ... Also most holding procedures in the Europe use NDBs as the holding fix. (there are currently NO operationally published GPS approaches in the UK, and the CAA and even JAA are tending to be somewhat wary of implementing GPS procedures for instrument approaches.) Is there a single rationale for this wariness? The obviously compelling reason is that other nations would be reluctant to throw the future of their air navigation into the hands of a system controlled by the US military - we're allies now, but alliances change within the lifespan of an aeronautical system. Or is there something more mundane: the incremental cost causing slow adoption, or the decision to put more INS systems into European planes before GPS came along, or roll out MLS faster than the US, or what? -- David Brooks |
![]() "David Brooks" wrote in message ... "Leland Vandervort" wrote in message ... Also most holding procedures in the Europe use NDBs as the holding fix. (there are currently NO operationally published GPS approaches in the UK, and the CAA and even JAA are tending to be somewhat wary of implementing GPS procedures for instrument approaches.) Is there a single rationale for this wariness? No, as MLS airborne equipments use GPS derived DME. The obviously compelling reason is that other nations would be reluctant to throw the future of their air navigation into the hands of a system controlled by the US military - we're allies now, but alliances change within the lifespan of an aeronautical system. The really compelling reason for building Galileo is to bridge a technology gap, unfortunately TACAN stations interfere with the proposed Euro Nav signal. Or is there something more mundane: the incremental cost causing slow adoption, or the decision to put more INS systems into European planes before GPS came along, or roll out MLS faster than the US, or what? Working MLS uses GPS, so the reasoning has to be somewhat convoluted. Then again, if Galileo provides binary stars, the Europeans will be ahead of the US in space based Navigation. John P. Tarver, MS/PE |
Leland Vandervort writes:
The vast majority of ILS approaches in Europe use an NDB as the IAF and many of them use an NDB LOCator (colocated with outer marker). Ditto for Canada: to my knowledge, we no longer have any marker beacons at all. Every Canadian ILS approach I've seen so far has an NDB as the IAF/FAF, but I'm sure that someone can point out an exception somewhere. I was surprised to see the marker lights on my audio panel light up, one after the other, when I overflew Albany NY a few weeks ago -- I had never seen them light up except with the test button, and even turned on the audio just to hear what they sounded like. All the best, David -- David Megginson, , http://www.megginson.com/ |
On Thu, 10 Jul 2003 02:06:30 GMT, David Megginson
I was surprised to see the marker lights on my audio panel light up, one after the other, when I overflew Albany NY a few weeks ago -- I had never seen them light up except with the test button, and even turned on the audio just to hear what they sounded like. S'okay.. at my base airfield we have OM and MM, but half the time they don't work anyway... di-dah-di-dah-di-dah-di-dah dah-dah-dah-dah-dah di-di-di-di-di-di-di ![]() Leland |
On Tue, 8 Jul 2003 14:18:55 -0500, "Gig Giacona"
wrote: I've not been flying in a while and don't have an IR. But I plan to get one as soon after I finish building my plane. I was looking at this approach plate for my home field http://www.myairplane.com/databases/...l/ELD_ir22.pdf or http://tinyurl.com/gcjc And the ILS plate is marked ADF required? Why is that? PPSEL R-H My Zodiac 601XL www.peoamerica.net/N601WR Two reasons -- the (one and only) IAF is defined by the LOM, and that is also the missed approach fix. An ILS approach still has the missed approach as a integral segment. |
The perfect approach | Capt.Doug | Home Built | 25 | December 3rd 04 03:37 AM |
Which aircraft certification is required for R&D? | Netgeek | Home Built | 5 | November 23rd 04 05:59 AM |
LSA Approach speeds | Ace Pilot | Home Built | 0 | February 3rd 04 05:38 PM |
Download approach charts | Ron Natalie | Home Built | 0 | July 9th 03 08:29 PM |
