In article , writes:
I was just wondering, are the uber hackers still on RAH? I have a problem with windows XP that nobody's been able to fix. I have a good suggestion but I doubt that you would take it. Take your computer, load it in your plane, climb out to 20k ft and shove it out. I guarantee it will end your problem. Short of that, get rid of Windows XP. Bob Reed www.kisbuild.r-a-reed-assoc.com (KIS Builders Site) KIS Cruiser in progress...Slow but steady progress.... "Ladies and Gentlemen, take my advice, pull down your pants and Slide on the Ice!" (M.A.S.H. Sidney Freedman) |
On 10 Jul 2003 22:02:30 -0700, Kali wrote:
Robert Reed is correct. The Gods use Linux or OSX. Only mortals and lower demigods use Windows. And I suppose you're Lucifer if you use OpenBSD, right? :-) -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
![]() "Kali" wrote in message om... (Dylan Smith) wrote in message ... On 10 Jul 2003 22:02:30 -0700, Kali wrote: Robert Reed is correct. The Gods use Linux or OSX. Only mortals and lower demigods use Windows. And I suppose you're Lucifer if you use OpenBSD, right? :-) Lucifer uses CP/M. I used to dos around a bit, however I've never done a cp slash m anywhere, it's a bit before my time. -- .. -- Cheers, Jonathan Lowe modelflyer at antispam dot net Antispam trap in place Many of the Gods use OpenBSD on secondary machines, several of us attended the hackathon at Calgary. But few would have understood the reference. |
![]() "Model Flyer" wrote in message ... "Kali" wrote in message om... (Dylan Smith) wrote in message ... On 10 Jul 2003 22:02:30 -0700, Kali wrote: Robert Reed is correct. The Gods use Linux or OSX. Only mortals and lower demigods use Windows. And I suppose you're Lucifer if you use OpenBSD, right? :-) Lucifer uses CP/M. I used to dos around a bit, however I've never done a cp slash m anywhere, it's a bit before my time. -- I got out my old Osborne CP/M machine just this last weekend and fired it up to see it it would still run and it does. Its been probably 12 years since I run it last. Jerry |
![]() "Kali" wrote in message om... (Dylan Smith) wrote in message ... On 10 Jul 2003 22:02:30 -0700, Kali wrote: Robert Reed is correct. The Gods use Linux or OSX. Only mortals and lower demigods use Windows. And I suppose you're Lucifer if you use OpenBSD, right? :-) Lucifer uses CP/M. Many of the Gods use OpenBSD on secondary machines, several of us attended the hackathon at Calgary. But few would have understood the reference. This is a canard. Lucifer does not use CP/M. He just wrote the documentation. Tim Ward |
Tim Ward wrote:
"Kali" wrote in message om... (Dylan Smith) wrote in message ... On 10 Jul 2003 22:02:30 -0700, Kali wrote: Robert Reed is correct. The Gods use Linux or OSX. Only mortals and lower demigods use Windows. And I suppose you're Lucifer if you use OpenBSD, right? :-) Lucifer uses CP/M. Many of the Gods use OpenBSD on secondary machines, several of us attended the hackathon at Calgary. But few would have understood the reference. This is a canard. Lucifer does not use CP/M. He just wrote the documentation. Tim Ward IIRC One of the C/PM manuals set the long time recodr for bad and usless documentation. Bill Higdon |
![]() "Kali" wrote in message m... || | | Robert Reed is correct. The Gods use Linux or OSX. Only mortals and | lower demigods use Windows. | That is because us mortals use applications instead of operating systems. I don't give *&(% about the operating system as long as the application does what I want it to do. |
