Holding Pattern Entries
Old July 9th 03, 02:01 PM
Dan Luke
Default Holding Pattern Entries
"Ryan Ferguson" wrote:
If one's SA is what it should be, ciphering out which of the three
standard
entries to use becomes a waste of time and therefore counter to safe
practice.
Shouldn't require any ciphering out. Once you visualize where you are and
where
the hold is, figuring the entry should be essentially 'automatic.' This
is why
I've never been a fan of any of the various 'memorization' methods such as
thumb, dividing the DG into P-T-D, etc. If you can see what it looks
like, you
just fly the entry without further thought. Frankly it sounds to me like
your
initial instructor might have made this process painful enough for you
that you
just wrote it off early. I nearly did the same myself.
Ha! I could feel you out there steaming!
If you draw a few entries via the method I posted, you'll see that it
produces practical P-T-D entries automatically.
That's why the concept of "the official entries" is a bad idea.
The concept is good (and it's not going away.) The execution (by pilots)
is
often bad. It leads to a frustration which sets in and can be hard to
combat.
I was once more aligned with your thinking, but over time and with
experience
I've come to realize that they're actually a very elegant and simple tool
waiting to be discovered.
Any method that supports an industry of gizmos to figure it out isn't simple
and elegant.
That has not been my experience in my airplane. As you pointed out, the
whole secret to holding is situational awareness. If I'm doing a
one-shot
course reversal, I will adjust the procedure accordingly to give myself
time to intercept properly.
Which procedure will you use and how will you select it?
The one I posted - it's the one I use every time. By "adjust the procedure"
I mean the time I fly on the outbound leg, which may mean adding 30 seconds
to it to ensure adequate time to intercept the FAC. I would do the same
thing if I had flown a "book" entry.
Why are you willing to do that on course reversals and not hold entries?
I'll do it on any procedure I fly. Situational awareness, remember?
Shame on you if you do - that's why a racetrack is depicted; you're
allowed
to go all the way around if you need to.
That's a poor choice and only an option that should be taken if your
flying was
sufficiently sloppy to require it.
Not necessarily. Why do you think holds are depicted for some course
reversals? Why not a PT every time?
The guy waiting to fly the approach behind
you now has to wait. Why - simply because you didn't want to do a little
applied thinking?
If I have to make a full circuit, it won't be because I didn't fly a perfect
teardrop entry. It will be because there is something about the approach
that requires it. I've never had to do this, BTW.(Really, the orthodox
teardrop is the only one that's any different from my method, and it's not
much different.)
And as for applied thinking, may I respectfully suggest that you might do
little more of it on this subject. Draw a series of entries with the
orthodox method and then overlay them with drawings of the method I suggest.
I think you'll see there's not enough difference to matter.
Dan
C172RG at BFM
Old July 9th 03, 02:04 PM
Dan Luke
To Dan's credit, the 'when all else fails' method of hold entry is fine.
It works
when you can't think straight...
Heyyyy...!
Dan
C172RG at BFM
Old July 9th 03, 02:31 PM
Ryan Ferguson
Dan Luke wrote:
Heyyyy...!
You're prolly the only guy on usenet with whom I have so many fundamental
disagreements, yet still like to chat with.
Stay cool, mang.
-Ryan
CFI-ASE-AME, CFI-RH, CP-ASMEL-IA, CP-RH, AGI
Old July 9th 03, 05:09 PM
Michael
Ryan Ferguson wrote
If one's SA is what it should be, ciphering out which of the three standard
practice.
Shouldn't require any ciphering out...
If you can see what it looks like, you
You know, that was going to be my response - and then I realized we're
not all looking at it the same way. The AIM divides the compass into
three sectors - 180 degrees for direct, 110 for parallel, and 70 for
teardrop. Suppose you're close to one of the sector division lines?
Now you're going to be doing mental math or some other timewasting
procedure to figure out if you should be doing a parallel or teardrop
entry.
My solution is don't do that. Pick the one that looks right. So
you're doing a teardrop when you're really in the parallel sector by
10 whole degrees. SO WHAT? It's still going to work just fine. If
you've correctly visualized the entry, being off a few degrees is
irrelevant.
I would be happier if the official depiction, instead of using sector
lines, had grey sectors maybe 30 degrees wide (probably centered on
the present dividing lines) for those regions where either of the
entries is appropriate. After all, that's realistically how we do it.
Michael
Old July 9th 03, 07:21 PM
Dan Luke
Oh, that would make it *so* much less confusing.
Jeez.
Dan
C172RG at BFM
Old July 9th 03, 06:57 PM
Stan Prevost
"Michael" wrote in message
m...
The practical test is another matter. No, the official hold entries
are no longer required.
Not for the instrument rating. But I have always heard it said that the
following excerpt from the ATP Airplane PTS is interpreted to require
standard PTD entries:
4. Follows appropriate entry procedures for a standard, nonstandard,
published, or non-published holding pattern.
Stan
Old July 9th 03, 11:19 PM
Ryan Ferguson
Usually because the approach has to be designed that way, whether it's because
of obstructions, airspace, the missed approach procedure, or other issues. I
can assure you that when the weather's low and everyone's trying to get in, no
one will appreciate your extra lap if it wasn't necessary.
Most of the time, you're right. There's very little perceivable difference
between the brain-mush method and the actual prescribed hold entries. The
difference occurs when:
1) You need to hold, winds are blowing perpendicular to the inbound and outbound
course, and you don't want to blown to the wrong side of the hold. (Yes, I
realize that you're actually protected well into what we think of as
'unprotected' airspace, but that's simply sloppy flying - and we GA pilots have
a cushion because our airplanes are slow.)
2) You need to fly a course reversal (hold-in-lieu) and stabilize the approach
early (when it ideally should be stabilized.) A 172 is easy to stabilize on
damn near any segment of any approach. A Twin Comanche is not.
3) When taking a flight test.
4) When instructing students who need to pass flight tests.
5) To satisfactorily pass an ATP flight test.
6) In many cases, to 'pass' a job interview, for the career-minded among us.
Regardless of the way you decide to fly, Dan, you just can't throw this out!
Best regards,
-Ryan
Old July 10th 03, 05:43 PM
PaulaJay1
In article , Ryan Ferguson
writes:
Well, I guess I kinda feel that being situationally aware of where
the holding pattern is and from which direction one is approaching
shouldn't tax the brainpower, and once one knows that the correct
P/T/D entry is pretty obvious.
You'll get no disagreement from me! If that works for you, use it. As I've
already mentioned in
this thread, I believe learning the standard entries sans the various memory
aids and finger tricks
tends to lead toward proper visualization of the hold, your position, and how
to enter it with very
little thinking. For those who can't do that easily, the 'just turn
outbound' method is an
alternative which THEY might find simpler.
Lots of training for holds but, in 7 years, I've never had one. Sure, I do
them for practice but have never been given one by ATC. However, if the
training help spacial awareness, it's all for the good.
Chuck
Old July 10th 03, 05:56 PM
Ryan Ferguson
I've had 3 assigned in 1,200 hours.
writes:
Chuck
Old July 10th 03, 11:04 PM
Ray Andraka
I've had about a half dozen in 800 hours. Seems they are much more likely when the
weather is yucky. Only two were in VMC, one for traffic control going into Atlantic
City for one of the airshows, and one for traffic outside of NYC on V16. The others
were all in IMC.
writes:
Chuck
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
Hickory NC Airport Flight Pattern HBYardSale Aerobatics 1 March 11th 04 02:19 PM
Machinista 2004 - call for entries Robb Mitchell Machinista.org Home Built 0 February 24th 04 02:19 PM
the Jumping Jack - Electric ARF Pattern Plane FlitonUSA Aerobatics 0 January 15th 04 07:39 AM
